Problematic recognition of memory
Dear Sir,
Recently I decided to build a brand new system for a friend. I bought a DFI LANPARTY JR 790GX-M2RS motherboard and 2 dimms of memory of KINGSTON KHX6400D2LLK2/2G HYPERX 2GB, which according to Kingston's site (http://www.kingston.com/HyperX/products/khx_ddr2.asp) is 2GB 800MHz DDR2 Non-ECC
Low-Latency CL4 (kit of 2), 4-4-4-12, 2.0V. I also used Windows 7 as my operating system.
The problem is that the memories are being recognized as DDR2 PC5300 at 333Mhz, after checking with CPUid, Lavalys Everest and SIW and even though I have tried manually to force bios to acknowledge the dimms as such, Windows refuse to recognize them as PC6400 of 800Mhz. Should I feel ok nevertheless, thinking that the software might be the problem after all?
The BIOS Manual is here: http://img.lanparty.tw/Upload/CatalogElement/JR790GXBIOS.pdf
I am already grateful for any advise, help you can offer me.
Antonis
  • incense_77 May 24, 2009
    First of all I have to say that I'm astonished by the fast response. Thank you very much for taking the trouble to participate.
    It would be a bit of a problem to try another OS at this point. My friend already utilizes the system and made the necessary software arrangements for his work. regardless the memory issue.
    I would be grateful if you could take a better look at the 2nd and 3rd page of the .pdf manual I provided you with and make some suggestions according to the specific kind of memory. I checked the technical specifications of the latter through Kingston's site http://www.valueram.com/datasheets/KHX64... , but I was a bit confused with this comment:
    "Each module pair has been tested to run at DDR2 800MHz at low latency timing of 4-4-4-12 at 2.0V. The SPD is programmed to JEDEC standard latency 667MHz timing of 5-5-5-15 at 1.8V."
    The DRAM Voltage Control is 1.950V by default in the motherboard and the latency timing was 5-5-5-12 on the auto (SPD). I think that I have already tried changing it to 4-4-4-12 at 2.0V manually, but let's say I have been mistaken...should I use this option rathen than the 5-5-5-15 one?
    Thanks again for your advises.
  • Dick
    Dick May 11, 2010
    If the BIOS does not identify the memory correctly, Windows will not identify it correctly either. Your operating system gets the information from the motherboard.
    If you have tried all the settings available in the BIOS, I would try the memory in another system. Most likely thing to work is resetting the CMOS back to failsafe defaults (hold the INSERT key while powering on the system as described on page 12 of the manual you provided.)
  • 272 Answers
You may try another OS if you think, this is a software problem. please let me know the update with another os like xp ?
Posted on May 24, 2009
I can not install win7
Maybe you're too fast. Don't Press any key, just let it sit a while and see if it starts processing. The only time you should press any key is when you first start the install. Any other time that the system reboots it is going to give you the prompt about Press Any Key, but don't do it because it will get what it needs off the drive, not the cd.
May 14, 2012 | DFI LANPARTY DK 790GX-M2RS AM2+/AM2 AMD...
I have a DFI LANPARTY UT nF4 Ultra-D and have been been unable to use all of the memory slots. I originally bought 4GB but have only been able to use 2. Is there a setting that i need to enable?
Hi, you can use up to 3 gigabytes on windows xp 32 bit with service pack 3.
You need a 64 bit operating system to use 4 gigabytes of ram.
Here is some info:
CPU
AMD Athlon 64 FX / Athlon 64 / Sempron Socket 939
Chipset
NVIDIA nForce4 Ultra
Front Side Bus
2000MT/s
HyperTransport interface
Memory
Four 184-pin
DDR SDRAM DIMM sockets
Supports dual channel (128-bit wide) memory interface
Supports up to 4GB system memory
Supports
DDR266, DDR333 and DDR400 DDR SDRAM DIMM
BIOS
Award BIOS
CMOS Reloaded
CPU/DRAM
overclocking
CPU/DRAM/Chipset overvoltage
4Mbit flash memory
Aug 30, 2011 | DFI LANPARTY UT nF4 Ultra-D Motherboard
I have a DFI LanParty NFII Ultra motherboard. I had to move the power supply to a different machine and have purchased a new one to drive the DFI system (Win Power) rated at 650w. The power standby...
It's the craziest thing, I'm looking dead at the Motherboard Manual for the DFI LanParty NFII Ultra B motherboard, and the diagnostic LED lights are Not referred to.
Looking at the view of the System Board, the LED lights are shown down by the CMOS Battery.
LED 1, 2, 3, and 4.
The manual indicates only two types of BIOS Beeps are listed;
1) One Long beep followed by Three Short beeps.
Video error has occurred and BIOS cannot initialize the video screen to display any additional information
2) Single Long beep
A DRAM error has occurred. {Problem with the Ram Memory modules}
The BIOS program is a Phoenix - Award BIOS, but doesn't indicate what version or date.
[ The motherboard manual is downloaded for free from here,
http://productsmanuals.com/computer-manuals/dfi-lanparty-nfii-ultra-b-system-board-user-manual
Go to > To view the Products Manual - or to Download it - just click HERE.
{Click on HERE}
Allow up to 30 seconds for the file to download.
Offhand I would say it is Ram Memory that is the problem. Remove the ram memory module/s, and clean the gold plated contact pins with a pencil eraser, then use air to remove the eraser dust.
However, in looking up for information on the diagnostic LED lights, (The info IS out there. Maybe on DFI's support website, but I couldn't find it), I see that if you are using a graphics card that requires an additional power cable, you'd better have that baby plugged in.
The motherboard won't work if the additional power cable isn't plugged into the graphics card.
Regards,
joecoolvette
Dec 06, 2010 | DFI LanParty NFII Ultra B Motherboard
I use a computer with a DFI LanParty Pro 875b (LP PRO 875B) Motherboard in it, and i can't get it to connect to the internet, either wirelessly, or through an Ethernet cable. the device manager says the...
Go to DFI and look for Drivers for your operating system...all device drivers are OS specific..or just purchase a new compatible network wifi or lan card and install it....
Feb 03, 2018 | DFI LanParty Pro 875b (LP PRO 875B)...
I have two computers with dfi lanparty nfii ultra b MB both of them now will reset if you put them under to much of a load I installed new PS change video card and changed out the memory. It's not OC it's...
Did you change-out the CPU?
If not, try that.
How old are the motherboards?
If the warranty on the motherboard is still valid, exercise the warranty, to replace the motherboard, at no cost to you.
Sep 28, 2010 | DFI NFII Ultra B (LANPARTY NFII ULTRA B)...
The sound drivers won't install and no sound device is detected by the system.
Check in the BIOS if the onboard audio is detected and activated. If it is then power cycle it: disable, reboot, reboot, enable it - that should force Windows redetect it.
Jun 10, 2010 | DFI LANPARTY DK 790FX-M2RS Motherboard
I need to connect wires to DFI LANParty mother board.
You can find your manual here in PDF version, this will allow you to " zoom " in on any connection information your may need.
http://img.lanparty.tw/Upload/Manual/CM/lputnf4%20847505101.pdf
Jun 20, 2009 | DFI LanParty UT nF4-D Motherboard
Computers & Internet Logo
160 people viewed this question
David Payne
David Payne
