Question about Alps MD 5000 Thermal Printer
Looking for an Alps MD5000 driver for Mac OSX
Also need to find an adapter to connect the 50-pin SCSI port on my Alps MD5000 to my Mac which only has USB and Ethernet ports.
    Sniper:
  • 58 Answers
There are no OS X drivers for the 5000.
If your version of OS X is old enough, you can run the )S 9 driver under classic.
Posted on Jul 19, 2009
  • 1,305 Answers
Here's an alternative: Adaptec makes a scsi card that you can put in your mac...If it's a tower. It's got a 50-pin high density exterior connector... you should be able to connect your unit to this...
it's the Adaptec 29160N...there are a few different varieties...look for the high density 50-pin...my research is showing you may have to spend a little to get one.
Posted on May 24, 2009
  • 3,866 Answers
Well I found that www.driverguide has helped me find drivers but do not shoot the messanger on this also you can try www.download.com I am was told they have too
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Alps md5000 printer driver for pc with windows 7
Sorry, there are no Windows 7 Drivers. There are a couple of work arounds. I use an older laptop with Windows XP. The XP drivers are easy to find on line. There is another way, but I have not tried it. It's using XP compatibility mode in Win 7.
Dec 08, 2012 | Alps Office Equipment & Supplies
Alps MD 5000
1. delete any MD5000 printer entries. *(I had no other printer entries defined)*
2. Use ADD/REMOVE programs to remove the driver.
3. Disconnect printer USB cable (one you bought on EBAY) My laptop has no Parallel port.
4. Reinstall Driver (I am using 2.2.4) specifying not to make it the default printer. For me the 2.2.4 install worked fine.
5. use the add a printer function to manually add the MD5000P. I pointed the install wizard to the 2.2.4 file created by the installation of the driver when it asked if I had a disk. for my computer that was:
C:\Documents and Settings\AMD64\My Documents\My Received Files\MDP224XP
5. after the printer definition was successful , I followed the steps from a
previous message in the ALPS group listed below listed below:
RIGHT CLICK MD5000P ICON, and open properties menu for said printer (this is the one you created manually)
click PORT TAB:
pick a USB port ( virtual printer port) from list *(the install set it to a
port of MD_LPT1 I selected USB001)*
DISABLE bi-directional support RADIO BUTTON,
click ADVANCED TAB:
click PRINT DIRECTLY TO PRINTER radio button,
OPEN PRINT PROCESSOR BUTTON on bottom of page,
from menu select ALMD224S (for print processor)
and DATA TYPE select RAW(FF AUTO).
I plugged the printer in a USB slot and printed test page and a color
photograph.
After this all worked I reset the USB port definition to reselect the bi-directional function. So I do run with the bi-directional mode
Note that Win XP itself will auto create a printer definition using a Microsoft driver "Alps MD-5000P (MS)" if you use this printer to print you will not get any of the ALPS functions.
But this seems to have worked for me.
I hope this helps you. I have only worked with an Alps MD5000 so I have not done this with any other model but the steps I think the steps could still apply because of windows requirements. I have not tried to install the driver on Vista so I do not know if it will work but it might.
Hope this helps.
If any of this is a problem you can contact me and hopefully we can work it out on the phone or chat or whatever
Good Luck
Jan 27, 2008 | Alps MD 5000 Thermal Printer
I have an alps MD400 and am running xp pro with drivers for xp and can't get the thing to print and need a trouble shooter
There are WinXP drivers for the MD-4000. You can find them in the files section in the Yahoo ALPS Group. There are some conflicts with the Windows XP (Service Pack 3) and the ALPS printers. It is best to connect to a computer running SP2 and has a parallel port. The ALPS group also has the Twain for the Scanner. The MD-4000 does require a carrier to scan things.
Dec 17, 2010 | Alps MD 5000 Thermal Printer
I want to retrieve data from an old 50-pin hd from my old mac. Anybody got a solution?
There are two ways of retrieving data from a SCSI hard drive.
1. Connect the SCSI hard drive to a different SCSI connector on the same data cable, make sure this hard drive has a different SCSI ID from the first hard drive or other SCSI devices in your system. When you boot up your MAC you should see the second SCSI hard drive, You can then copy off your data or remove the redundant files and keep the old hard drive in your system as a 2nd hard drive.
2. Connect the old SCSI hard drive to a SCSI USB hard drive adapter. Then connect it to the USB port on the MAC and you should see this as an external hard drive.
Jun 14, 2010 | Ricoh 2GB Printer Drive (SCSI-50PIN)...
SCSI to USB connection
You would need a USB to SCSI (50 pin Centronics) adapter. That would get it connected, but i don't you are going to find any software or drivers that will then see the scanner so you could use it.
May 11, 2010 | Apple OneScanner 1200 Flatbed Scanner
I use a Mac G3 Wallstreet Powerbook with OSx. Does OSX talk SCSI?
It will only read devices connected unless there is a problem with the scsi port. Also be aware early scsi needed termination to be read.
Apr 08, 2010 | Apple Power Mac G3 Desktop
SCSI to USB Cable or Converter for Astra 2400S Scanner?
You need a Firewire/ SCSI adapter. Mine is a Belkin F5U541. Then simply connect a SCSI cable from the scanner to the adapter & a Firewire cable from the adapter to your Mac. I'm using my old Umax Astra 2400S w/ a G5 iMac running OSX 10.6.7. I had to upgrade my old copy of VueScan, however, to run on Snow Leopard
Jan 16, 2010 | Umax Astra 2400S Flatbed Scanner
MD5000 to MACBOOK PRO problem
MAC is NOT my forte... however, I do know that ALPS offered THIS a few years after the MD5000 came out:
USB Interface Kit for the iMac OS V8.01 and Windows ($99)
You might find it on ebay etc. and be able to use it (no support with this printer on OS X!).
Apr 08, 2009 | Alps MD 5000 Thermal Printer
Trying to connect Umax PL 2100XL (SCSI) to G4 - scanner not found
I just told someone else this solution...KILL the SCSI junk...I had nothing but trouble with it with my Mac....I got a Ratoc Firewire to UltraSCSI Converter...to solve the regular SCSI to ultra SCSI problem...I also bought an adapter....It works great...no need for a SCSI card...or a driver...you just plug directly into your firewire port! If anyone can help me with my TA adapter startup problem...I'll be thrilled! Carole
Mar 23, 2009 | Umax PowerLook III Prepress Flatbed...
SCSI Inquiry Command Failure w/Tandberg TDC 4120 tape drive
Try putting the tape drive on the last scsi termination point.
Jan 01, 2009 | Adaptec Cables & Converters...
Alps MD 5000 Thermal Printer Logo
553 people viewed this question
Top Alps Office Equipment & Supplies Experts
Jesse Walters
Jesse Walters
Samuel Konger
Samuel Konger
Are you an Alps Office Equipment and Supply Expert? Answer questions, earn points and help others
