Question about Danby 22 in. DDW396 Free-standing Dishwasher
Water does not drain from the bottom. I understand that a small amount is normal, however, this is not a small amount. Thanks for your help.
Bottom of washer does not drain. I do understand that a small amount is normal, however, this is not a small amount. Thanks.
    Problem Solver:
  • 4 Answers
It worked for me .I have a danby countertop dishwasher.
I took off the metal top
I looked under on the left side to find the pump
I took both hoses off the pump and took off the little fan.
i took off the little metal bracket behing the little fan. and unscrewed the little pump to take it out.
the little metal piece that the fan was on wouldn't even move.So i sprayed it down with wd and it started moveing again then a screw fell out.so i found where it went(inside the motor which the fan and metal piece move) got the tweezers and replced it. oiled it some more and put it all back together. Perfect.
Posted on May 25, 2009
We have a new whirlpool refrigerator....there is watering collecting in the bottom of the freezer side and it is running out onto the floor..do we need a repairman or is there something we can adjust to...
Sometimes the drain can clog with ice. If this is it - simple fix. Empty the freezer and find the drain. Put hot water in the drain with a turkey baster or try using a hair dryer to thaw the ice and let the water drain. A small amount of water drainage through this drain is normal. The water sits in a tray underneath and evaporates helped by heat from the compressor. If the drain plugs, the water will build up in the bottom of the freezer and become an ice block.
Feb 25, 2015 | Whirlpool 25.6 cu. ft. Side-by-Side...
My Fagor dishwasher di not finish the cycle and has water in the bottom of the machine which has not drained. Now it will not start and just beeps. How can I drain the water and get it to start and fu
A small amount of water in the bottom is normal (it allows the pump to be pre-primed). Do not remove the water (as long as it is only a little in the center well).
Nov 03, 2014 | Fagor Dishwashers
My whirlpool dishwasher is not draining completely. It runs through the entire cycle with no problems, except that after it has finished, there is a layer of water on the bottom of the diswasher.
Hi, there will always be some water in the bottom the tub. This is called the sump. When your pump stops draining, all the water that's up in the hose will drain back into the sump. You failed to tell me how much water is there. If a small amount then it's normal, however if it's a large amount that covers 1/2" or so then you indeed have a problem and snaking out the lateral should clear it up.
Jun 28, 2011 | Whirlpool Dishwashers
We have side by side Kenmore and on freezer side we are getting prozen water under the slide out drawers on the bottom on interior. We have cleaned it out and it refreezes and when we turned off water to...
Your drain line is frozen and not allowing the defrost water to drain to the pan below. The drain hole is at the bottom of the evaporator coil in the freezer behind the metal rear panel. You may need to remove the panel to access it. You can use hot water to thaw it out and you should be in good shape.
Kelly
Mar 24, 2011 | Kenmore Side by Side Refrigerator
Small amount of water covering bottom dishwasher-won't drain
YES IT IS WATER FROM DRAIN HOSE LEFT AFTER PUMPING OUT THE MAJORITY OF WATER AND IS LEFT IN HOSE.
Mar 10, 2010 | Maytag 24 in. MDB3700 Built-in Dishwasher
Dishwasher is not getting dishes clean. Plus there is a small amount of water below the drain screen but still in drain pipe. Should all the water be pushed out.
Look for particulate matter build up in drain screens.,
Normal operation leaves a small amount of water in the bottom of the machine. If it were not there, you would quickly burn out the seals...
My suggestion is to observe the VOLUME of water exiting the hose, on draining.
Sometimes you just have to take the unit apart and witness every part is clear. and be sure to look for bent drain hose, which would relax and pinch off more with hot water draining...
Sep 20, 2009 | Dishwashers
Standing water at drain in dishwasher after using.  Is this normal or should the water drain completely.
Most dishwashers leave a small amount of water in the bottom to keep the seals lubricated. If it is only a small amount of water it should be normal.
Jul 09, 2009 | Dishwashers
After a load water still remains in bottom
If it is a very small amount it may be normal. Check to see if the manual says anything about that. If it is a large amount, the drain hose may be partially blocked where it connects to the pump underneath. Something like a cherry pit caught at that connection could cause water to not drain fully.
Jul 08, 2009 | Dishwashers
Water and odor collecting in our empty dishwasher after 4-5 days
A small amount of water may be normal.  Clean the filter at the bottom of the tub.  Sprinkle some baking soda inside between washes.
Jun 02, 2009 | Dishwashers
Water still in bottom of tub after drain/spin cycle
I removed the drain hose from the bottom left rear corner of the washer & cleaned a large amount of gooey sludge from the bottom of the drain inside the washing machine.
Feb 14, 2009 | Kenmore 12502 Top Load Washer
Danby 22 in. DDW396 Free-standing Dishwasher Logo
158 people viewed this question
Top Danby Dishwashers Experts
Kevin Getz
Kevin Getz
Andrew Taylor
Andrew Taylor
Are you a Danby Dishwasher Expert? Answer questions, earn points and help others
