Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Ice maker not working right
The ice maker gets the water but won't dispense it. It has dispensed it only twice in almost 2 months. Its a whirlpool ED2VHG.
  • 1 more comment
  • dougiedoug66 May 25, 2009
    I am still not sure how to check it. I took the cover with 3 screws in it off and saw the thermostat. It looks like it has two pins coming from it. Do I need a meter to check it?
  • dougiedoug66 May 26, 2009
    Is there an adjustment screw on this ice maker that I can tweek so it works. I am just tryin to check everything out before I start checking continuity. And thatnks by the way for all the great advice. Doug
    That link won't work for some reason.
  • Whirlpool Master
  • 4,654 Answers
Your ice maker has a thermostat inside that tell the ice maker to cycle. If the thermostat id defective the ice maker will not cycle. below is a picture of the break down parts. You can visit the link below and place model number ED2VHGXMQ00 into the model search feature. If the thermostat is good the contacts on that part will be on or show continuity through the 2 contacts only when freezing. Let me know, If I can help you further, Sea breeze click on link below and go to the page showing your refrigerator. On left of screen click on photo 12. The part below in photo is # 27 Sometimes older models are less expensive to replace with a complete new ice maker. Let me know if I can help you further, Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
Posted on May 25, 2009
  • 4 more comments
  • John Tripp
    John Tripp May 26, 2009
    You will need a meter and a little knowledge on what to look for . The ice maker inside your refrigerator can be powered up and you could be shocked or damage other parts of your refrigerator. Tell me when someone can follow with me. If you are sure you can do this then unplug the refrigerator and while the meter is set for continuity then we need to check the thermostat for a open or closed circuit while frozen.
  • John Tripp
    When the thermostat shows a complete circuit through the two connections without one wire connected to it then it is good. But the thermostat tells the ice maker to cycle only when the thermostat is freezing. I realize this is a little complex to explain so if you want to give this a try I will be here to help you. Sea Breeze
  • John Tripp
    I also can send you a A Whilpool Gold Ice Maker Repair manual without charge if you like. appliancepartsse@yahoo.com
  • John Tripp
    Yes, there are screws that can be tweaked but this can make things much worse if not done properly.
  • John Tripp
    seabreezehvac at yahoo.com
    appliancepartsse at yahoo.com
  • John Tripp
    email me at appliancepartsse@yahoo.com copy and paste to your email and I will send you the manual in PDF format If you do not have Adobe go to adobe.com and download the free version of adobe9 you also can reach me at seabreezehvac@yahoo.com
GE GSH25JFRF BB ice maker doesn't dispense. Water dispenses and ice maker makes ice but won't come out.
There should be a plastice hinge cover on the left top hinge on freezer door. Take it off and press the plug together firmly. Try that and let me know, Sea Breeze
Aug 19, 2012 | GE Refrigerators
Whirlpool refrigerator water dispenser not working
hve u tried to clean any blockages in the unit.let me know wat other problem u face
Oct 23, 2008 | Whirlpool GS6NBEXR Side by Side...
Ice makers have a heating element to thaw the inlet and allow water to flow into them perhaps the heater is broken and it can't get water to make ice. Check the hopper to be sure it has ice in it. If it does check it for obstructions from the hopper to the door.
Apr 04, 2012 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a side by side with ice/water dispenser on the freezer side of the door. a couple of months ago the ice maker stopped working and just today the water stopped coming out the dispenser and none of...
1light not work , may lightbuld loose in the socket , or door switch
2 ice maker not work? may the ice maker arm shut-off. sut-off arm to be on(sure be down position)
3 is the ice maker switch in the off positio ( on some models)
4 is the freezer door not closed completely ? if it will not shut all the way,push the door firmly shut for the water dispenser poblem
5 check water filter. or water valve clogged or bad? replace them if necessary
good uck
Jan 11, 2011 | Whirlpool Refrigerators
Replace water inlet valve for ice dispenser with new. When icemaker cycles it dispenses through the water dispenser instead of tube going to ice maker. I have switch lines around but can only get water...
The ice maker is what tells the water control valve to open so it may be correct now and the thermostat in ice maker may be defective. Part 27 or 627985 down below where it says Whirlpool Ice Maker Parts Breakdown and in that photo is the ice maker thermostat. If your ice maker has been used for many years the complete ice maker may be better to replace. Ice maker Model=> 4317943
Or click here=>Point and Click Then enter model or part number into search feature. If you have questions please ask, Thanks, Sea Breeze
Whirlpool Model ED5GTFXKQ02 Ice Maker Parts Breakdown
Dec 17, 2010 | Whirlpool Refrigerators
NO ICE
Check this first,
Your dispenser can be turned off for easy cleaning or to prevent
unintentional dispensing by small children and pets.
NOTE: The lock feature does not shut off power to the product, to
the ice maker, or to the dispenser light. It simply deactivates the
ice and water dispensers. To turn off the ice maker, see “Ice
Maker & Storage Bin.”
 Press and hold LOCKOUT for 3 seconds to lock the
dispenser.
 Press and hold LOCKOUT a second time to unlock the dispenser.
Let me know if this helped, Sea Breeze
Mar 22, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker not getting water after changing filter
Check the following:
 Is the freezer door closed completely?
 Is the ice storage bin installed correctly?
 Is there ice in the storage bin?
 Has the ice frozen in the storage bin?
 Is ice stuck in the delivery chute?
 Has the wrong ice been added to the storage bin? Use only
cubes produced by the current ice maker.
 Has the ice melted around the auger (metal spiral) in the
ice bucket?
Dump the ice cubes and clean the ice storage
bin.
 Is the ice dispenser stalling while dispensing “crushed”
ice?
Change the ice button from “crushed” to “cubed.” If
cubed ice dispenses correctly, depress the button for
“crushed” ice and begin dispensing again.
 Has the dispenser arm been held in too long? Ice will stop
dispensing when the arm is held in too long. Wait 3 minutes
for dispenser motor to reset before using again.
The ON/OFF switch is located on the top right side of the freezer
compartment.
To turn the ice maker on, slide the control to the ON (left) position.
To manually turn the ice maker off, slide the control to the OFF
(right) position.
NOTE: Your ice maker has an automatic shutoff. The ice maker
sensors will automatically stop ice production, but the control will
remain in the ON (left) position
REMEMBER:
 Allow 24 hours to produce the first batch of ice. Discard the
first three batches of ice produced.
 The quality of your ice will be only as good as the quality of the
water supplied to your ice maker. Avoid connecting the ice
maker to a softened water supply. Water softener chemicals
(such as salt) can damage parts of the ice maker and lead to
poor quality ice. If a softened water supply cannot be avoided,
make sure the water softener is operating properly and is well
maintained
The Dispenser Lock (on some models)
dispenser levers. The ice and water dispensers will not work.
Style 1: Press the LOCK BUTTON to lock the dispenser. Press the
UNLOCK button to unlock the dispenser.
Style 2: Press and hold the LOCK OUT button to lock the
dispenser. Press and hold the LOCK OUT button a second time to
http://www.ajmadison.com/ajmadison/itemdocs/2261717.pdf
May 15, 2008 | Whirlpool GS5SHAXN Side by Side...
Ice maker stopped working
are the "fingers" of the icemaker pointed toward you and slightly up? if not the icemaker is internally broken . is the red light to the right blinking twice and then a one second pause? if not the emmitter is broken. is the black hose coming from the ceiling blocked with ice ? if so the water vave is broken allowing water to seep in hose and freeze. hope this helps.
Feb 08, 2008 | Whirlpool ED5SHAXM Side by Side...
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
193 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
