Question about Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with PuriClean II Ice and Water
Freezer works...the refrigerator side is warm...
My refrigerator is getting hot but the freezer is still working. I think that the support temp control is out and needs to be replaced. We can not take off the shield light to get to it. Can you help?
  • Maytag Master
  • 4,655 Answers
Could you send me the model number because Maytag is really good about help and assistance, Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
Posted on May 25, 2009
A kenmore side by side model 106 5661 2500 has warm refer and cold freezer
If the freezer temps are normal and the refrigerator is warmer than normal, the the air flow from freezer to refrigerator is being hampered either by ice on the evaporator or the freezer is stuff in such a way that normal airflow between freezer and fridge is hampered. If the auto defrost is not working properly you will have warmer freezer temps and a relatively warm refridge. Check the defrost timer and defrost heater element.
Nov 26, 2013 | Kenmore 56612 Side by Side Refrigerator
Freezer is running at a warm temp- cannot maintain a constant temp of -1. Refrigerator is fine and working properly. Anything I can do before calling a repair mn?
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 15, 2011 | Jenn-Air JS48SEFXDA Stainless Steel Side...
Freezer working but refridgerator at room temp. Door seal hot.
either the evaporator coil is iced up which means the defrost heater is bad,the defrost control is bad or the damper vent door which throttles cold air in isn't opening fully from the freezer to refrige,the evaporator fan isn't running or if electronically operated the main board behind the unit can be bad on these as this board controls all electrical issues
Jun 20, 2010 | KitchenAid 19.7 Cu. Ft. Side-By-Side...
16 month old GE Profile refrigerator with bottom freezer can no longer maintain freezer temp. With control set at zero degrees, freezer temp varies from twenty down to six degrees. Both sides of cabinet...
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Nov 25, 2008 | Pds GE Profile Energy Star 22.2 Cu. Ft....
Outside freezer is hot to the touch
Its normal, the heat is coming from the condenser which is integrated within the freezer cabinet and is completely out of sight.
Jul 10, 2008 | Kenmore 73262 / 73264 / 73269 Top Freezer...
Refridgerator was never that cool now its warm
put a thermometer in the refrigerator and one in the freezer to see what it reads each day when you had the freezer open it it coses it to work harder like having an air conditioner on with the window open it has to work harder to keep it cold so by recording them temp to see if its dropping or it stays the same you might have to get it looked at but for just getting it a week ago it should not have hurt anything just leaving it open a little bit might just be normal for it to be hot i have a side by side and the side is hot but not to hot just warm. let me know hope that helps
Jun 26, 2008 | Jenn-Air JCD2290HES Side by Side...
Admiral side by side
All the cold air from your freezer gets pushed into the fridge with a fan in your freezer section. So your problem is from the fact that this cold air isn't get to your fridge.
- the door that allows this cold air into the fridge, normally in the top left corner of the fridge, is stuck shut and needs replacement.
-the freezer isn't defrosting and restricting the air flow
-the temp controller for the fridge is damaged and thinks that the fridge is cold enough.
Nov 15, 2007 | Admiral 26 cu. ft. Side-By-Side...
Refrigerator warm, frost in freezer
take back panel off freezer and check for ice build up which will block air flow and temps will rise. melt off carefully with a hairdryer.make sure drain is also clear and use hot water and patience if blocked with ice. if fault re-occurs, you have a fault with defrost system
Apr 24, 2007 | Hotpoint 21.7 cu. ft. Side-by-Side...
Open Questions:
See all Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with Questions
Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with PuriClean II Ice and Water Logo
228 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
