Question about Olevia 237T 37 in. LCD TV
Blows fuse internally when tv powered up
Plug in the tv as soon as you turn on the power it blows the fuse inside is there any known problems that makes this happen you know of
    Sergeant:
    Champion:
  • 212 Answers
There is a short in it somewhere. check the ground.
Posted on May 24, 2009
I have a Sony TV model number KDL-46VE5 it doesn't turn on, there is no red power light when I plug it in and I have tried several outlets, can u help me figure out what's wrong with it.
check the fuse inside the power plug
check for any internal fuses blowing.
If these are all right it is probably something to do with the power supply to it.
Using a multmeter I would check that the set is receiving power. Next, if power is reaching I WOULD CHECK FOR DAMAGED CONDENSERS/ CAPACITORS ON THE POWER CONTROL CARD....SEE LINK BELOW FOR POSSIBLE REMEDY
https://www.youtube.com/watch?v=I8teB16U0LA
Jun 17, 2015 | Sony Televison & Video
19 in lcd sharp keeps blowing fuse
check the primary section of the powersupply mostly diodes and transistors inside and alo there filters.
Feb 06, 2013 | Sharp 32R-S50 32" TV
All power outlets went out. I replaced the fuse in the side panel but, as soon as I plug anything in, I can hear the fuse pop. I have checked all the other fuses andit is the only one that is blown.
You will need a new power outlet / cig lighter socket. The side tabs can get bent, and it will internally short and blow the fuse, whenever something is installed. Visually look inside the socket to see if the 2 side tabs (ground) are bent inward or downward. The center dot at the very bottom is the power, if it touches the sides or the tabs it will blow the fuse. It could also be the appliance you are plugging in, try something different (like a phone charger).
Apr 08, 2011 | Dodge Durango Cars & Trucks
Heard a pop then screen went blank. Now TV wont turn on.
Sounds like your fuse.
If not the fuse in your plug, then the internal fuse in the TV. to get too this you need to open the TV by taking off the back plastic panel and look at the fuse.
the fuse is the glass tube on the board, will no doubt be near where the power cord connects to the TV. and are easy to replace with another fuse. you will know soon as you open it if its blown as the little glass tube will be blackened or the little wire inside the tube will be missing or severed.
Fuses in TVs are actually designed to blow over time with ware (usually to last a bit longer then the warranty time frame) so after the cover has ended the TV can go in for repair work at extra cost. Its a little known fact.
Jan 02, 2010 | Sony KDF-E42A10 42 in. LCD Television
My tv just went dead. No power. I have a 1080p plasma that is about 5 years old.
Sounds VERY silly but did you make sure the fuse in the power cord is ok? Usually it's just the fuse, also with the guarantee, now no doubt now finished on your TV, open it and check the internal fuse, (little glass tube kept in place with metal on each side) usually pops in and out so can be replaces by repair shops.
Internal fuses are usually located near the power area of the TV inside the outer shell (so you need to take the plastic back off the TV)
To be honest fuses are designed to blow over time, usually after the guarantee timeframe, this is to act as a finance booster for the company that made the unit. Just a little known fact but true none the less.
Hope this has helped
Jan 01, 2010 | HP PL4260N 42 in. Plasma HDTV
Tv keeps blowing fuses when its plugged in...
There should not be any reason for the new TV to blow a 15 amps fuse in the house.
The TV has an internal short circuit even if it is new, I would suggest to return it and get another one.
Good Luck.
Jan 06, 2009 | Televison & Video
TV NO POWER
internal fuse, small 2 amp slow blow, check both, some times white coated inside when blows turns brown in middle, voltage spike problem
Jul 25, 2008 | Samsung Televison & Video
My TV doesnt turn on. where is ther fuse?
The fuse should be near where the line cord is attached to the power supply inside the TV. Be careful as there is a possibility of some DC voltage present from filter capacitors still holding a charge, long after the set is unplugged. If a fuse is blown and blackened, a new fuse will probably do the same when the set is plugged back in. Make sure you use the exact same rated fuse. IF the new fuse blows right away, do not repeat the process, it will only cause more damage. Good Luck.
Feb 11, 2007 | Samsung HCJ552W 55" Rear Projection...
Microwave not works
WARNING: Microwave ovens are the most dangerous consumer appliance to service due to up to 5,000 V at high current inside. Even with the power off, there is a HV capacitor that can produce a lethal kick. This capacitor must be discharged before touching anything in the microwave generator circuitry. DON'T remove the cover yourself unless you fully undertand the SAFETY issues involved in working inside a microwave oven. A microwave oven is possibly THE MOST DANGEROUS common consumer product to service. About the only "easy" fix would be a blown fuse, if it keeps blowing, don't go any further unless you know what you are doing. Your likely options are a blown high voltage cap, diode, or the magnetron. Good luck(but luck has nothing to do with it ;] )
Apr 01, 2006 | Sharp R-320H Microwave Oven
Olevia 237T 37 in. LCD TV Logo
244 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
