Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Throttle doesn't work properly
Craftsman 17hp I removed the carburetor (not the linkage), and now it appears tne throttle doesn't work properly (seems like it is reversed). I did not touch the governor control lever or throttle cable. In addition, initial start of the engine takes approximately 15-20 seconds of cranking before starting. Any suggestions? Also, does anyone know where to find a detailed diagram showing where the choke and governor links hook into as well as the governor spring?
  • dselheimer May 25, 2009
    I found the manual, but diagram only illustrates parts, not how they are to look when assembled and connected. Any other suggestions?
  • 284 Answers
Try sears.com go to parts and enter your mod# from under your seat IE:358. and so on.
Look around for prompts and info for you mower from your entered mod#
Posted on May 25, 2009
Ryobi weedeater throttle not working
Check the throttle cable connection at the carburetor throttle linkage, it (cable) may be broken or the carburetor linkage is broke.
Jul 09, 2016 | Ryobi Garden
Briggs and Stratton 17HP Intek Governer Overspeeds
Can you Regulate the Engine Speed Using the Governor Arm? If Yes, then Reset the Governor. **To Reset the Governor; Loosen the Governor Arm Bolt and Turn the Governor Shaft Clockwise Until it Stops. Using the Governor Arm Hold the Carburetor to Full Throttle. Now with the Shaft Full Clockwise and the Governor Arm and Carburetor Held at Full Throttle, Tighten the Governor Arm Bolt. If the Engine Still Runs Full Throttle, then Reverse the Rotation of the Governor Shaft, but Still Hold the Carburetor at Full Throttle with the Governor Arm. If it Still Runs at Full Throttle, then Check the Internal Governor.** If you Can Not Regulate the Engine Speed Using the Governor Control Arm, then Check the Carburetor Throttle Valve. If the Throttle Control Valve (sometimes called a Flap or Plate) Mounting Screws Came Out of the Control Valve, then you will have No Control Over the Engine Speed. Send me the Model and Type or Spec Numbers Off the Engine, Please. With these I can Locate the Proper Manual and Better Assist you. **The Throttle Cable Attaches to the Throttle Control Bracket. The Cable Moves a Slide that Moves a Pivot. The Pivot has the Spring Attached to it and to the Governor Arm. The Solid Link Connects to the Governor Arm and goes to the Throttle Shaft on the Carburetor. When the Throttle Cable is Moved it Moves the Pivot and the Pivot Pulls the Spring. The Spring Pulls the Governor Arm and the Governor Arm Moves the Throttle Shaft. Usually the Spring is in the Lower Hole in the Governor Arm and the Solid Link is in the Top Hole of the Governor Arm.** If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance. Hope this Helps. Let me Know What Happens
Sep 23, 2008 | Garden
Do anyone have a drawing for the throttle to carburetor linkage on a Craftsman 358.797931 leaf blower?
http://www.searspartsdirect.com/model-part/358797931/0247/1503120/p9040031/00001.html
This is the only picture I could find of the breakdown of your machine showing the throttle linkage. You can zoom in on it, but its still hard to make out. I hope this is of some help.
Apr 08, 2016 | Craftsman Garden
17hp kawasaki idels fine but when you throttle up it runs wide open just put governor in
Eric, the one thing I can think of is that either your linkages are incorrect, by that I mean it sounds as if then you throttle it up, it gets stuck open... I would go over the carburetor set up and make sure that everything is correctly back in its right order.. you may also have the governor set too high, adjust it lower if it sounds as though the engine is working too hard or screaming.
Oct 05, 2015 | kawasaki Garden
Craftman model 917.271920 run at high speed at the time.even with the throttle in idle position
If a cable operated throttle the far end of the cable may have broken or come off. Linkage between throttle cable and carburetor bent/broken/
missing, spring broken/missing. Shouldn't be too serious.
Apr 15, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Snowblower c950 52361 throttle will not change out of idle
Sounds like snow blower has been sitting since last season. Remove carburetor shield and move throttle linkage at top of carburetor. They some times seize or tighten up from sitting.Spray with WD-40 or something to lubricate.
Feb 22, 2014 | Craftsman Snow Blower / Snowblower Bottom...
Throttle going wide open in 1st gear and staying there for about 5 sec
sound like throttle cable could be binding the cable clip broken or missing or throttle body linkage and plate has carbon build up.throttle body need taken off remove all plastic parts and rubber parts remove all electrical parts like idle air control valve and remove tps sensor the carburetor cleaner will destroy.clean throttle plate and throttle shift linkages spray clean real good remove all carbon build up.
Jun 21, 2013 | 1995 Toyota Camry
Toro rider 16-38 HXL when I start it revs at FULL speed and sounds like it will blow up. I slow it down with choke all other linkage seems to be in place properly- Is there a trick to fixing?
Three options:
1. The carburetor throttle plate (closest to the engine is stuck); clean it with gumout and work it back and forth
2. the linkage is hooked in the wrong hole ; check the wear pattern on the throttle shaft plate to see if it is in the wrong hole.
3. The govenor arm or gear is not adjusted properly; loosten the govenor arm, push the throttle plate of the carburetor all the way closed. push the govenor arm the same direction all the way until it bottoms out. tighten the arm clamp. Test again
I recommend getting a manual or at least a free parts diagram from a local shop like www.arcolawn.com
Good luck
Joe
please vote me up if the fix was good.
Dec 29, 2010 | Toro Lawn Mower With Toro Power Tools
Craftsman 22hp 7500 zero turn mower 3years old.
Be careful - running ungoverned will quickly destroy the engine. Look at the carburetor throttle lever. There should be two linkages attached -- one from the manual throttle lever, another from the governor. The linkage to the governor is usually a spring. Perhaps that came off or broke, or a foreign object is wedged in there.
Jul 15, 2010 | Craftsman 20 hp 42 in. Deck Yard Tractor
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
657 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
