Question about Smeg WDI12 Front Load Washer / Dryer
Machine keeps blowing fuse
Has happened several times
sometimes ok for a while
sometimes blows straight away
    Champion:
  • 249 Answers
I suspect the heating water element has a fault,..close
Posted on Dec 19, 2007
Grinder does not work, keeps blowing fuses! Can I fix it?
You need to return it for repair or buy a new one.
Nov 24, 2015 | Saeco VIA Veneto Combi
I have a vn commodore wagon. Keeps blowing indicator fuses
sounds like an earth problem , check the witing to the indicators for wear , good connection etc , do this to all indicaters , if not experienced in auto electrics worth getting an mechanic , will save you time and money
Nov 08, 2014 | Cars & Trucks
Fuel pump fuse keeps blowing on my 95 Crown Vic
Using a smaller fuse should make the problem happen more often.
A mechanic would unplug the pump harness at the tank and check the circuit for high resistance or a short to ground.
If nothing is found in the harness, I would suspect the pump in the tank.
Jul 19, 2012 | Ford Crown Victoria Cars & Trucks
My fuse keeps blowing for my tail lights help
This would be an indication of a direct short to ground somewhere in the circuit...
Does this vehicle have a trailer harness?
has it been wrecked?
Jan 10, 2011 | 2005 Nissan Frontier
My oven light bulb keeps blowing on my Whirlpool oven.
becoz of some problem that might be your oven is on for long time
Apr 10, 2010 | Ovens
Hotpoint wma62 keeps blowing the fuse in plug started week ago would go couple times then blow another fuse now when i switch on blows it straight away
I assume that you have the correct amperage fuse fitted, and that the plug and socket are o/k.
I would start by unplugging the motor lead from the motor, if it still blows, remove the leads from the heater
.If it still blows, then it could any one of a number of things.
However, there is more than a good chance, it will be the heater or motor.
If it is the motor that has caused the problem then before you do anything about it, check the control module in the top of the washer,as there is a very strong possibility that it will have blown the board, I have come across this on many occasions.
This being the case, then it is not going to be economical to repair.
Hope this helps.
Dec 02, 2009 | Washing Machines
Fuse that operates window, a/c , meters blows when driving
try and take not when it blows to what is on a/c or blows when using windows or straight away
can put head light globe into fuse location head light lights up bright when short is present so you can then locate problem
May 28, 2009 | 1994 Toyota Camry
Jandy Aqualink RSO301 keeps blowing fuse
Great discovery! You're welcome.
Could you please take a few and rate my assistance.
thanks...
Charlie
May 26, 2009 | Jandy AQUALINK RS TELELINK KIT
Maytag washer blows 1.5A fuse in back of the top compartment where the dial etc is
There is a micro switch next to the fuse. It is shorted out. Replace the micro switch and solve your problem.
May 20, 2009 | Maytag SAV571EEWW Washer
Fuses
heating element may be faulty. Change it
Oct 20, 2007 | Smeg WDI12 Front Load Washer / Dryer
Smeg WDI12 Front Load Washer / Dryer Logo
168 people viewed this question
Top Smeg Washing Machines Experts
matt
matt
ray gallant
Are you a Smeg Washing Machine Expert? Answer questions, earn points and help others
