Question about Acer TravelMate 4200 Notebook
Power Problems My battery light flashes when the adaptor is plugged in, says I have few minutes left of power. The laptop is then shut down, take out the power lead, plug it back in and then its ok, but then it happens again. Am not sure whether it is the battery or the power lead, I also have another Travelmate 4200, which has no problems
  • stargirl1304 Oct 23, 2007
    I have swapped the battery on the laptop with my other one and it now does it on that one, so its the battery, thanks al ot for getting back to me, its still under warranty so i'll contact the manufacturer.
  • silvereco2 Nov 26, 2008
    I also Have The same problem with my acer. I bought it almost 3 years ago its an Acer Travelmate 4200 and it started giving me trouble about a year in. The powrcable and battery are fine. I just bought a new battery for it but the problem keeps continuing. I spent almost $2000 on this laptop and since have had to repair it almost 20 times!!!!. I really hate Acer becuse they have no warrenty or limited warrenty. Acer is the worst and the Travelmate 4200 is the worst of the worst!!
    Uploaded 30 video answers.
    Uploaded 5 video answers.
  • 72 Answers
If the problem is the power pin it's from jerking and pulling on too much. Here's an interesting video about a way to keep the problem from happening. . .
Posted on Mar 04, 2008
  • 90 Answers
Quick check, remove the battery all together.
Plug the laptop into the wall with the adapter, power on, wiggle the connector at the laptop and see if the notebooks shuts off. You are checking to see if there is a short at the DC Jack. If the notebook runs without shutting off instantly, then it's not the power connection. Let me know what you find from there.
Posted on Oct 23, 2007
Hello. I have a lenovo n500. The battery died after i unplugged the adaptor for a few minutes. I plugged the adaptor back in blue light on adaptor and blue light on laptop are on- no power up. I have tried...
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods. When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Jan 28, 2013 | Computers & Internet
The button is on and the lock 9 is on and flashing and the screen is black. It was working fine. I opened the laptop and my screen is black. The A in the lock is blue and the icon next to it. The power...
Hold the power button for 5 seconds or more - does it turn off properly? If so, can you turn it back on afterwards?
Take out the battery and unplug the power adaptor. Let it sit for a few minutes. Now try the power adaptor alone. If this works, try shutting down and running on battery again.
Apr 18, 2010 | Dell Vostro 1510 Laptop
I have a HP dv7 laptop it does not work with the ac adapter but worked with the battery, whenever it is working with the battery and the ac adapter is connected it shuts down.
Remove the battery and plug the ac adaptor in check wethere the light on the port where you connect the ac adaptor glows or not, if no then check the wethere the ac adaptor is getting warm or not after you plug it in for few minutes if not then ac adaptor has to be replaced.
If the light on the port is glowing then it is likely that the power supply of the notebook has gone bad as it is not able to switch to ac adaptor or the port where you connect the ac adaptor to the notebook has a short circut when the acadaptor pin is connected , better try with a different ac adaptor to be sure wethere the issue is with ac adaptor or the notebook.
My best wishes
Mar 19, 2010 | HP Pavilion dv7-1130us laptop
Gateway M-6862 laptop will not turn on; battery light flashing re
Seems to be a problem of not enough power.
First check the voltage output of the charger(adapter) and match it with its specs.
Also try to reset the hardware using the following steps:
1 Disconnect battery and the charger
2 Let it sit for 1-2 minutes.
3 Press and hold down the power button for 30 seconds.
4 Reconnect battery and charger and try to start by pressing the power button.
Mar 07, 2010 | Gateway Computers & Internet
Plug in battery, power light and fan noise cycles on and off
I think it probably went into hibernate. Remove the battery while unplugged from the a/c adaptor for a few minutes. Plug it into the a/c adaptor, and see if it will boot up.
Mar 19, 2009 | Gateway 4535GZ Notebook
Dell inspiron b130 power problem
try running with battery out it should still work as long as it is pluged to a/c
Feb 18, 2009 | Dell Inspiron B130 Notebook
Nc6320 Laptop power
hello the first thing to make sure of is that the ac adaptor cable is not having any partial contacts ofany kind whereby power gets into the laptop irregularly.this could have adverse effect on the circuitry. it is not enough just checking the output of the ac adapter by a meter.try straighten the cable from the adapter and check the meter for voltage fluctuations. if the above is okay then the problem could be on board leve.
Aug 10, 2007 | HP Compaq nc6320 Notebook
Sanyo camera shuts down and won't power up
I connected my Sanyo VPC - 603 digital camera to an AC/DC adaptor due to battery malfunctions. After about 5 seconds, i heard a spark sound and the camera went off. What might have gone wrong? How can it be repaired?
Apr 10, 2007 | Sanyo Xacti DSC-S4 / VPC-S4 Digital Camera
Acer TravelMate 4200 Notebook Logo
107 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
