SOURCE: door locks problem with one door drivers door
dont blame the idiot,we all make stupid mistakes without thinking and iam no exception,remove door trim and oil the solonoid with a oil can not a silly sunday mechanic spray and let it soak in as its working but i think its just a bit sticky with wear and dirt ingress hence it locks but doesnt unlock which might need a bit more power,oil the whole lot lock and all
SOURCE: Central Locking not working
Hi Craig,
I'm running a E34 Tds Touring with a similar problem, my rear doors and tailgate have dropped of the central locking circuit.
I have been told it is the Central locking Module a large black box under the dash that is faulty, apparently a common problem.
Hope this points you in the right direction,
Please remember to rate my effort!
Paul 'W'
Onyer~EDson(:0) {#><U.K.
SOURCE: 2005 Toyota Sienna Sliding Door Won't Open
Have 2005 Sienna and its Driver side door was not openning. Cheap dealer fixed it himself in front of me. After opening the doors plastic assembly while sitting inside with a screw driver. Then he bent the clip towards left where the metal wire is connected. If you guys want to see what he did i would record a video and upload for you guys. Let me know at [email protected]
SOURCE: 2001 saab 9-5 electric door lock system does not function
Most likely you have a bad TWICE unit. it is located under the driver's seat, at a low point in the floor and often gets wet.
SOURCE: back door on drivers side locked wont open or
can you lift the lock knob up at all?? If you can lift it and the door stays locked, the linkage inside the door is broken.. if you can't lift it up, then the linkage is most likely seized... you'll need to remove the door panel to actually see it
