Question about Frigidaire 30 in. Electric Gallery Series Self-Cleaning Double Wall Oven
Oven turn's on, keep's heatings at a higher temp.
Oven heats to much and turn's off,come's on again keeps heating to much. Stay's at a higher temp.
  • 6,784 Answers
This is failed communication between the EOC and the temp sensors located in the oven. i recommend testing the EOC(break point test on the pins) for its operational value and the temp sensors as well. replace any component that doesn't register.
I would also inspect the oven temp sensors for welded harness and fouled housings.
In most cases, this will be a EOC issue.
Posted on May 25, 2009
Bottom oven isn't heating to desired temp. Considering swapping the heating elements to see if one is faulty - thoughts?
try thermostat first. verify heating elements operational, if so check if tstats are same. swap if so, If not jump out tstat and see if higher temp achieved.
Sep 20, 2015 | Thermador PODC302 30" Double Electric Wall...
Oven heat sensor
yes. is it under warranty?
Nov 09, 2013 | Ovens
Main oven keeps going off
If you mean the heat keeps turning off??? The heat will turn off when the thermostat detects the desired heat level has been met, after that, when the level of heat goes below the selected level then the oven will heat up again granted if the thermostat is functioning correctly. This is the best answer I can provide for vagueness of the question.
Nov 03, 2013 | Baumatic Ovens
Oven Won't Heat To Desired Temp / Burner Quits Working Sometimes
The temperature sensor in the oven needs to be replaced. Here is the part to order. As far as the top element, lift the top up and look for lose or broken wires on the element. Keep me posted.
Nov 20, 2012 | Magic Chef Ovens
When my GE wall oven is in the middle of heating up, I get an F3 edit and the oven keeps beeping. I turned it off and then turned it on again and it seems to be heating again. What part should I look to...
Hello there:
Normally this is due to a bad temperature sensor F3 Open oven temperature sensor circuit Measure oven temperature sensor circuit at oven temperature sensor (should be approx 1100 ohms at room temp); check for cut or pinched wire or loss of contact and replace if found faulty
Apr 27, 2010 | GE Profile JK915 Electric Single Oven
High limit switch trips and needs re-set
After grilling or cooking at higher temps leave the oven light on so the cooling fan continues to run for approx 1/4 hour, or whatever setting will keep the fan running...
Apr 22, 2010 | Dacor ECS130 Epicure Electric Single Oven
We have a GE JKP15 oven that will not heat to temperature (350F) when first turned on. The oven will beep (temp confirmation) and the display will indicate 350F but the oven temp will only be at 220F...
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Dec 26, 2009 | GE JKP15 Electric Single Oven
Burnt some food yest in grill and is not working today. wouldnt turn on straight away so i left it till this morning but still not heating up. oven is working perfectly fine. could the heating element for...
if the temp light or indicator light for the grill is on then i'm tempted to say that it is the element but checking for resistance is the only sure way to know..
Dec 22, 2009 | Zanussi ZBF360 Electric Single Oven
My oven won't heat to the right temp.
Check the temp censer in the oven It went bad.
Feb 26, 2009 | Frigidaire FEB27S5A Electric Single Oven
Kenmore oven doesn't keep heat
im going to assume it is gas.. you may have a bad ignitor.. it is not gettin hot enough all the time to ignite the gas.. eventually it will not lite it at all..
Feb 15, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Frigidaire 30 in. Electric Gallery Series Self-Cleaning Double Wall Oven Logo
168 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
