Question about Porter Cable PCH3200 Commercial Pressure Washer
Water pressure fluctuations
I don't have the same pressure at my house as I did at my mother's house. I have city water and she has well water, would this make a difference?
Would it make a difference if the hose is hooked up in the front of the house or the back? Should it be hooked up closest to the hook-up from the street?
  • kmazz88 May 24, 2009
    Any suggestions?
  • 1,889 Answers
Yes, yes and, yes
Posted on May 24, 2009
  • Jim Goldsmith
    Jim Goldsmith May 24, 2009
    not really; your pump is only able to increase the pressured water it receives you could buy a bigger pump motor I suppose...
How do I increase the pressure on my Flotec FP711OT-08. It is low 40s psi, can I move it up to 50 psi or high 50 psi? Water pressure throughout the house is low.
There may be a pressure setting on your outfit but My feeling is -- your problem will be low pressure on your water line. Most pressure settings is to keep from having too much pressure on what your running. For instance our city water pressure is 70 lbs but in order to keep my furnace boiler system at 16 lbs I have to install a pressure reducer.
Nov 23, 2014 | Pentair Flotec Fp7110t-08 Water Tank...
How much pressure should you have in the pressure tank itself.
That depends. City water? Shared well? Personal well? If you have your own well, it's pretty common to maintain about 50psi at the tank. City water may go to 100psi or higher, which is why many people have a pressure regulator installed to prevent it from going above about 65psi. I don't like to see anything above 65psi in a two-story house, or 50psi in a one-story house (it takes extra pressure to lift water higher); that's plenty of pressure to do everything you need to do, and not enough to blast the skin off your cheeks when you take a shower.
Jul 03, 2014 | Plumbing
Water temperature fluctuates with tankless
Have you ever tried to pump water for a fountain... It is so tough and you need larger and larger pumps to get it to go 7 feet high to let's say 10 feet high. Having the on demand water heater in the attic dramatically drops it's pressure. It's best to feed it with a 1 inch or at least 3/4 inch pipe downstairs before it splits the hot and the cold to get the best pressure everywhere then the least pressure will be when it reaches the 2nd floor. but the heater won't cut out because the pressure it even greater downstairs.
Nov 30, 2013 | Rinnai Water Heaters
All double faucets in our house run hot cold hot. Single faucets are fine. Problem?
Do you have a well and/or, do you have an expansion tank installed in the system. Alot of homes, almost all with wells and, alot now with city water, install expansion(pressurized) tanks in the line to prevent surges in pressure and temperature fluctuations. The tank would either be outside by the pump or, could be installed on or near the water heater. If these tanks go bad or, if they lose pressure, they can't provide the cushion to prevent this from happening. Also when they go bad they will become saturated with water and adding pressure to the tank may lessen the problem but, again, it can't provide the cushion.
Jun 12, 2011 | Home
What is the required water psi for residental home use?
Most states only require that the locality only provide you 10 psi at meter and that's just plain wrong because at 10 psi it will not even provide enough pressure to take water to shower head.Most house have about 50 psi you can not have above 70 psi or it will cause a lot of problems you have to install a pressure reducing valve for high pressure for too little of pressure you may have to install a pressure booster pump,which is around 500.00 plus installation.If city not providing enough psi contact pubic works officials tell them if you don't get you more pressure you will install booster system and that will **** their lines dry and cause all the neighborhood to be calling about no water,thats what I did and had engineers and workers provided me with 55 psi at my meter.
Jun 05, 2011 | Moen Plumbing
Hot water tank does not work when shower is on, it does however work when the faucet in bathroom is on. It quit working in the shower about a month ago.
  1. COLD MIX, HEATER DEACTIVATES
    If inlet water temperature is over 70°F due to geographic location, water maybe very hot out of the tap. This requires a lot of cold water to be added with it in order to attain a useable hot water temperature. The addition of too much cold water will overpower hot water demand from the tankless water heater. This slows the flow within the tankless water heater, decreasing it below activation point, which shuts off the heater. The end result is nothing but cold water coming out of the outlet. See: TWH E2-04 Overcoming fluctuating temperatures [PDF].
  2. FLUCTUATING WATER PRESSURE
    If the water pressure in the home is erratic and the water flow is not consistent while a tap is opened, then the temperature of hot water will fluctuate. The minimum water pressure for the home should be 30psi or greater. For people on well systems the minimum pressure range is 30-50psi. The use of a pressure reducing/regulating valve is an effective way to maintain constant water pressure to the water heater. Watts brand 25AUB- ¾" or N35B-¾" pressure reducing/regulating valves or equivalent is suggested.
  3. CHANGING FLOW RATE
    Major changes in flow rate can adversely affect the output water temperature of the heater. Increases from one major fixture running to multiple fixtures running at one time can cause the temperature to fluctuate. Stay within the heater's specifications. See: TWH E2-03 Outlet temperature vs. flow rate [PDF].
From the Bosch website.
Good Luck,
Gary
Dec 16, 2010 | Bosch PowerStar AE125 AE125 Whole House...
When i move shower valve to hot, the water pressure drops. There is more cold water than hot. I have changed my moen valve before and this still happens. Good water any where else in the house including...
probably have a kink on how water line feeding valve..if possible to cut drywall bhind tub valve and inspect pipe at bottom plate...moen faucets are equipped w/ anti scald device, pressure balanced (newer models) and this could cause cold water to overwhelm hot water...
Nov 20, 2010 | Moen 3175 Legend One Handle Shower Faucet...
My shower goes from warm to scalding and then to cold without any adjustment to the controls...is this a hard water problem? is this a common problem? my faucets were installed 1 year ago.
No it more then likely is because of fluctuating pressures...this could be because of other water usage in the house or even in the water entering the house...to see hwat it is the water pressure would need to be monitored at different locations to find the source of the problem...likely if it happens when somewhen else in the house flushes a toilet then you know where it is...
heatman101
Aug 04, 2010 | Delta & Single Handle Shower Faucet
Lost water pressure on house
it is normal to loose pressure from the filter it must have very small holes in it for the water to pass threw so it can trap dirt and particales from both well and city water. it is normal for it to cut back on pressure, it will cut back more and more as it catches the things that you are filtering out. what you might want to do is filter your drinking water only, under your sink .dont try shower and outside faucets. and you wont have to replace it as often. well good luck and good day to you... sawdust46
Jul 03, 2009 | House Brand Aqua-Pure AP102T Whole House...
Porter Cable PCH3200 Commercial Pressure Washer Logo
171 people viewed this question
Top Porter Cable Garden Experts
Jim Goldsmith
Jim Goldsmith
Are you a Porter Cable Garden Expert? Answer questions, earn points and help others
