Question about Polaroid TDA-03211C 32 in. LCD HDTV
Need to learn to take capacitors off the circuit board
My polaroid tv broke today. after research i found that the capacitors may be the problem. I have to tv apart, i just do not know how to get the capacitors off.
  • Polaroid Master
  • 3,866 Answers
Very carefully as we discussed in our expert forums this takes skill and it takes the right equipment as you can burn the thrid layer board and you will be without a TV. First you need a 40 watt iron, 60/40 rson core solder/you need wicking wire/ heat sink and a whole lot of experience. check this website www.badcaps.com even know he works on motherboards for computers this guy gives you tips I would follow them and heed to them if I where you!! Good luck with your repair!
Posted on May 25, 2009
My Polaroid TV is about 3 y/o and it was on for 30 and just went pop and the screen turned black and the red light in the corner. Does this mean my TV's blew?
That pop was a "button" surface mounted circuit board capacitor blowing up, inspect the main board first and look for burn mark in the board.
Feb 21, 2017 | Polaroid Televison & Video
Polaroid tv doesn't turn on
I have the same problem with a 37" Polaroid LCD... through some thorough research i discovered that it is a possible 3 things;
1: Blown Capacitors on the power board; Look for domed heads on capicitors
2: A Faulty AV board; I'm unaware on how to test this at present!
3: Faulty T-Con Board; Disconnect the AC power cord from the TV.
Disconnect one end of the LVDS cable that goes between the main board,
and the timing controller (TCON) board.
Connect the AC power cord to the TV and press the power button.
If the screen lights up dimly, then you have a defective TCON board.
If the symptoms didn't change, then you have either a defective main board or
power board (you should get them both, replace them one-at-a-time,
and send back the one you don't need). There are tuition video's for t-con and capacitors replacement on youtube
Feb 26, 2013 | Polaroid TDA-03211C 32 in. LCD HDTV
How to fix blue screen problem on polaroid tla01511c
Hello!
If you do have only "blue screen" on your set, it could be caused by 2 separate issues: 1. if your TV glows blue, without "polaroid" logo at the start up, problem is t-con board(display controller).
2. if TV start up normally, with "polaroid" logo, then stays bright and blue, the issue is: multiple electrolytic capacitors failure throughout the signal board(s). Those might look "bloated" and normal, as well. Easy to find and replace "bloated", but to find other bad capacitors, you need to have a technical skills and in-circuit capacitor checker(ESR meter). Plus, good soldering equipment.
definitely, not a "diy" project. You may replace the board, where you find "bloated" capacitors, first and observe the change. It might take care. Usually, "blue screen" means: no signal from tuner. In case of separate tuner sub module, that the place to start.
Good luck,
Alex.
Jan 10, 2012 | Polaroid Televison & Video
Polaroid FLM 323b LCD sound but no picture. Changed out c32, c33, and c34 caps but it did not fix the problem. None of the other capacitors look bulged on the board. Any ideas where to go next?
Well, you need to find out if it is putting out the 24vdc for the backlights inverter board, if it does, then check to see if the 24vdc is at the inverter board, check the surface mounted fuses on the inverter board, check to see if it has BL_ON signal. One thing about bad caps, they can look normal and correct value but they can have high ESR which is bad for switching power supply circuits.
Service manuals, Polaroid: http://www.polaroidsupport.com
Learn how TV works here:
Basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: www.interliquidparts.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Oct 07, 2011 | Polaroid FLM-323B Television
I have a samsung ln40a550 LCD and had a problem with it , the TV wouldn't turn on. So i did some research and found out that samsung had some crappy capacitors, so i called them and they came and replaced...
I would think if SAMSUNG came out to replace the bad caps and the TV is still not working right, I would think they should fix it correctly, may be the person did not do the good quality jobs and left. What does SAMSUNG say about this? The bad power supply could have unstable DC and could have damaged the other boards inside the set. You will need to inspect the power supply yourself, look to see the soldering works are good and everythings are put back together correctly with correct polarity.
Then you need to verify all the DC output voltages before going any further, it will not be an easy job.
Learn more here;
Basic LCD monitor and TV troubleshooting guide:
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Replacement boards:
http://www.shopjimmy.com/catalogsearch/result/index/?q=Samsung+LN40A550&stock=all.
Dec 11, 2010 | Samsung LN40A550 LCD TV
I have a Polaroid 4011-TLXB and it won't turn on. I've read alot of people having this problem but mine is a little different. Most online articles I've read say that their tv turns on showing the blue...
U check the power supply board and it is good and power is on LED light power indication light up.Than only one possibility the tv Tuner signal board is shorted and dead.That the board,where the incomming broadcasting signal cable plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner signal board for the replacement.
Nov 18, 2010 | Polaroid 4011-TLXB LCD TV
I want to start repairing amps. how do i learn?
You will need to enroll into an electronics school to learn how to repair electronics on a component level.
Jun 21, 2009 | Rockford Fosgate Punch 401S Car Audio...
My Polaroid 32" LCD TV just stopped working after only 7 months!!
they use an inferior brand power board. the power board you will fined it has alot of capacitors that will need replacing. in worst case you will need a replacement power board. if you replace the capacitors use 105c types and not the same brand that are on the board these capacitors are like grade F capacitors, really cheap.
Jun 05, 2017 | Polaroid TDA-03211C 32 in. LCD HDTV
Polaroid 37"
Go to HERE for the solution to your problem.
I hope this helps.
If you have any questions, feel free to ask them.
Thank you for using Fix Ya!
Don't forget to rate the overall satisfaction of this solution.
Mar 02, 2009 | Televison & Video
Polaroid TDA-03211C 32 in. LCD HDTV Logo
327 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
