Question about E-Machines EMA IMPERIAL GV (845GV) TG3 eMachines (145119) Motherboard
Emachine t2824 board diagram
I need to find the diagram to show where the power led and power switch wires coming from the front panel switch to the board
The system is getting power but noting is initializing
I tried to find it on the emachine site but was not successful
Once I am sure of the correct connections of the power sw wires and if it still continues to do nothing but show power light on the board, what would you reccommend? should i strip the system down to board or do you think the board is shot?
Any advise would be greatly appriciated
  • 2,404 Answers
Here is the diagram that shows you how to hook up the wires:
http://www.fixya.com/uploads/images/284ECAC.png
If you still have no video then reseat the memory one stick at a time in one slot at a time.
If you still have no video then reseat the cpu into its slot.
If still no luck try a different stick of RAM by trying it one slot a time.
Last step, unhook the power connectors from your device so the only power connectors that are connected are the power to the motherboard and the p4 connector to the motheboard. Also make sure your power supply is set to 115v. Its the red switch on the back of the power supply.
If none of this works, then the motherboard is bad. Hope this information helps.
Ben
Posted on May 24, 2009
Motherboard diagram Acer eMachine MB DA061/078L
Hello? Tap, tap on the monitor. What are you reading from?
http://www.ebay.com/itm/Acer-MB-NB107-001-DA061-078L-Motherboard-eMachines-08120-2-780G-AM2-Desktop-/280919767281?pt=Motherboards&hash=item41681f78f1
The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the main wires go to from the Front panel, is the Front panel header.
Motherboard installed in computer, the Front panel header is at the Bottom/Right.
Two rows of 7 pins in a small black rectangular plastic block.
http://www.ebay.com/itm/Acer-DA061-078L-Motherboard-eMachines-EL1200-X1200-AMD-780G-Socket-AM2-DDR2-/140825131784?pt=Motherboards&hash=item20c9d4fb08
TOP row of pins is numbered EVEN.
BOTTOM row of pins is numbered ODD.
Starting on the LEFT side going towards the Right, TOP row:
Pins 2, 4, 6, 8, (NO 10), 12, and 14. Again, there is NO Pin 10.
Starting on the LEFT side going towards the Right, BOTTOM row;
Pins 1, 3, 5, 7, 9, 11, and 13.
A) Pins 1 and 3 are for the HarDDrive activity LED. (Light)
Pin 1 is for the Positive ( + ) wire.
If the HDD LED is dim when the harddrive is active, switch the wires around.
2) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
3) Pins 2 and 4 are for the Power On LED (Light)
Pin 2 is for the Positive ( + ) wire.
If the PWR LED is dim when the computer is on, switch the wires around.
4) Pins 6 and 8 are for the Power On switch.
5) The rest of the pins are N/C. Not Connected.
Don't forget to plug the 4-pin ATX +12 Volt power cable in,
(Top left corner),
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
For additional questions please post in a Comment.
Regards,
joecoolvette
Sep 06, 2012 | Computers & Internet
I'm working on an Emachines T3624 I took out the front panel connectors and I can't remember where the power switch connects to the motherboard. I know the general area but I don't know the exact spot....
The manual can be downloaded here, just click on "drivers and downloads" and follow it out.
http://support.gateway.com/us/en/emac/default.aspx
I was hoping to refer you to the manual to provide a diagram, but the manual does not show the front panel I/O connections, so I'll give you general instructions.
The front panel header is a set of two rows of pins. You may need a magnifying glass and flashlight to see the small print on the motherboard that identifies the pins. Look at your front panel cables and look for the same abbreviations on the circuit board. You should see "pw sw" (power switch), "rst" (reset), HDD (hard drive activity indicator LED), and "pw" (indicator LED that shows that the computer is powered up. There should also be speaker.
Just match the cables to the pins on the motherboard. Polarity ( + or - ) is only important for the LED's ( pw and HDD ) Don't worry, if you connect them wrong, they just won't work, just swap wires.
Apr 29, 2011 | E-Machines T3624 PC Desktop
Looking for the front panel wiring diagram for a emachine T4510. The Power LED & the Power SW are disconnected! HDD LED was never unplugged! I need to know where they need to be!
If you look closely at the board there should be labels printed. The power switch plug can plug in either direction, but the LED must be the correct direction for it to work. No damage can be done by plugging the LED in backwards.
Jan 30, 2011 | E-Machines eMachines Desktop PC
Emachine t1840 wiring diagram power switch wire to mother board ?
Because there are so many different case and motherboard combinations sometimes it can be difficult following the instructions for connecting the front panel, USB header and audio header.
Below is a few generic guide that should stop some of the confusion with the labels on the wires.
Front Panel Audio
***Please note this is a generic wiring guide and we can not guarantee it will work with every motherboard. Please check your motherboard manual first. Wiring the headers wrong can cause damage to the motherboard and case, this damage is not covered by the warranty***
another handy USB wiring guide can be found here http://www.directron.com/installusb.html
this maybe easier to follow
FRONT PANEL AUDIO
2________10
__
1________9
Pin Wire
1) Mic In
2) GND (ground) or if 2xGND available, it’s the GND for the headphones, NOT the Mic
3) Mic BIAS
4) n/c
5) Speaker Right Out
6) Speaker Right Return
7) n/c
8) no pin (n/c)
9) Speaker Left Out
10) Speaker Left Return
n/c = not connected
USB (F_USB1 and also F_USB2)
2________10
 x
1________9
Top row of pins
2 = USB port 2 : VCC/Power/+5V
4 = USB port 2 : Data -/D-
6 = USB port 2 : Data +/D+
8 = USB port 2 : Ground/GND
10 = USB port 2 : pin present, but not connected to anything.
Bottom row of pins
1 = USB port 1 : VCC/Power/+5V
3 = USB port 1 : Data -/D-
5 = USB port 1 : Data +/D+
7 = USB port 1 : Ground/GND
9 = USB port 1 : no pin present
Front Panel Connector (FP1)
1 2
x 
9 10
1 = no pin present
3 & 5 = Power Switch
7 & 9 = Power LED (light)
2 = pin present, but not connected to anything.
4 & 6 = Reset Switch
8 = 10 = Hard Drive LED (light)
Jul 30, 2009 | Computers & Internet
On/off switch
Usually the power on button only has two wires. Then you have HDD led leads, reset leads, power led leads etc. These are all separate wires that fit onto separate pins in the Jpanel1 (front panel header).
Could be that the really old emachines grouped all these wires and made them into a plug to fit their own style motherboards.
If this is the case then that connector would not be on your newer motherboard, and it would have that Jpanel1 instead.
Hope this helps as I'm not very familiar with the old emachines.
Hank
Jul 08, 2009 | Intel Desktop Board D815EFV (BOXD815EFVLU)...
A power diagram for restoring power for a emachine
Hi there if you look real closley at the wires they are labled such as (pwr)led (reset) (hdd led )
(remote switch this the power for the computer) ect ect now look real closley and you will see the same markings on the edge of the board by each pin that they go to.. or you can also contact e-machines tech support and they will be able to help you out more if needed
best regards mike
Mar 17, 2009 | E-Machines eMachines Desktop PC
Emachines t3830 I need the schematic for MB I umployed the wire for the push bottom without looking at the way they were plug. Now I do not know the correct aligning of the push bottom wires.
If you look at the motherboard there is usually a diagram labeled "FRONT PANEL HDR" that will tell you which pins are for: HDD LED, PWR LED, RESET, PWR ON. etc.
The chart / diagram may be a few inches away from front panel header.
the following example is from my emachine T2893 that I had opened because it won't power up.
the motherboard at the header connector labels pin #2 and with that you can figure out the other
pin numbers
example of diagram on motherboard (Confirm the pin numbers on your motherboard)
J9G1 PINS
| HD LED | 1 - 3 |
| PWR LED | 2 - 4 |
| RESET | 5 - 7 |
| PWR ON | 6 - 8 |
Hope this helps you figure which pins to hook you switch up to.
Jan 18, 2009 | E-Machines eMachines T3830 PC Desktop
Can u possibly tell me where i might be able to download a schematic for an EMachine desktop computer model #T2742? It is out of warranty and was donated to our church and we need to know where to...
Hi dallasblue08,
Here's a diagram of what your looking for:
The following eMachine models share the same motherboard (and thus the same front panel layout):
T2742 T2796 T2798 T2824 T2885 D2823 T2862 T2896 T2898 T2958
Hope this helps!
Mark
Jan 04, 2009 | Computers & Internet
Emachine t2742 I also have a wiring problem!
gtater,
It's ironic that you ask me this question today-- i am just now carrying in another eMachine computer to fix. Anyway, unfortunately I do not have one that is the same model as yours (T2742). However, I did some quick research and found that yours has the same exact motherboard as the T2898 which I made the diagram for!
For further reference, I would like to share this diagram for the eMachines T6544 in case someone else may need this model. This is the computer I just carried in... might as well share.
By the way, the power switch doesn't need to be oriented any particular way (positive and negative), which is why the switches are not labeled as + or -. Switches can be wired either way and they will work the same.
Hope this helps.
Jan 03, 2009 | E-Machines eMachines Desktop PC
Computers & Internet Logo
2,390 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
