Question about Dell 922 All-In-One InkJet Printer
After installing new Dell 922 hi yield black catridge I get white lines through print & I don't know how to clean the printhead
White lines through lines of black print.
    Sergeant:
    Champion:
  • 212 Answers
Turn it off and restart it.
Posted on May 24, 2009
White lines in my printing and sometimes smudges of black ink
Hi
First before you buy a new cartridge,try doing a 'printhead' cleaning on your machine.Sometimes the printheads need cleaning clogginl.
Mar 03, 2012 | Office Equipment & Supplies
How do I print a negative black & white photo...it keeps printing a yellow tone image?
hi...while you give the printing command go to option and select black and white option. u can get black and white.
If u get yellow tone image means that the catridge of black might hav finshed please check the catridge and replace it.
Jul 05, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
When I try to print a black and white document it started printing in reverse (black prints white; white prints black). If I print a black & white photo it looks like a negative. I tried resetting the...
Kindly reseat the cartridges 2 time and then close the access door .Clcik on Menu on the printer and scroll down and choose Clean printhead and select "deep cleaning" Print a demo sheet after the cleaning process has been completed. If ur issue persists,Call Kodak @ 1800 421 6699 and they will replace printhead of the printer free of cost. Printhead is the part which takes the ink out from the cartridges.Probably the printhead of the printer has gone bad.
Nov 27, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Dell printer problem
This could be because of the fault in your printer head. Clean your printer head and try printing again.
May 02, 2009 | Epson Printer
I've installed a new coloured catridge but printer
did u remove the peel off cover that protects the contacts or the print head on the new cartridge?
Feb 17, 2009 | Dell A920 InkJet Printer
White lines through anything I print
Try to clean the catridges and alligned the print head from the front panel menu of the printer.
Regards,  raj_p5983
Jan 20, 2009 | Epson Office Equipment & Supplies
HP L7680 Printer Head Problem
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Step two: Increase the print quality mode
If reprinting did not help, try increasing the print quality mode.
In the application you are printing from, click File, and then click Print. Make sure the printer is selected, and then click Properties.
Select the Paper/Quality tab. In the Print Quality area, choose the next higher quality setting. If the current setting is Draft, choose Normal. If the current setting is Normal, choose Best.
Step three: Print in grayscale (black area streaking only)
If the streaks are in a black area of a black and white printout, change to grayscale printing.
NOTE:- This step does not apply to color printouts.
Make sure the printer is selected and click Properties.
Click the Color tab, and select Print Grayscale and High Quality.
Step four: Clean the printheads
If the print quality is still bad, clean the printheads.
Make sure the printer is loaded with unused white paper.
Open HP Solution Center.
Click Settings, Print Settings, and then select Printer Toolbox.
Click the Service Tab.
Click Clean Printhead, and then click Clean.
Step five: Align the printheads
If the print quality is still bad, align the printheads.
Open the printer Toolbox, and select the Printer Services tab.
Click Align Printheads. The Align Printheads window opens. Click Align.
The printer prints an alignment page. The lines in the patterns should appear to be straight. Click OK when the page finishes printing.
Step six: Calibrate the linefeed
If the print quality is still bad, calibrate the linefeed:
Open the printer Toolbox and select the Printer Services tab.
Click Calibrate Advanced Linefeed. The Advanced Linefeed Calibration window opens. Click OK .
Step seven: Replace one or both printheads
If the print quality is still bad after performing all the above steps, one or both of the printheads will have to be replaced. Print a PQ Diagnostic page to see which printhead should be replaced.
Press the Setup button.
Press 1 and * simultaneously.
Look at the color blocks labeled Test Pattern 2. Some or all of them could show white horizontal streaks. If none of the blocks are streaked, the printheads are okay.
If the Black block has lines – replace the KY printhead.
If the Cyan block has lines – replace the MC Printhead.
If the Magenta block has lines – replace the MC Printhead.
If the Red block has lines – replace the KY printhead.
If the Green block has lines – replace the KY printhead.
Nov 08, 2008 | HP Officejet 5610 All-In-One InkJet...
Lines through Pictures
This sounds like a clogged print head. If you have gone through the cleaning process already take a cotton swab with alcohol and clean the head yourself. If that doesn't work you may need a new cartridge all together.
Here is a good article for that issue.http://articles.techrepublic.com.com/5100-1035_11-1043849.html
Dec 11, 2007 | Dell 922 All-In-One InkJet Printer
Black stopped printing out. Dell 922 all-in-one ink jet.
clean contacts on back of blk cart and printhead with alcohol on micrfiber towel
Oct 14, 2007 | Dell 922 All-In-One InkJet Printer
Dell 922 All-In-One InkJet Printer Logo
93 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
