Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
2020 john deere cam crank balance timing
Re building engine need to know how to time balance shaft .iknow how to set cam timing
  • 246 Answers
SOURCE: john deere 2020 water pump repair?
Hello:
From your Description it Sounds like a Bad Water Pump Bearing and Seal.
>>You can View a Breakdown/IPL of the Engine and Mower at this Site Addy, http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt and Enter the Model Numbers and Click Find. Then Select your Model from the Search Results Area. Then Select the Sectional File. Then Select the Section of the Mower you Wish to View Online. *You can Drag the View Windows for Better Viewing.*
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
John
Posted on May 11, 2009
jimmy nutron
  • 132 Answers
SOURCE: I have a 1968?? 2020 john deere. The hydraulic
make shure none of your hydrolic cylenders are extended and fill it up till you can stick you finger in there and it barley touches if you do this when cylenders are extended you will over fill it.
Posted on Jun 04, 2009
  • 143 Answers
SOURCE: Three point hitch on 2020 Jogn Deere Tractor will not raise.
IF the rest of the hydraulic system has normal pressure, then the control valve for the 3 point may be faulty, or ; the hydraulic cylinder that raises/lowers the 3 point arms has failed (the sealing ring on the internal ring has torn)
Posted on Jun 20, 2009
  • 85 Answers
SOURCE: cam shaft is not turning when i crank engine model
I'm guessing you have a 7-10 year old Kawasaki engine with the plastic cam gear, that is missing teeth.
Kawasaki has a service bulletin on this,they have changed to a steel gear. your Kawasaki or John Deere dealer will have that info.
Posted on Sep 19, 2009
spiegela
  • 3 Answers
SOURCE: John Deere Model 445 garden
Do you know anything about the JD 445 engine?
Posted on Aug 06, 2010
Johndeere 2020 engine and balance shaft timeing
Put engine on TDC number one , balance weights will be bottomed in housing , lift it up and it will engage in the right tooth on the crankshaft gear bolt down while holding in place. There are no timing marks on crank gear or balance gear.
Feb 07, 2017 | John Deere Garden
190CC, 8.75 hp. how do I set cam shaft timing?
What brand of motor? Briggs has a dimple on the cam and has a timing gear ring on the crank. I position ny piston to TDC of, well, it doesnt matter. Position the piston at TDC and put on the ring gear (if applicable) back onto its keyway. Rotate the crank clock wise until the black dimple is 90° to the right. You can then line up the camshaft dimple to the crankshaft dimple accordingly. What motor model numbers do you have. That will help.
Sep 28, 2015 | John Deere Garden
How do i set timing gears for a john deere 2020
I'd suggest going to John Deere's website and look up an owner's manual and repair manual . If you have Adobe Reader you can copy it in a PDF format.
May 12, 2014 | John Deere 420,1020,2010,2020,2510,2520...
Timing chain marks needed for Audi A4 B9 1.8tfsi 2009 model. Engine was taken out and settings not marked. This is extremelyurgent. Please help
diagrams I have show a twin cam set up with 2 balancing shafts. The marks on the cam shaft point to (left cam shaft 11 oclock the mark on the right point to the 1 oclock position. The chain will have 3 black links-- the top black links will be at the timing marks on the shafts with the 3rd black link directly at 6 oclock facing a mark on the gear. The balancer marks both point to the 1 oclock position with black links on each and the 3rd black link will be facing a mark to the 7 oclock position on the crankahaft gear. Everything is done with the piston at TDC no 1 cylinder so get it there before you put the cam shafts in position or you will bend valves. Crank shaft gear is not keyed to the crank shaft. there are dots on the right hand balancer shaft gears and these dots will be as the 2 dots on adjacent teeth either side of a dot on the meshing gear. I suppose that is all as clear as mud but if you got this far then you will see the marks and marked links on the chains
Dec 22, 2013 | Cars & Trucks
Setting of timing chains
Get Ford timing tool kit, part = otc-6488 (For about $119 USD on eBay)
4 timing chains (3 front including the optional balance shaft chain + 1 back)
2 cam guides (1 front + 1 back)
2 oil tensioners (1 front + 1 back)
1 jackshaft tensioner (1 front)
1 jackshaft guide/cassette (1 front)
1 balance shaft tensioner (1 front) (will probably be ok, so dont replace it)
1 balance shaft guide (1 front) (will probably be ok, so dont replace it)
new sprockets + bolts + gaskets etc.
new spark plugs + throttle body cleaner + lithium grease spray + oil change
head gaskets
some of these parts (the front stuff) can be obtained as a primary timing chain rattle noise kit Part# = 2u3e-6d256-** ab for 4*4 & bb for 2*4.
The kits also have later part numbers for us$ 76 @ http://www.fordpartsonline.com
My parts order (without the balance shaft stuff) was:
$76.04 KIT-TENSIONER TIMING 2u3e-6d256-ab
$47.93 Engine, Camshaft and timing, Timing chain, TIMING CHAIN, Explorer, Mountaineer, Rear - 4.0L SOHC - 4.0L SOHC
$57.36 Engine, Camshaft and timing, Chain guide, CHAIN GUIDE, Explorer, Mountaineer, Jackshaft To Cam - 4.0L SOHC - 4.0L SOHC
$103.22 Engine, Overhaul gasket set, OVERHAUL GASKET SET, Explorer, Mountaineer, Upper (Valve Grind) - 4.0L SOHC - 4.0L SOHC
$28.93 Engine, Camshaft and timing, Tensioner, TENSIONER, Explorer, Mountaineer, Upper - 4.0L SOHC - 4.0L SOHC
Its worth mentioning that this procedure is not enjoyable at all and should be undertaken with at least 8 full days to completion (I recon you could do it in half the time the second time).
It is basically on entire engine re-build with both heads off and the engine out of the vehicle.
It is not possible to do the rear chain or sprocket with the engine in the car as the flywheel needs to come off + at least 1 head, but it is possible to do the front primary chain and or front cam chain with the engine in the car.
You will be a ford exploder and timing expert after you do this - the main reason should be the love of your American built vehicle. Its a solid car - except for the plastic guides!
Disclaimer Note: This is how i successfully did the job, but i am not a ford mechanic and don't hold me responsible if this does not work for you.
Timing Overview
A Small Sprocket on the crank turns a larger (2 to 1 ratio) jackshaft sprocket that is in turn connected front & back to the 2 camshafts.
Thus a 360o turn of the crank will turn both the camshafts 180o.
Firing order is 1-4 2-5 3-6, Right side numbers 1,2,3. Left Side = 4,5,6.
At TDC pistons 1 & 5 are fully raised, thus 1 is about to spark & 5 is evacuated.
The engine will turn freely (no piston to valve contact) with the cams 180o out, it will even run (roughly) with 1 out 180o, any other settings may cause major damage to the valves.
The 2 cam shafts come with timing markings, "yes" real timing marks that anyone can use (even without special tools) to ensure correct timing.
The way to time it is to ensure both the off centre cam shaft slits are level/flat with the head.
With the engine at TDC both the cams need to have the off centre slot in the same position either up and level or down and level.
It is super critical that both the camshafts are 100% in sink with each other, i.e. not a few degrees off, the engine computer can compensate for crank timing but not engineering failure.
Be warned the camshafts can turn easily fast & hard by themselves as a few springs are compressed at TDC, I got my finger jammed and its still healing + if the engine is not at TDC you may damage a valve.
Now heres the hard thing that you will need special tools for - if you need to change the timing, you will need to be able to undo the cam sprocket bolt on both cams & these are done up real tight.
There is a tool that you attach that has 2 pencil thick shafts that fit into the sprocket and prevent it from turning - then you need to put about 90Nm of force on the bolt (remember the rear one if LHT)
For the $money$, its well worth getting yourself the tool kit - it will save you hours in the long run. Search eBay for otc-6488 should be US $119 - then sell them again for say $100.
There is also a tool version of the oil tensioner in the kit that screws right in and puts the correct amount of force on the chain + guide, to enable you to do up the cam bolt with the chain and sprocket in the right spot on the cam.
Dec 20, 2010 | 2003 Ford Explorer
John Deere Model 445 garden tractor. Replaced plastic cam shaft gear, tried to start motor and it backfires through carb. I just removed front cover of engine to check the timing marks on both the camshaft...
Hi
Please check for the anti back fire solenoid in the front of the carb. Check whether the wiring to it is fine and if it is getting +12 V. If yes then you maybe required to replace the solenod.
However, if this doesn't resolve the issue then you would need to adjust manually so that decompresser works normally. Inspect the flywheel key as well, it may have sheared.
Check the carb filter and the make sure there is no sign of water in/around the carbeurater. Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
Daniel
Aug 04, 2010 | John Deere 420,1020,2010,2020,2510,2520...
How do u change the timing belt on a 1990 4 cylinder honda accord?
Disconnect the wire harness at the distributor.Remove the spark plug closest to the drivers side front tire. Place the palm of your hand over the valve covers empty spark plug hole and have a helper crank the motor over until air pressure pushes past your the palm of your hand. Next, look at the cam shaft wheel and note the direction that the arrow is pointing, the arrow should be pointing straight up IN RELATION TO THE ENGINE not the earth. If it is not, you will need to manually rotate the engine till the cam wheel is infact pointing straight up. Next, Jack up the front of the car and support it with jack stand and remove the front drivers side tire.Next, support the weight of the engine with a floor jack remove the motor mount closest to the drivers side tire To remove it you will need a deep 17mm socket on a heavy duty breaker bar. Next, loosen and remove the power steering belt and alternator belts. To loosen and remove the belts you will need a 10mm wrench and a 12mm wrench. And also a 14mm or 15mm wrench. Next, use a 19mm socket AND an air powered IMPACT wrench to remove the bolt holding on the crank shaft pulley. Next, remove the crankshaft pulley. Next, use a 10mm wrench and/or 10mm socket and remove the bolts holding the plastic engine side cover. Next, loosen the 14mm or 15mm bolt which secures the 2 belt tension wheels. Next, LOOSEN the 10mm bolt that is on the balance shaft tensioner. The balance shaft is the cogged wheel with a small timing mark dot on the side of the wheel. Next, loosen the 10mm bolt on the timing belt tensioner. It's obvious what wheel is the timing belt tensioner. Next, remove the 12mm bolt on the back side of the block (near the balance shaft) a little bit of oil will drip out, this 12mm bolt will allow a long bolt to be inserted into a recessed channel of the balance shaft. This recessed channel is needed to lock the balance shaft in place. A bolt from the air conditioner works great for locking the balance shaft in place. You're basically just pushing the bolt in a hole to keep the balance shaft from spinning.890a27a.jpg Next, remove both the balance shaft belt and timing belt. Then reverse the procedure to complete the new belt installation. EXTREMELY IMPORTANT!!!!!!!!! PLEASE NOTE, the oil pump wheel furthest to the left (closest to the radiator), has a timing mark on the flat face side of the wheel, that timing mark has to be pointing directly to the 9:o'clock position in relation to the engine. The cam wheel has an arrow on the side of one of the "spokes" ...make sure it is pointing straight up in relation to the engine...straight away from the crank shaft. Put the crank wheel on with the arrow pointing straight up to the center of the cam wheel.
Jun 28, 2010 | 1990 Honda Accord
I need to place timing chain on 1996 Chevrolet Cavalier. I need to know estimate of cost?
All shops charge differently. Call around. Plan on spending about 500 give or take.
Jan 12, 2010 | 1996 Chevrolet Cavalier
Cam shaft is not turning when i crank engine model 425 john deere
Sep 19, 2009 | Garden
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
350 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
