Question about Poulan/Weed Eater #Wt200 711724 24cc Gas Blower/Vac
How do I get the engine cover off of my gb1 22v weedeater so that
I can replace the gasline?
  • rparker0795 May 25, 2009
    It did not tell me how to install a new gas line?
  • 284 Answers
You have to take the one side off to access the fuel tank and lines
you will need a hex head wrench or allen wrench some would call and some patience and note that every hole has a hex head.
Even if you are mechanically inclined it is a pain as you need to know and watch how it comes apart and goes back is crucial to your and its success.
Hope this helps?
Posted on May 25, 2009
How do i adjust the carburetor on a husqvarna 18h hedge trimmer thanjs
you shouldnt need to,if it wont run right then your carb needs to be cleaned or gasline replaced,ethanol kills carbs and gaslines.
Apr 03, 2015 | Husqvarna Garden
Where can I find a manual for Redmax weedeater G20LS?
This OM covers starting and maintenance of the G20LS engine.
Redmax TR2350S with G20LS engine Owners Manual
And here is a site that has the parts look-up and the parts.
Redmax Parts Direct The internet best Redmax resource for parts
Mar 04, 2015 | Garden
Weedeater featherlite xt260
Small engine shop google that and good luck
May 30, 2014 | Garden
Gas is leaking, I think its the little plastic gasline thats cracked thats attached to the the gas tank itself, if so, where can I find a new replacement gasline to repair it?
All small engine repair shops carry the lines you need and you may even be able to pick up a fuel line "kit" complete with fuel filter and fuel lines at your Home Depot. They carry many parts and accesories for Ryobi and Homelite trimmers.
May 15, 2011 | Homelite Garden
We just bought an older house with a jenn air cook top but the pilots are out. How do we light them?
First, you need to look below the cooktop to find the gasline. There is supposed to be a shutoff valve on this gasline. Turn the handle so it is parallel with the gasline (perpendicular is closed) to open it. Before lighting anything, smell around high and low around the cooktop and make sure you do not smell any gas. You can also spray soapy water on all the gasline fittings to detect leaks by looking for bubbles that form. If all is safe, using a long butane lighter, light the pilots for the cooktop. There should be 1 pilot for every 2 burners. You will probably have to remove the grates and metal spill covers to light the pilots. The pilot should be approx 3/8" tall or less. Test each burner individually to make sure they light off the pilot. If they do not, you may need to clean the vertical holes on the side of the burner (where the lighting tunnel connects) by poking them clean with a needle. If the horizontal burner holes are clogged, clean them as well. If there is also a built-in wall gas oven, be sure to light that pilot on that as well. Good luck. Douglas
Sep 28, 2010 | Jenn-Air 36 in. CCGP2720P Gas Cooktop
Hi there! I have a used Poulan Weed Eater SV30 Barracuda 32cc Super Blower Mulching Vac w/ reconditioned engine; Engine Family TPW032UB24RA : EM and Serial No 96215N500274-1 I need an Owner's / Repair...
unbolt the cover and there is a pully under it,,,this pully holds the starter rope but its needs to be tenshond up first so it pulls the rope inside when let go,,,the rope is just knoted to the pully
also its a 20 to 1 petrol oil mix,,,for running it on,,,
Aug 21, 2010 | Poulan Garden
How to replace a craftsman weedeater gasline?
you hook one line to it the return line inside the tank
The line you used as a return line pull it back thru the gas cap hole and put that piece on one end of that line and pull it back in the tank until it stops and then hook the return line back where it belongs
May 14, 2010 | Craftsman Garden
Toro weed eater gasline problems
The bulb should have two fittings. When you depress the bulb, air should **** in on one fitting and air should be expelled out the other. You may have the line from the tank on the wrong fitting. Hope this helped and best wishes.
Jul 31, 2009 | Garden
Need gasline size
The best way to get the correct size lines is to take a piece of the old lines to your local outdoor power & equipment store, or sometimes your local auto parts store will carry them, and let them match them up. You may have two different size lines, so make sure to get pieces of both.
Jim
May 18, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Weedeater or trimmer
sounds like the carb is still not right or the unit is low on compression - you need 90 lbs min
Oct 12, 2008 | Garden
Poulan/Weed Eater #Wt200 711724 24cc Gas Blower/Vac Logo
132 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
