"warning you must plug in magicjack"
When i plug in my magicjack into the usb it says that "warning you must plug in magicjack".
it worked fine before but i don't know whats wrong now.
    Sergeant:
    Champion:
  • 212 Answers
Check the connections. Get ahold of magic jack you may have to format your magic jack
Posted on May 24, 2009
Hey everyone! I searched for answers all day for this because I had the same problem. I Googled the warning and found several answers from this site from last year. I tried all of them so I am not sure which one actually did the trick so here are the 3 I tried.
Please unplug your magicJack. Now go to "Start" in Windows and click on "run". In there write regedit and press enter.
Now click on + sign next to HKEY_LOCAL MACHINE.
Click on + sign next to SYSTEM.
Click on + sign next to CurrentControlSet.
Click on + sign next to Enum.
Now find the folder called USB. Right click on that and click on "Permissions". In permissions click on the check mark called "Allow" to the right of "Full Control". Click Ok.
Now click on + sign next to USB and then find the two folders called "Vid1307", right click on one at a time and select delete. (if there is no "Vid1307" is not available don't worry it will be deleted anyway).
Now click on - Sign next to USB.
Right click on Folder called USBSTOR and allow permissions.
Now click on + sign next to USBSTOR.
Find the folders called "CdRom&Ven_YMAX&Prod_MagicJack&Rev"and "Disk&Ven_YMAX&Prod_MagicJack&Rev".
Right click on those one at a time and delete them.
If you can't delete those folders, right click on it and and click on "Permissions". In permissions click on the check mark called "Allow" to the right of "Full Control"
Now exit Regedit and then plug your magicJack in.
I posted this on another post but want to spread it as much as possible. I spent 2 days of frustration with this item then solved this issue by the following:
1. Start
2. Right click My Computer then select properties
3. Select Hardware then Device Manager
4. Click + DVD/CD ROM Drives
5. Right Click Tiger Jet CD-ROM USB Drive then Uninstall
6. Unplug Magic Jack and wait 15 seconds
7. Plug Magic Jack back in
8. Wait for devices to re-install, MJ may start here, if not...
9. Click Magic Jack Icon and program should start
http://xomba.com/fix_magicjack
Good luck and don't throw your MJ away like I almost did!
Posted on Jun 11, 2009
  • kandis74 Jun 11, 2009
    After I did the xomba one I rebooted my computer and the user and password page came up. Hope this helps you.
I can call out on my Majic Jack Plus but cannot receive calls. The majic Jack is registered and set up on my modem.
This could be failure of the power adapter module.
Is your Magicjack plugged into the wall power thru a power adapter? Try bypassing the power adapter and plugging the magicjack directly into a USB port on your computer. If the magicjack work correctly now, then you have a bad power adapter module.
I had a similar problem. My Magicjack was plugged into a wall socket. First the dial tone became inconsistent, then I could no longer receive calls, then it died completely.
I plugged the MJ into a USB socket on my computer, and it then worked normally.
If you have a failing power adatper, it will continue to deteriorate, and it will eventually fail completely. The blue power on the magicjack will not come on when it is plugged into the power adapter, but it will illuminate when plugged into the USB socket on the computer.
Note: the computer must be on to power the magicjack thru the USB port.
Magicjack is aware of the problem and offers a replacement power adapter module. To contact them, go to www.magicjack.com and go to "support". They will ship you a new power module for about $5.50. Some people have reported that the replacement modules from Magicjack are no better than the originals and have had repeat failures.
Consider getting a power module from another source. There are lots of AC to USB power converter modules available on Ebay for only a few dollars. Search Ebay for "magicjack power adapter".
Oct 05, 2014 | magicJack Two, 2 Magic Jack Plus Voip...
My phone doesn't ring. The call goes directly to my computer and I don't know someone is calling.
Is your Magicjack plugged into the wall power thru a power adapter? Try bypassing the power adapter and plugging the magicjack directly into a USB port on your computer. If the magicjack work correctly now, then you have a bad power module.
I had a similar problem. My Magicjack was plugged into a wall socket. First the dial tone became inconsistent, then I could no longer make calls out, then it died completely.
Oct 01, 2014 | magicJack pc to phone, free local & long...
My Majic Jack Plus is not working ,the light is not coming on.
,M MK,MVCOKJKVCJIIJCVXIJIHJVLLLFLMPFKKKKFHJUGDKKHDFSUHGHTCSDGFYFTYTASDFSD HFYVSDFYGVASD SDYYSDYTF ASAVYSJUUASTFSDISDJJDHSHYUSDYGBSDYGUJKSDFIHDFSHSDYCAS6FTBB BASDUGTTSDFYG7SDBB DFUSDGVGGSD7FUIYUASVBB SDUTASDYFSDTYASDFYXSUSDFGFODFGSDGASDFSDFUSD
Dec 14, 2013 | magicJack Two, 2 Magic Jack Plus Voip...
XP laptop no longer recognizes any USB speakers, and internal speakers dont work. USB speakers do not appear in the audio controls. the only 'device' listed under Sound Playback is SoundMax Digital Audio,...
Nothing wrong with your USB ports. MagicJack has changed your audio and driver settings so it can use the sound system for phone calls. The changes exist whether the Jack device in plugged in or not.
You can confirm the problem by uninstalling MagicJack and reinstalling your sound drivers. Should fix the problem.
You'll probably need to contact the maker of the MagicJack device for a workaround. Might be something specific to your laptop/operating system.
Nov 13, 2009 | Toshiba Satellite M45-S2653 Notebook
Warning u must plug magicJack in usb
Courtesy of the MagicJack website, try these steps located here to resolve the problem:
http://www.magicjacksupport.com/warning-you-must-plug-magicjack-into-usb-t3208.html
Its the first message that is closest to the top of the page that gives you the instructions.
Feb 09, 2009 | Acer Aspire 3680 Laptop
Warning: YOu must Plug Magicjack into USB
This link fixed my PLUG magicjack IN USB problem: (tried all the other links mentioned in the forums and this is the only one that worked)
http://upgrades.magicjack.com/upgrade/upgrade.exe
Dec 13, 2008 | Computers & Internet
Warning message being displayed when magicjack is plugged
My Magic Jack was working fine. One day I got some viruses in my computer and I ran setup CD.After that magic jack is not working, it always display "Warning you must plug magic jack into usb".
I tried to chat with tech persons so many times and tried many methods but when they say "now unplug and plug in" , then magic jack home page opened on chating window (always) and stopped chating.
and still I'm getting same 'warning' message.
Oct 23, 2008 | Computers & Internet
Warning you must plug magicjack into usb
I was receiving "You must plug magic jack into usb" error
This is the fix that worked:
please download and Run the remover :
http://upgrades.talk4free.com/tools/mjRemover.exe
after you have done that , download the MS Fix http://go.microsoft.com/?linkid=9645377
then Run the UPGRADE http://upgrades.magicjack.com/upgrade/upgrade.exe
Oct 08, 2008 | Lands Phones
Magicjack phone is not working
i had unpluged and plug it back in and now it dont work
Oct 05, 2008 | Lands Phones
Computers & Internet Logo
826 people viewed this question
David Payne
David Payne
