Question about Nokia N95 Cellular Phone
Got wet now it gets hot and won't charge
I left it outside it got wet than I let it dry know it want hold charge and it gets hot while im talking. And the pictures and music I had stored comes on when it wants to...?
  • 3,866 Answers
Put it into RICE for 3 days to make sure the water is absobed for the unit the rice method works sometimes but its work the craps shoot.
Posted on May 25, 2009
Takes 4 to 5 dryer cycles to dry one load
usually thats a blocked vent to the outside..Its wet on the inside because its holding the condensation from the clothes .also check blower wheel ..One sure way is take your vent off the back of the dryer and dry a load if it drys in a normal time you know your out going vent is plugged
Feb 18, 2015 | GE Dryers
I have a jonway 125cc moped it won't start and the battery seems too be flat I have tried to charge it but it doesn't make any difference, the weather is quite wet and bike is left out when I&
try removing your spark plug and turning over the engine if you can see a spark your plug should still be ok if its wet around your plug it may be flooded try drying it off and trying again if you want to test your battery for charge i usually have 2 screwdrivers which i touch both electrodes of the battery then touch the screwdrivers together whilst taking care to not touch the metal of the screwdrivers if you get any spark at the contact point of the screwdrivers its not your battery if not charge it then try again if your batterys flat your lights wont work though also give your air filter a clean out that could stop it starting, also check your fuel is still getting to the carbs ok i hope this helps im ok with motorbikes but im no mechanic i know the basics good luck and be careful undertaking any work on fuel or electric use insulated drivers
Oct 15, 2012 | Jonway Motorcycles
Having trouble getting my new z445 to start when it is cold. It will turn over but not crank. I can give it a little puff of starting fluid and it will crank right up.
It sounds like you aren't getting a hot enough spark. Have you pulled out the spark plug and checked it?
First try to turn over the engine a few times.
Then immediately unplug the wire, use a socket to remove the plug, and check the end of the plug to see if its wet. If it is wet you are getting fuel, if it looks bone dry you aren't getting fuel and I can make some other recommendations.
Plug the wire back in and place the outside metal of the plug against the engine. When you try to crank the engine you will either see a nice spark or you won't.
Let me know what happens.
Jun 07, 2011 | Garden
I just had the LG WM3987HW washer/dryer combo installed on Saturday, and it will not dry our clothes. This machine is ventless and dries by dehumidification. The clothes are more dry at the end of the spin...
I also have this unit with the same problems. After lamenting on making a poor purchase decision, I found somewhat of a solution. Basically, water is not being expelled during the dry cycle. When I addressed this issue, clothes were MUCH more dry than before. Made a quick video demonstrating the fix: http://www.youtube.com/watch?v=8EhzuzSk2Ok
Nov 29, 2010 | LG WM3987HW Front Load Washer / Dryer
The door is always wet on the inside. I use the heated drying cycle. Glasses don't always come clean, are spotted, and the silverware is still wet. We have a water softner so that is not causing the...
1.you must fill your dispenser with jet dry.2. make swure water is hot going into maching from faucet then start machine. 3.add cascade soap. you will see a big difference. im a old bosch tech:) let me know what happens .
Feb 25, 2010 | Dishwashers
Plastic catch broken DeLonghi KBX1510
try supper glue??? but dont hold your breth that this will work,,, it realy dont like hot wet places! i know this from first hand experience,,,
as its holding up my left lung!!!!!! and im not kidding you there?
Oct 24, 2009 | DeLonghi KBX1510 Cordless Electric Kettle
Dryer keeps drying and getting too hot
Check the dryer vent .The vent is stopped up,in the vent,or in the inside of dryer,in the lint hopper.Clean it out and unstop the dryer,and the vent.
Oct 10, 2009 | Whirlpool LER5636P Electric Dryer
Suburban 99 no start after a raining outside
There is a drain in the distributor that gets clogged up and holds moister under the cap.It is like a vent .So i would replace the cap and rotor and check the vent hole the will fix the issue :)
Sep 09, 2009 | 2004 Chevrolet Aveo
The dryer gets hot but takes five hours to dry one load
Check the exhaust vent, make sure it's not kinked or squished behind the machine and that the outside vent is not clogged with lint. You should feel air blowing freely to the outside.
Also make sure the exhaust vent is not over the recommended length (refer to the manual).
Let me know if you still need help.
Apr 01, 2009 | Frigidaire Dryers
Nokia N95 Cellular Phone Logo
247 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
