Question about Biozone Standard 2000 Air Purifier
Won't work with new bulb. says fuse needs to be replaced. where is the fuse and where do you get a new one.
I can't find the fuse in my biozone 2000 unit. says it needs to be replaced in the bulb has burned completely out...which mine has and now new bulb won't come on.
2 Suggested Answers
  • 9 Answers
SOURCE: The fuse keeps blowing in my biozone 1500 induct unit.
get yourself a cheap multimetre, check for a short circut or open circut. this should be your first step. refere to google for info on short/open circuts. check the capasitors (small cylender things) for leakes or if the top is popped up on them. if so replace with the SAME. hope i was of some help
Posted on Aug 17, 2009
Replace lamp biozone 1000
Here's some Biozone lamp info http://www.air-purifier.org/orderform.html. Replacing the lamp is pretty simple, just remove the old lamp and install a new lamp and fuse if any.
Aug 31, 2012 | Biozone Standard 1000 Air Purifier
S1730 sharper image ionic breeze GP
So you need another bulb correct
To order replacement lamps directly from The Sharper Image,
call 1-800-344-5555 and order item number SI922.
Lamps are effective for about 12 months of continuous use.
Dec 02, 2007 | Sharper Image Professional Plus Ionic...
BIOZONE 1000 HAS NO POWER
Maybe it also needs a new fuse or power supply?
Mar 01, 2012 | Biozone Standard 1000 Air Purifier
The blue lite fades to black after awhile after powering it up
It sounds like the lamp and maybe the fuse has gone bad and might need replacing. Here are some Biozone lamps and fuses http://www.air-purifier.org/orderform.html
Oct 11, 2010 | Biozone Travel Aire 250T Air Purifier
I was considering Biozone for restrooms etc and I assumed,as your info.says that it would be odour free?Some I have seen are not odour free.Is it just a uv lamp system or is there some form of ozone...
the UV lamp does produce some ozone .. this one specifies .04 ppm .. thats not very much but might be detectable as a slight fresh air odor .. some other types use electrostatic filtering and some even have strong ozone generators .. ozone does kill bacteria, fungus and such and will freshen the air removing many odors but is not considered healthy in large or concentrated amounts or for prolonged periods .. the UV lamp will also kill bacteria and fungus without producing so much ozone.
Purifying Method: Photoplasma, UV, ions, and ozone.
Oct 09, 2010 | Biozone 500 Air Purifier
My Flair stopped working correctly,so I purchased new Ozone plates. It still doesn't provide that clean ozone smell. I took mine apart and cleaned it and noticed a small bulb inside that doesn't light up....
pull the unit out of the enclouser and check the bottom for a circuit board and on the board their is a glass fuse see if it is blown. Also on that same board their is a small round black fuse that is labled f21 it is a 400ma 250 volt fuse on my unit and is soildered in this fuse is just for the ozone
May 23, 2010 | Ecoquest Flair Air Purifier
Aug 17, 2009 | Biozone InDuct 1500 Air Purifier
My blueair 501 suddenly stopped working. I turned it off to move it to another room, and it will not come back on. Outlet has power. Is there an internal fuse I can replace?
The power cord had burned out right at the point where it connects to the female receptable (the end that connects to the unit). Need replacement cord.
Jun 05, 2009 | Blueair 501 Air Purifier
Biozone Standard 2000 Air Purifier Logo
Top Biozone Air Purifiers Experts
Michael Youngman
Michael Youngman
Are you a Biozone Air Purifier Expert? Answer questions, earn points and help others
