Question about Frigidaire ATF6000ES Front Load Washer
I have Frigidaire Affinity washer that beeps and blinks "dr"
I have a Frigidaire Affinity front load washer model LTF6000FS0 that started a normal wash cycle then stopped. When it stopped washing it started to beep every couple of seconds and the display blinks "dr". The load of clothes inside was completely soaked.
I have tried disconnecting and reconnecting the power, thinking that it might reset something. However, a second or so after I try to restart the washer, it starts beeping and blinking "dr".
Thinking that maybe "dr" stood for door, I slammed the door and pounded on the closed door but nothing has changed.
Thinking that maybe "dr" stood for drain, I have taken the washing machine outside and disconnected the discharge hose from the pump. A lot of water flowed out, I did not find any junk in the water. The pump outlet has some kind of filter that seems to be built in. I stuck my finger in the discharge tube but I did not find any blockage. I reconnected the discharge hose and tried to restart the washer. I get the same beeps and "dr".
I disconnected the boot hose from the input side of the pump. A little water came out. I stuck my finger inside the pump inlet and inside the boot but I did not find any blockage. I reconnected the boot hose and tried to restart the washer. I get the same beeps and "dr".
My guess is that it could be the pump or maybe the door lock, but I am not sure.
Any ideas?
Thanks
Mark
  • 6,784 Answers
Hi. the "dr" represents a faulty door mechanism. you will need to replace this device asap.
Click here to purchase your new door mech.
Posted on May 24, 2009
Actually don't buy a new door mechanism yet. There is a metal ring that holds the rubber tub to the rest of the washing machine. It has a spring at the bottom of that ring. Pull it down and you will be able to get the ring off. Carefully peel back the rubber tub on the right had side near the door latch. Reach in side and unplug the bottom connector for a few seconds and plug back up. (Do this all with the power on). Then put the rubber tub back around the frame and put the metal ring back on. This should solve your problem. I had the same issue not too long ago.
Posted on Sep 06, 2009
Frigidaire Affinity ATF7000E DR error code
Good Morning Friend,
I understand you are receiving a "DR" error code on your Frigidaire Affinity washer, model ATF7000E. The "DR" error code is stating that there is a possible problem with the door. This could also be a possible false error code. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 30, 2014 | Frigidaire Affinity ATF7000E Front Load...
Affinity frigidare front load washer won't start. It beeps with message flashing (DR)
Hello zabbster - Typically the DR or DO error code indicates that the door switch is not closed. Make sure that the door lock is completely closed. If the door is closed, make sure the door latch is not broken. If the latch is broken, you may possibly need to replace the door lock switch.
Sep 25, 2012 | Frigidaire Affinity ATF7000E Front Load...
I have a front loader washer...it was in the middle of the cycle and starting beeping. The dr (door) signal is flashing. Cloths are wet and i can't get any cycle to go now. Any suggestions?
Unplug your machine.
Open the top of the machine.
Open door
Remove the door lock assembly
Check contacts of the door switch.
Replace if faulty or try to clean with electronics cleaning solvent.
Jun 23, 2010 | Frigidaire Affinity ATF6000F Front Load...
Says "dr", will not start
The error clearly indicates bad door switch. Very simple to fix, have to take top off and loosen switch from front panel. Remove and replace.
Part #131763245 and suggested retail price $50.
Thank you
Jun 14, 2010 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
My washer stops half way through the cycle and blinks????Frigidaire affinity front load washer for some reason just stop halfway through the cycle sometimes.
Take note if the drain pump is operating. If it stops halfway, it must be stopping for a problem that has arisn, Normally, the water is not being pumped out.
Jun 13, 2010 | Frigidaire Affinity ATF7000E Front Load...
Error Code "dr"
Dr means door problem, either some clothes is keeping it from shutting or the door switch is bad 1ff09a4.png
Mar 05, 2010 | Frigidaire Affinity ATF7000ES Front Load...
Frigidaire affinity front load washer doesn't start
mabye there is something keepin the door open, thats usually why most washers dont start
May 11, 2009 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
Error messege, front loader wont start.
my name is joyce
first try the simple step, unplug unit for 60 secounds, then replug unit back up. reset load and see if that works. let me know if I can be of further assistance.
joyce
Feb 05, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Affinity/dr error
dr code means door not closed
get some crc spray and spray into lock on machine
that will lube the workings and should fix problem
Mar 13, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
1,166 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
