Question about Smeg WDI12 Front Load Washer / Dryer
Fuses keeps fusing sometimes ok for a while sometimes fuses straight away
    Champion:
  • 249 Answers
Heating element may be faulty. Change it
Posted on Nov 25, 2007
SOURCE:
2007 dodge caliber cooling fans not working?
First try a wire straight to the fan from the positive battery to the fan keep you hands away from fan if it turn on check your. Fuse if ok try fan relay
Aug 24, 2014 | 2007 Dodge Caliber 2.0
Replaced horn fuse and it blew again right away this is a pontiac transport 1997 help
The fuse blows to prevent wire melting and eventual fire! If it blows straight away then there will be a short circuit somewhere in the circuit, which means the electricity is going from the battery positive to the fuse then straight back to the battery negative without any resistance. You would have to follow the wiring and test components until the fuse no longer blows. :)
Jul 01, 2012 | 1997 Pontiac Bonneville
Dryer comes on and tumbles. but no heat
Hi.
Check the thermal fuse. You can replace the fuse straight away, or you can first test it using a multimeter set on OHMS. If the multimeter reads Ohms infinity when you touch the fuse contacts with its probes, then the fuse is gone.
If the fuse is OK, then you can have a defective thermostat or heating element (electric models), with gas models you test coils, thermostats and ignitor (flame sensor rarely fails).
Regards.
Ginko.
Mar 10, 2011 | Dryers
My fuse keeps blowing for my tail lights help
This would be an indication of a direct short to ground somewhere in the circuit...
Does this vehicle have a trailer harness?
has it been wrecked?
Jan 10, 2011 | 2005 Nissan Frontier
Peugeot 307 sw ignition switch fuse keeps popping????sometimes the car will start and work normally but other times the dash lights illuminate but nothing works and the car wont start. replace the ignition...
there are three likely problems.... check the battery of the vehicle if the battery is still ok, or the alternator is not supplying the right power and finally the fuse box has some burnt part in it internally...
Jan 31, 2010 | 2005 Peugeot 405
Hi i have a300tdi disco it keeps blowing number 14 fuse.sometimes straight away.sometimes after 5 mins
According to the wiring diagram, No14 fuse is the 10Amp, which is connected in-line to the Engine Check light. It also runs to the Engine Control Module (ECM) and Anti-Theft system (if equipped).
Something in one of these circuits is triggering a malfunction.
I recommend you have the onboard Diagnostic computer scanned by your local Land Rover dealership, to extract any fault codes - this will immediately identify the faulty component/s.
If no codes are present, then the vehicle will need to go to an Auto Electrician, to locate and rectify the fault.
Nov 12, 2009 | 1997 Land Rover Discovery
Fuse that operates window, a/c , meters blows when driving
try and take not when it blows to what is on a/c or blows when using windows or straight away
can put head light globe into fuse location head light lights up bright when short is present so you can then locate problem
May 28, 2009 | 1994 Toyota Camry
Machine keeps blowing fuse
I suspect the heating water element has a fault,..close
Oct 20, 2007 | Smeg WDI12 Front Load Washer / Dryer
Smeg WDI12 Front Load Washer / Dryer Logo
59 people viewed this question
Top Smeg Washing Machines Experts
matt
matt
ray gallant
ray gallant
Tom Chichester
Are you a Smeg Washing Machine Expert? Answer questions, earn points and help others
