Question about HP PSC 2210 All-In-One InkJet Printer
Shutdown after 3 0r 4 pages
Parents had this printer for a long time and it worked beautifully. Now it has a problem when printing. After printing 3 or 4 pages it will shut itself down. It has to be unplugged, set for a minute, then plugged back in. It does not pick up were it left off but has to restart, or I have to set the printer options to start were it stopped. Is this the actuall supply, the adapter, or is there a fan that is makin it overheat? If you know the problem were do I go to get the proper parts?
    Sergeant:
    Champion:
  • 240 Answers
Try to check the voltage output of the power supply adapter,.if it has a enough voltage to run the printer,,using the voltmeter..the meter should read atleast 30 Volts or nearest ..and a current of 1.7 amp..
if not the supply
its a firmware issue..of the printer,,
you need to flash with its compatible firmware..
thanks for using FIXYA.
Happy FIXing..
Posted on May 25, 2009
How to print middle page from scanned document
Dear! First of all, You should check your printer timer may be it enable and after the completing the time it shutdown automatically. Secondly, You choose custom option and use it command it from 85 to 100 and 30 copies for each it will work completely.
Thank You
Jul 25, 2009 | Ricoh Aficio AP410N Laser Printer
My HP C4480 all in one printer is working fine accept when I try to print things, the first half of the page is fab however the second half looks like the colours are running out. The ink is new and it...
check the page setup and verify that the paper type is A4 also check the margins of ur paper which u want to print it by check it on print preview before printing
Jun 08, 2009 | HP Photosmart C4480 All-In-One InkJet...
Hp Laserjet 4 Plus printing very light - second post
Your description indicates that the problem is with the printer driver settings.
Go to Start, Control Panel, Printers and check the setings for Economode and ReT. The should both be off or Economode=off and ReT set to Med or Dark.
This should fix the problem. Let me know if this works or not and we can try something else.
May 03, 2009 | HP LaserJet 4m plus Printer
Epson RX650 with a G5 Mac. Printing beautifully,now pgs are blank
It definately sounds like blocked print heads, try head cleaning 4 or 5 times, leave overnight and try another 4 or 5 times the next day. This usually works, if not you will need to try something a little bit stronger. Try this link:
http://websites.uk-plc.net/UK_Inkjet_Cartridges_PLUS/products/Print_Head_Cleaner.htm
Blocked print heads are more far more common if you are using non-genuine Epson inks. Please take a moment to rate this solution. Thanks.
Mar 04, 2009 | Epson Stylus Photo RX600 All-In-One InkJet...
HP PSC1410 wont print and shows offline
I had the same problem. This is what worked for me: I went to the HP website and downloaded the hp Print Diagnostic Utility. Found the problem and fixed it in no time (device manager I believe)... worked beautifully. Hope this helps :-)
Feb 06, 2009 | HP PSC 1410 All-In-One InkJet Printer
HP Photosmart D7360 not seen by PC, despite driver, s/w loaded
Not a solution per se - just a diagnosis. I have decided that the USB out port on the printer is bad - and after wasting time just trying to crack the case, will just use this as a photo printer "offline." It prints beautifully directly from media inserted into any of its onboard slots. I will just have to save things as .jpgs or picture formats to print from this printer. HP didn't have the part available, anyway. I called and inquired.
Jan 27, 2009 | HP Photosmart D7360 All-In-One InkJet...
Dell 540 photo printer
It might be time to, but try these first:
(1) Try rebooting the computer (Press Ctrl+Alt+Del>Shutdown>Shutdown OR press and hold the power button down on the front of the workstation/computer/tower/CPU until the unit turns OFF)
(2) If that doesn’t work, then try clearing the print queue: Start>Settings>Printers>Double-click on the printer>Right-click on the print job(s) and click cancel/delete/purge documents and try reprinting a document
(3) If that doesn’t work, then try a power cycle: Try turning the printer off, then unplug the power supply from the printer, then unplug the USB cable from the printer then the back of the computer; wait 30 second; then plug the USB cable back into the computer, then back into the printer then plug the power supply back into the printer and turn it on – run a test print
(4) Run a Test Print: Start>Settings>Printers>Right-click on the printer>Properties>Print Test Page
Jan 02, 2009 | Dell 540 Photo Thermal Printer
Printer photo paper
Scrapbooks work very well and they come in such beautiful sets of ornamentation etc. that you can create a beautiful wedding album. Or you can purchase a beautiful 3 ring binder and use the more expensive plastic sleeves that are sturdy and insert all of your 8 X11 pages into them. Or you can make every document or photo that you print 8x10 by setting up your printer to print that way. Good luck to you!!
Aug 15, 2008 | Office Equipment & Supplies
HP PSC 2210 All-In-One InkJet Printer Logo
46 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
