Question about Frigidaire FRS26R4A Side by Side Refrigerator
Leak under frigerator
Hi, my refrigerator is leaking underneath in the center. I thought it was the water supply line, but when I turned of the water and removed the line it still leaked, any ideas?
Brand:Frigidaire
Model# frs26r4cb1
  • 18 Answers
Leaking inside of fridge? your defrost drain is plugged and running from freezer into fridge around once a day....
Posted on May 25, 2009
Fridge leaks water on floor constantly
does it have an ice maker and or water dispensor? if so start by turning off the water supply, see if the leaking stops. if it stoped you may have a broken water line or the water level valve is leaking. if that isn't the issue check your seal around the door to make sure it isn't leaking in warm air. if that is ok you will need to look at the self defroster to make sure it isnt defrosting all of the time.
Jan 17, 2013 | Frigidaire Refrigerators
Water leaking from under Frigidaire fridge
Hello - There are many reason for this issue to occur, for example the refrigerator could have a crack in the defrost pan, a defrost drain line blockage, a leak from the water supply line for the dispenser or ice maker, but most cases water leaking inside and draining through the refrigerator cabinet. Try confirming that the vales are tightened. If the connection is still leaking, turn of the water supply line to the water valve and take the connection apart. You can try using Teflon tape when retightening the connection to ensure a good seal. If these suggestions prove to be ineffective contact a professional to move forward accurately.
Oct 02, 2012 | Frigidaire Refrigerators
Frigidaire professional series refrigerator leaking water under door
Hello - Typically when water is coming out from under the refrigerator there could possibly be a loose connection from the house water supply line to the water valve or a cracked drain pan (located underneath the refrigerator). Try confirming that the valve is tightened. If the connection is still leaking, turn off the water supply valve and take the connection apart. You can try using Teflon tape when retightening the connection to ensure a good seal. There could also be a loose water connection to the door. This connection is located on the bottom left of the freezer door.
Sep 25, 2012 | Frigidaire Professional Series PHS68EJSB...
Hi, I just found a leak in the back of the fridge from the green water line. Is it something I can fix easily or should I have an expert take a look?
If water appears to be leaking from the back of the refrigerator, check that the water line from the household water supply to the refrigerator is not damaged or cracked. Check all connections that are accessible such as the connection at the supply valve and the connection point of the supply tubing onto the back of the refrigerator. Check that the tubing is firmly inserted into all fittings and all fittings are tightened.
Saddle Valve Shutoff Valve
Leaking from under the door
On exterior dispenser models, if water appears to be leaking from under the refrigerator door, look and feel under the door to ensure the water connection to the dispenser is properly done. Firmly push the water tubes into the fitting.
NOTE: This connection was disconnected if the doors were removed during installation or if the door swing was reversed.
Leaking at the filter
Ensure that the filter is correctly installed.
Jul 02, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
I have water collecting on the bottome of my side by side refrigerator on the frigerator sided un the crisper.
Hello and Welcome to FixYa!
Actually the leaking water is from the evaporator coil unit....(it is located at the back wall or underneath the freezer compartment). Under normal conditions,Self-defrost refrigerators usually dispose the water generated during the defrost cycle through a tube or channel that directs the water a pan (Known as Drip pan), commonly below the refrigerator unit....
The channel or tube is clogged and the water is leaking to the refrigerator/freezer unit, so you need to clear that blockage/contamination....Once the blockage is removed, the generated water will move through that channel/tube directly to the drip pan and there will no water on the floor in the refrigerator/freezer compartment. This is all you need to do....
Best of Luck,
Your token of appreciation in form of rating would be highly obliged,
Concerned.
Sep 17, 2010 | Frigidaire FRS6R5EMB Side by Side...
Whirlpool gold refrigerator leaking under neath on the side
If its leaking all the time you could have a problem with the water supply line (if it has an icemaker)Or the solenoid valve (water valve) that opens to refill the icemaker after it drops (harvests) the ice.Or the plastic water lines that run from the valve up to the icemaker.You should pull the frig out from the wall and check the back for leaks.You could also Just shut off the water supply to the unit and see if it stops.These leeks cause a lot of damage when they go unnoticed for a long time.I would check it out asap.
Jun 03, 2010 | Whirlpool ET1MHKXM Top Freezer...
Water leaking from underneath right side of refrigerator. Shut off water line to ice maker and still slowly leaking. Where is this coming from?
check the defrost drain line and catch tray under the fridge. you may just have moved the hose out of the tray or the tray may be full.
or it could just be your water valve has a slow leak. try turning off the water farther back on the supply line.
Dec 12, 2009 | KitchenAid Superba KSRS27CN Side by Side...
WATER LEAKING FROM INSIDE BACK OF REFRIDGERATOR SAMSUNG 267LASH
The frigerator has a drip pan it may need to be empty. Check the water line for leaks going into freezer.
Apr 11, 2009 | Refrigerators
Water leaking from bottom of unit
check to see if if drip pan leaking may be water line
Apr 07, 2009 | Magic Chef CTF1826AR Top Freezer...
Drain pan leaking?
there is a drip pan located underneath you ref but most likely your prob is a plugged drain line coming from the freezer. when you ref goes into automatic def the water doesnt run out into the drip pan but instead onto your floor..
you can clean the drain line by removing the rear cover in the freezer compartment and using hot water to thaw the drain below the evap coil.
Dec 08, 2007 | KitchenAid Superba Architect KSCS25INSS...
Frigidaire FRS26R4A Side by Side Refrigerator Logo
325 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
