Replacing electrical cable on Air conditioner
Have an air conditioner and needed to replace the electrical cable. Well a week later and got the part and the person that took the conditioner apart has forgotten how to put it back together. So, now I have two plugs that need to attach to the compasitor and there is four plugs to choose from. I hope someone can help me, I don't know and had I taken it apart I would have made a note to know.
  • Anonymous May 25, 2009
    Thank you for trying to help me, I am going to attempt to figure it out on my own, but do thank you for making an effort.
  • Ned C Cook
    Ned C Cook May 11, 2010
    do you have a phone camera? if so, take a picture of the connection points and send them to 9096303192
  • 46 Answers
There sre clearly 2 sides on top of the compasitor one wire to apost on 1 side and 1 wire to a post on the other post sides are seperated by a L shape one of them of coarse would b a backwards L those are your 2 sides
Posted on May 25, 2009
AC button on 1996 Honda Passport doesn't come on?
I think it's coincidental; I think the air conditioning fuse or circuit breaker has blown. Check the fusebox - this fuse should be labeled "AC" or "A/C".
Aug 01, 2014 | 1996 Honda Passport
Duo therm rv air conditioner fan wont spin
If the motor gets real hot you should be able to have it removed and tested---better to replace if bad than rebuild in most cases.
Jun 16, 2012 | Heating & Cooling
Air conditioning is not engaging when button is pushed to turn on.
Air Conditioner No air coming from air conditioning vents
  1. Check the air conditioner fuse and replace as necessary.
  2. Air conditioner system discharged. Have the system evacuated, charged and leak tested by an MVAC certified technician, utilizing approved recovery/recycling equipment. Repair as necessary.
  3. Air conditioner low pressure switch defective. Replace switch.
  4. Air conditioner fan resistor pack defective. Replace resistor pack.
  5. Loose connection, broken wiring or defective air conditioner relay in air conditioning electrical circuit. Repair wiring or replace relay as necessary.
May 31, 2011 | 2007 Buick Terraza CXL Wagon
MSZ-A26YV only blows air now, (no heating or cooling), no error indication. Worked all fine one day then few days later stopped. Emergency switch does the same. Looks like the external unit fails to pump...
try to check your compressor if working if not check electrical parts like capacitor. overload if defect replace. also try if compressor working observe the condensing unit fan blowing hot air if not theres possibilities of leakage of refrigerant gas need for braze leak then recharge refigerant gas. or possible compressor loose compression need for replacement.
Feb 12, 2011 | Mitsubishi Heating & Cooling
Hi, I have Gold start R5050 Air Conditioner. Recently when moving it, the power supply cable got damaged. Can you sugget me the compatible cable (I have no knowledge about the Amp/Volt etc). If I wish to...
your problem is cable try insulate with electrical tape the damage portion of your aircon cord if you want to replace cable please state how much horse power and voltage use.
Feb 06, 2011 | Goldstar R5050 Air Conditioner
Air Conditioner shut down.
Set your thermostat to "ON". If the system continues to shut off and resumes later then you have an electrical failure within the unit or its just cluttered with junk. Check through the vent holes visually for debri. If there is enough to cause concern, remove the nuts holding the grill above the fan once you have flipped the breaker for the unit. (you definately dont want that thing kicking on with your arm inside)
if the unit stays on then you have a bad thermostat.
also pay attention to the temp of the exterior unit, if it gets too hot to touch then that is a sign of an electrical component failure and needs to be diagnosed through more troubleshooting
GOOD LUCK AND PLS RATE THIS POST!!!!!
Jun 03, 2010 | Goodman CLQ36AR49 Air Conditioner
AC wont turn on after replacing 3 amp
My guess would be that your cable installer drilled into or nailed into an electric supply to your AC. I'd suggest calling the cable company (groan,......) (30 minutes later,.....)
Oh hello,.....
To tell them what happened and see if they would like to contact a repair person of their choice, or if they want you to forward the paid invoice for them to re-imburse you. Good luck.
Jul 06, 2009 | Heating & Cooling
We got an a/c central unit goodman modle ckl60-1 and a month a go it broke and the technician said that it needed a new capacitor and freon and about a week ago the unit broke again and the technician said...
When a compressor is has to start. 1. HAs it been off longer than five minutes. As a service tech when I run on to this problem I install a hard start kit and a time delay. The start kit helps the compressor to start under heavy load condtions. The timer helps the compressor to balance out before tryng to start. Have tech set at 5 minutes. I install hard start kits and time delays on all my change outs. Replace problem will go away. Thanks Rus
Jun 15, 2009 | Goodman CKL60AR60 Air Conditioner
Heating & Cooling Logo
103 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
