Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
Bissel pro heat unit brushes will not engage
Brushes will not turn
  • kimbrailee May 26, 2009
    Belt is intact, it is cleaned, it has been tried upright and handle engaged, it has been tried with water clean and deep clean as well as the other settings, plus it is fairly new. I just realized the brushes aren't moving though. I wonder if they ever worked. Any other solutions to offer? I know, don't tell me, return it. Right? :)
  • david4112 May 26, 2009
    CAN YOU PLEASE TELL ME HOW TO CHANGE THE BELT THANKS
  • 59 Answers
Keep in mind they only turn when the handle is down. if that is not the problem, it is usually the belt.
David
Posted on May 25, 2009
Manual for a Bissel pro heat
Here is the Instruction or User Manual for the 7910 and the 8910 series machines
Here is the Instruction or User Manual for the 8920, 9200, 9300, 9400, series machines
Here is the Instruction or User Manual for the 9500 series machines
Aug 05, 2012 | Bissell Carpet Cleaner Powerbrush Deep...
How do i replace the brush belt to my bissel pro heat carpet cleaner?
Follow the link below for belt change instructions on bissell.com.<br /> <a href="http://www.bissell.com/VideoRating.aspx?id=1555">http://www.bissell.com/VideoRating.aspx?id=1555</a>
Aug 25, 2010 | Bissell 8910 ProHeat Clear View Upright...
How to get the beater brushes to work
Your belt is broken or has come off the track.
Mar 18, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
How do you replace the pump belt?
To install a new belt you need to unplug the unit first and flip that bad boy over so you can acess the bottom of the unit. You will need a phippilps or torks driver to remove the scres towards the front where the brush is. Once you pull all this out the belt will be attached to the brush and a small pin in the back. It is really simple. Hope this helps out.
Aug 23, 2009 | Bissell 1697-7 Powersteamer Pro Deluxe...
Bissel Pro Heat Turbo attachment does not work.
Something is probably clogging up the suction.
Try to snake it out with a coat hanger or similar tool.
Often, especially with shedding pets hair will clog the suction pipes
Hope this is helpful.
Good Luck!
Jan 02, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Taking the brush off the pro heat bissel?
try changing the belts first if you buy the original belt package it comes with instructions on how to replace them, if not it probably has a clogged heater core
Oct 12, 2008 | Bissell 1699 ProHeat Clear View Upright...
Bissel pro heat /brushes do not turn
Belt worn or hair build up can clog it from spinning. I've seen this on other models. Just remove the hair slowly. If the Belt is worn you can replace that from Bissel or any store that sells their product.
Check to ensure that the pump belt and brush belt are intact and installed according to the instructions provided in the User's Guide.
The pump belt is located under the belt access door on the side of the machine. This belt should be looped around the red pulley and the silver motor shaft.
To check the brush belt, please follow these directions:
Turn the machine OFF and unplug from the wall outlet.
Step on the handle release pedal to lay the handle down on the floor.
Remove the Tank-in-Tank and SmartMix Bottle and set them aside.
Turn the machine over to expose the brush.
Look for the red retainer plates, which hold the black brush arms in place. Remove the two Phillips head screws to access the toothed brush belt. Check to ensure the belt is intact and looped around the brush end, as well as the red pulley with the ridges.
Remove any dirt or debris from the brush assembly.
Inspect brush, brush arms, red brush arm retainers and red pulley for damage and replace parts if applicable.
Jul 30, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
My bissel pro heat cleane's brushes stoped. I checked the belts. They are okay. There is no sign of heat or problems around the motor. Is there a mercury switch some where in the handle so the brushes...
Depending on which model you have, you did not say, if the cogged belt goes to the pump pulley, the cogs may be wore away or and won't turn the brush roll. On some other moels, there is a brush roll motor that may have gone bad.
Apr 17, 2008 | Vacuums
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
236 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
