Question about Frigidaire Freezers
Unable to remove shelf
I need to remove a shelf from my upright frigidaire frost-free freezer. The shelf has two spacers on one side which I am able to remove. The ends of the self sit into holes in the side of the freezer. I am unbale to see how to shift the shelf far enough so that one side clears the holes and would then be able to come out. I'm unable to see what the procedure is. I can see multiple holes for some of the shelves which confirms that it must be possible to get a shelf out and in. I'm at a lose for the moment and any help or gudiance would be appreciated!
  • Frigidaire Master
  • 3,361 Answers
Remove the "spacers" from the shelf and discard them.
They are for shipping purpose only.
Then push the shelf right or left and pull up on the opposite side. It will come out.
Posted on May 24, 2009
Our Frigidaire frost frost free upright freezer from day one has frost build up on the food inside the packages. The frost is not a problem in the freezer itself, but on the food. Freezer burn occur
Hi Dale Dibb, thank you for your inquiry!
I understand that the food inside of your Frigidaire freezer is getting frost on the inside of the packages. I would recommend turning the temperature up inside of your freezer. Additionally moisture inside of the package would cause frost to develop on the inside of the food packages.
Please assure that all possible moisture has been removed out of the food packages prior to placing the items inside of the freezer. If there is anything else that I can help you with, please feel free to reconnect! -Matt
Sep 30, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Hi. We've got used ("as is") Electrolux Frigidaire
Not sure if u still need help but the first thing I would do is remove the grills on the front and back and vacuum out the fins on the condenser...dust and grime collects here and will cause the unit to overheat and not cool properly....sometimes an air compressor can be used or air in a can for the hard to reach places.
Tr this and see what happens...good luck
Mar 31, 2017 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
May frigidaire frost free model LFFU1767DW15 have fan motor
Hello David - Typically most of the recent manufacture freezers have fan motors, however some are enclose to where you are unable to reach or see it. Are you having a specific problem with your freezer?
Sep 25, 2012 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Frigidaire upright model ffu21k2cw1 frost on top shelf and not cooling properly
http://manuals.frigidaire.com/prodinfo_pdf/StCloud/216802800en.pdf
Your unit is not self defrosting so I would suggest you do a manual defrost and see if it corrects the problem.
Also make sure that you have good air flow across the compressor.
Jan 01, 2012 | Frigidaire Freezers
Lower shelves keep falling down out of wall supports
replace gromments and reduce the weight that you put inside the shelf/basket.
Apr 22, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Side by Side Freezer ice build up and water in the
Either the drain hose is plugged up with ice and not dripping into evaporator tray, or the defrost unit needs to be replaced.
Aug 04, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Ice build-up on the inside top of of freezer door
yea def , not normal, nor an acceptable amount of ice forming there( good pic). heres what i have been told to try and with good results
first make sure the door gasket is sealing all the way,(small gaps in ht emagnets at extreme corners) is common but with a little amount of "mortite"or "permagum can sometimes be insterted behind the corner of gasket to assist filling the void.
second a small amound of a white/clear silicone be applied to the outer perimtere of gasket, to minmize air movemnt from between gasket and door panel.
lastley in oyour second pic i see "frost free" written on a plastic air deflector. you can remove that with 3-4 screws on backside of it, and then reinstall with a small spacer so as the baffle now with sit with a 3/8in. gap between it and the top of the freezer liner.( a brass ferrel from the compression fitting of a plumbing fitting is just the right size)..... the theory behind this is to prevent the air from gatting "trapped" in the void created when the door closes-- air can now pass back and forth freely.
I hope this gives you some satisfaction if not I would advise another tech be sent who is willing to call for factore tech support( ths is where i got my info from)
Jan 14, 2009 | Frigidaire 13.7 cu. ft. Upright Freezer...
Freezers Logo
285 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Dan Webster
Dan Webster
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
