Question about Mastercool 67680 Evaporative Cooler Air Conditioner
Fan sliding the fan is sliding on the bar inside the unit and hitting the side of the wall.... What should be holding the fan in place?
    Sergeant:
  • 293 Answers
Tha fan is fixed to the shaft (bar) with a set screw. It is located at the hub at the back of the fan.
Posted on May 28, 2009
Goodman ckl36-1e
You do not need a new unit ,it can be fixed, good luck finding an honest tech
Jul 01, 2013 | Heating & Cooling
REFRIGERATOR AND FREEZER NOT GETTING COLD. ERROR CODE 5Y.MODEL NUMBER LGUS2642LF2 SERIAL NUMBER 4A23305873
That error code is "SY" and not "5Y" and it is for the evaporator sensor error. You will need to replace the sensor.Here is the part to order.
The part comes with a 365 day, any part, any reason return policy.
Access the evaporator assembly cover in the rear of the freezer section. In convertible units that can function either as refrigerators or freezers, and is located toward the bottom of the unit on the inner back wall -- if necessary, remove the two lower glass shelves and the crisper compartments.
Remove the screws securing the evaporator cover to the freezer wall, using a Phillips screwdriver.
Pull the evaporator cover away from the wall just enough to access the electrical connection behind the cover. Be careful not to damage the gaskets on either side of the evaporator cover. Reach behind the cover and disconnect the electrical connection from its wiring harness. Remove the evaporator cover from the freezer.
Remove the wires inside the exposed evaporator assembly from their retaining clips, then squeeze the quick-connect mechanism to detach the wires from the fan motor.
Remove the two hex-head screws that hold the fan motor mounting bracket to the back wall of the unit, using a 5/16-inch socket or nut driver.
Remove the two hex-head screws holding the fan motor to the mounting bracket, using the 5/16-inch socket or nut driver, then pull the fan blade off the motor shaft.
Examine the fan to make sure the blades are not damaged; if necessary, replace the fan itself as well as the motor. Slide the fan onto the motor shaft.
Attach the new motor to the mounting bracket, using the 5/16-inch socket or nut driver to secure the two hex-head screws.
Replace and tighten the two hex-head screws that hold the fan motor mounting bracket to the back wall of the unit, using the 5/16-inch socket or nut driver.
Reattach the the fan motor wires by clipping them back into the quick-connect mechanism, and set the wires back into their retaining clips in the same manner as they were attached.
Set the evaporator assembly cover back into place, then reach behind and connect the electrical connection into the wiring harness.
Secure the Phillips screws that hold the evaporator cover to the freezer wall.
Replace the shelves and crisper compartments if they were removed, then plug the refrigerator into its power source and verify proper operation.
Regards,
Richard Roth
http://appliancecafe.com
Nov 07, 2012 | Frigidaire Refrigerators
I need to remove the front axle out of the differential on a 2003 Dodge Ram 1500? What is the best way to pull it out. I already have the half shaft taken off I just cant get the solid axle out of the...
when removing the front axle i believe that you must open the front differential cover and inside the dana you will see a small 8mm bolt located on the spider gear center it holds the pin bar in place and the pin bar holds both the upper and lower gears in place with a small washer below them. be careful when you pull the pin bar out to make sure the gears stay in place (upper and lower) do not let the washer fall out of the spider cage assembly. Then, carefully slide the U pin that holds the axle in (there are two of them one for the left axle and one for the right). Once the U pin slides off the axle the axle should slide all the way out of the whole differential - Note if the U pin you see at the end of the axle does not come off easy just push the axle IN ward towards the center of the differential and then slide it out with a small screw driver ..
Jan 12, 2011 | 2004 Dodge Ram 1500
How to remove towel bars and hooks from wall. No set screw visible. We did not install them.
Newer towel bars don't have set screws... Solution-slide off! There is an opening in the bottom of the bracket. Slide your flat head screw driver inside the opening and place pressure on the bottom. Make sure you place enough pressure to allow the holder to slide off.. Now pull on the holder and it will snap off...
Sep 23, 2010 | Moen 24 In. Towel Bar...
The towel bar just fell apart. The wall mounts remain in tact as well as the mounting hardware on 1 side (the piece that the bars (this towel rack has 2 bars) slide into. I can't figure out what holds...
The part that holds the bar up should either have a screw in the bottom to tighten up against the wall bracket or a hole to access a scew and turn the screw out to tighten to the wall bracket
Jun 20, 2009 | Gatco & Channel& Satin Nickel Towel Bar
Brew unit wont go back in in seaco incanto
There is a flag on the back side of the brew unit. Below the flag are 2 plastic bars that the flag slides in. Push in between the 2 bars and see if the flag will drop. If it does holding the brew unit with your right hand, take your left hand and place it on the bottom left side of the brew unit, then with 2 fingers reach up inside the bottom and grab the bar in the center and squeeze the bar to the left. This will bring the cylinder back into position and align the 2 triangles on the front of the brew unit. Once they are aligned push the lever to the right to lock up the brew unit. Leave the brew unit out, but everything else in place, then turn the machine on. Once
the machine is settled open the door, remove the drip tray and then insert the brew unit, drip tray and close the door.
Apr 26, 2009 | Saeco Incanto Classic Espresso Machine
Fan is hitting something -- can't get a it.
There are two screws that hold the rack in that holds the fan assy. Look at the very top of the fan where it connects to the housing. Kinda hard to explain but undo two 5/16 sheet metal screws they are on the top and to the sides, then grap the whole fan and housing and pull towards you. It slides on two rails and will come completely out of the unit and might have to remove some wires to get unit completely out. So make a chart and mark each location very carefully. And don't touch the circuit board with fingers at all. It is very easy once you do it one time you won't believe how easy it comes out. Let me know how it goes ken
Apr 22, 2009 | Heating & Cooling
New Super Mario Bros:Stuck on world 6
wow, I don't know how you guys got this far in the game if you can't wall jump... all you have to do is get on the red blocks and "wall jump" to the other side. how do you wall jump...? well you hit jump as you hit the wall. If you can slide down a wall, you can "wall jump" all you do is basically hit the jump button and the point the arrow pad (left or right) to which ever side the wall is at. ex if the wall is on your left (which is the case on this level) you jump close to the wall and hit left on the arrow pad and jump. MArio, then. will jump to the other side off the spot you hit the controls off. you could even jump straight up slide down the wall and just hit jump. Try practicing wall jumping, it'll make your life a lot simpler and the game much more fun :D good luck. you could twitter me if you have any questions, but twitter is kind of short with letters.
good luck to you all.
http://twitter.com/ilikeapples
Jan 27, 2009 | Nintendo New Super Mario Bros. for DS
Message waiting indicator light will not turn off keeps flashing
Slide the Nortel Grey Bar above the Hold & Rls buttons to reveal the setup button.
  1. Hit that button to show *Options List / # Setup list
  2. Press * to go into options.
  3. Use the arrow buttons or hit 3 to go into CLEAR MESSAGE WAITING
  4. Then hit 3 again to clear the message waiting
This should resolve the blinking light.
Nov 11, 2008 | Astra Meridian 9417 Corded Phone
Cleaning The Tower [inside]
there is a black lever just above the bottom screw...after removing the screws, push down on the lever and it should release the case to slide off
Dec 04, 2007 | Acer Aspire L100 PC Desktop
Mastercool 67680 Evaporative Cooler Air Conditioner Logo
88 people viewed this question
Top Mastercool Heating & Cooling Experts
Bill Long
Dan Webster
Dan Webster
Boyet Soriano
Boyet Soriano
Are you a Mastercool Heating and Cooling Expert? Answer questions, earn points and help others
