Question about Hampton Bay 24002 Ceiling Fan
Wiring ceiling fans to wall switch
I have four Hampton Bay ceiling fans with lights. Currently wired to run from chains. I need to rewire to wall switch control. Tried several waus, but only getting light to work from wall switch. Ceiling box has red, black, white and bare. Fans have black, blue, white and green. Wiring from wall only has red, black and bare. The Lutron fan and light switch I want to install has black, red, green and yellow
  • 6 more comments
  • Anonymous Nov 29, 2008
  • Anonymous Mar 12, 2014
    Fan and light operate with wall switch can't controlled fan with remote
  • Anonymous Mar 13, 2014
    When Replacing motor where do i connect the red yellow green white black wires
  • Anonymous Mar 22, 2014
    when button is pressed to turn on light, red light does not illuminate. not working. tried to change battery in switch but still does not work.
  • Anonymous Mar 26, 2014
    The on off panel the red light is now staying on. Also the fan will no longer turn on high. What could be causing this?
  • Anonymous Mar 27, 2014
    4 wires,black, blue, red and yellow
    there are 4 wires, black, red, blue and yellow
    wire diagraam for one room with ceil light; light switch;two wall outlets on different walls
  • 709 Answers
Hi Bigelow,
You need two switches.  It sounds like the Electrician set up the junction box for two circuits(Lights and Fans).  i say this because your supply has 4 wires, Red , Black, White and Bare. We may be able to oversome this with one Lutron Switch. Allow me to investigate, and I will be back.
Posted on Oct 29, 2007
Had to disassemble a Hampton Bay ceiling fan to install a new light pull switch. Hung from a paperclip while fixing but it dropped and disconnected a number of wires. Rewired by my best guesses and now fan...
If you bought the switch from Lowes, most likely it's the wrong switch. Even if it looks the same on the outside, it could be different on the inside. As for the other wire, push it into the empty slot of the switch & see what happens. There has to be 4 wires in the switch. Black usually goes to L
Jan 04, 2015 | Hampton Bay Dryers
Hampton Bay fan wiring
this is everything u need to no
it has all the colors and a diagram for you
Sep 29, 2008 | Hampton Bay 52 In. Brushed Nickel Romano...
I did not make a diagram when replacing the light switch
Red from switch goes to two blacks, blue from switch goes to two blacks and the black wire goes thru top of light and attaches to blue fan light wire. If you want a good fan, look for blade pitch(13 degree or higher)Or CFM's above 5500 on high.
Oct 02, 2013 | Hampton Bay 24002 Ceiling Fan
Missing remotes for hampton bay ceiling fans
Apr 02, 2017 | Hampton Bay 52 In. White Redington...
I bought a Hampton Bay ceiling fan and I have
Hi ,, the usual wiring for the fan / light is that in the ceiling the white wires connect together , the black house wire connects to the black fan wire, the red house wire connects to the other fan wire, usually blue or black with a blue stripe. If this does not resolve the issue, then check the wall switches and see that there is a power wire to each switch and that there is a red wire from the fan on one switch and the black wire from the fan on the other switch ..
Apr 07, 2010 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Zing ear switch from a hampton bay ceiling
Did you try Home Depot, Lowes, or any lighting supply store. It's a pretty common item, so they should all stock it
Dec 12, 2009 | Hampton Bay 52 In.Carriage House II in...
Hampton bay fan with two wall switches and fan does not work
That is because you need both switches wired exactly the same way in order to have a two way switch. The switch that blew had the necessary wires but was wired wrong. One of those two black wires has to be used as a red one. You will have to check the wires for continuity to find which black connects to the red wire on the other end.
Jan 31, 2009 | Hampton Bay 24750 Huntington III Ceiling...
Wall switches do not control fan
Some fans will not operate without the remote, however, I'm not sure if the Hampton Bay brand is one of these or not. Below is how you will bypass the remote if the fan will operate without the remote.
You can try disconnecting the receiver in the canopy of the van (the cover that fits snug to the ceiling) once you have shut off the power source remove the canopy and find the remote receiver.
Most likely it will be a rectangular box with white, black, and blue or red wires attached. Disconnect all wires from the receiver and lay it to the side.
Now reconnect the wires directly to the fan, white to white, black to black, if you have a red wire (or a second black wire) in the ceiling box connect it to the blue wire from the fan.
If you do not have a red wire (or second black wire) in the ceiling box, connect the black and blue wire from the fan to the single black wire in the ceiling box. This method will require you to pull the chain to operate the fan separately.
Dec 12, 2008 | Hampton Bay 52 In. White Redington...
Ceiling fan wiring
blue would be your earth.
black and white are phase and neutral.
for the wiring in your roof you need to call a local sparky. just ask which is which and connect them appropriately.
Sep 01, 2008 | Hampton Bay 24002 Ceiling Fan
Hampton Bay Ceiling Fan At Slow Speed
I recently replaced my hampton bay fan for the same reason (slow at all speeds) and discovered scorched and melted capacitors and wiring inside the fan. My suggestion is to stop using fan and replace immediately.
Aug 10, 2007 | Hampton Bay 52 In. White Redington...
Hampton Bay 24002 Ceiling Fan Logo
631 people viewed this question
Top Hampton Bay Dryers Experts
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
