Question about Gateway 2520915 Keyboard
Trying to open Gateway desktop keyboard
Trying to thoroughly clean gateway keyboard. Bought computer in 2002. Back shows Model P/N RT3602V:5STW E, with 7003604 under barcode.Have all the screws out, keys off, but there seems to be something holding it together in the middle. Can I just pop it open or will that mess it up so I can't put it back together again?
On the gateway keyboard that I took apart, there were an additional four screws under the rubber feet (one to a foot) on the part of the keyboard closest to me when it is oriented for typing - the space-bar side. The must be removed as well. if it doesn't just pull apart - with ease - then look for more screws.
Posted on Apr 13, 2011
I took my gateway keyboard apart after 5 years for a good cleaning. The screw hidden behind the label is the key. After you separate the top keyboard intact with keys you will find a thin layer of rubber like material that completely covers another thin plastic layer beneath it that has the diagram on it. I removed the rubber and washed it in the sink as well as washed both sides of the top keyboard. I took canned air and blew out the excess water and then used a hairdryer to completely dry it. Then to make sure I got all the water I used canned air again on the underside of the top part of keyboard. Reassembled it and am using it to type this now about 15 minutes after I reassembled it.
Not difficult at all.
Posted on Aug 24, 2010
  • Gateway Master
  • 5,568 Answers
There is often one screw covered by a lable; this just serves as a 'warranty voided' sticker.
If there are none in the middle, carefully pry (with one of those credit cards you have been meaning to cut up) since often plastic housings are provided with a point or two that snaps together to hold things until the screws are inserted.
I generally clean mine (too infrequently) by holding it upside down and using a new paint brush to urge the majority of the 'stuff' out, then clean and dampen the brush with window cleaner and again, upside down, go between the keys to loosen the crud.
Once you have finished this, use absorbant paper towels and that (no longer clean but somewhat dried) paintbrush to remove the last of the moisture.
Depending on the quality of the keyboard, the key markings shouldn't be affected by the gentle scrubbing of them. If you are unsure, just try the window cleaner on a single key not used often.
Posted on May 24, 2009
    Sergeant:
    Champion:
  • 212 Answers
I wouldn't. I would **** debris out with a vaccum.
4 Suggested Answers
SOURCE: Gateway keyboard types wrong characters
Same keyboard, same problem for almost 2 years now, and just now figured out how to fix it!! Try a simple left ctrl-shift, your language tab up top will switch between US English/Canadian English/Canadian multilingual, or whatever you set it for. I occasionally want the alternate characters applied, so now I can switch back and forth easily. You may need to set the language tab to your preferred settings. Hope this helps!
Posted on Feb 05, 2008
rtrahan
  • 741 Answers
SOURCE: Letters on Gateway desktop keyboard not working. Tried Rebooting.
First check the Device Manager and see if there is a problem with the device driver. If you see a yellow! or a redX, then right click on it and choose to update the driver. In fact you may just update the driver anyway, it will not hurt anything. If updating the driver does not work there is not much else you can do with a keyboard; they are pretty simple machines. You may have to just replace it.
Posted on Dec 27, 2008
SOURCE: Keyboard beeps when any key is pressed
I found out what was wrong in my case. Someone had tampered with the accessibility options
So for anyone with keyboard problem check :
In Windows XP : control panel-> accessibility options -> keyboard : StickyKeys and Filterkeys checkboxes should be unchecked.
In Windows Vista : Ease of access -> Ease of access center -> keyboard : StickyKeys and Filterkeys checkboxes should be unchecked.
Posted on Feb 23, 2009
My gateway wireless mouse won't sync
- Have you tried the steps mentioned in the link to connect a wireless keyboard and mouse to the Gateway computer? http://support.gateway.com/s/desktop/2009/gateway/zx/zx4800/ZX4800faq3.shtml
http://www.support.gateway.com/s/Manuals/Profile/WirelessKb_MouseGuide.pdf
Also follow the generic troubleshooting steps mentioned in the link to connect a wireless keyboard and mouse to a computer.
http://support.microsoft.com/kb/838398
Note: The steps provided in the link mainly works for Microsoft hardware but the steps can be applied to any wireless keyboard and mouse. Do not install any software given in the link as it will not help you if you do not have a Microsoft Hardware.
It would be helpful if you could provide us the exact computer model number and also the make and model number of the keyboard and mouse.
Feb 14, 2015 | Gateway GM5664 Desktop PC
I have a Gateway GM5072 I think the fan is going out. it speeds up and while it is running my computer gets real slow I think a fan is going out? will that make my computer slow down? I need to know what...
Hello strabley,
Have you ever cleaned the inside of your computers? Close it down completely disconect the power source, open the side panel and wit a compressed air can clean the fans and remove all dust accumulated on the peripherals ,
You should see some chromed screws on the back panel take them out and slide the side panel towards the back see the gateway tutorial here http://support.gateway.com/s/tutorials/Tu_842243.shtml
Hope this helped
Aug 02, 2011 | Gateway GM5072 Desktop PC
Hi, im trying to install windows 7 ultimate onto my gateway. I bought it retail from best buy and am having problem with the install... is it factory set for me not to be able to install an operating...
If you bought a full retail version and not an upgrade, you may need to do a fresh installation of windows. You also need to make certain that your gateway model is able to upgrade to windows 7. Checking your computer's support page, there are no BIOS updates available. Your computer should be fully capable of upgrading to windows 7 from windows Vista. ALso looking at Gateway's support page for this model, there are no drivers offered for Windows 7. All drivers offered are for windows Vista. I have seen computers in the past that will not tolerate an operating system change from the system that was installed at the factory.
If you have a restore partition, you can back up your data, and do a clean install of windows after formatting your hard drive. You may also want to make recovery disks for your computer in case the Win 7 will take on your computer or you cannot get your hardware to work with Win 7 since Gateway offers no Win 7 drivers.
Good luck. Take precautions to back up data and be able to revert to your original factory settings if necessary.
Feb 24, 2011 | Gateway GM5626 PC Desktop
I have a Gateway DX-4200-09 64 bit with a Gateway keyboard model no KB-0817. For the last 6 months every time I reboot I get this error message "multimedia keyboard driver has stopped working". ...
The factory installed drivers and applications can be re-installed by using Gateway eRecovery
Click Start, and then All Programs
Click Gateway, and then Gateway eRecovery Management
You may be prompted to enter or create a password. This password will be required to use eRecovery in the future.
In the next window on the left toolbar, select Restore.
Choose Reinstall Drivers or Applications
Choose Contents
Choose the driver or application you wish to install
On the right, click the Install link and follow the prompts.
The computer should restart when installation is completed. If it doesn't restart, manually shutdown and restart the computer by pressing and holding the power button until it powers off. And then start it as you normally do.
Don't forget to rate this if it helped fix your problem.
Jan 14, 2011 | Gateway DX4200-UB001A Desktop Computer
I have a gateway 2002 model. I am trying to open
Hello,unscrew the two screws that are at the rear left.I think are bigger that the others and pull the side cover toward you or move it on the left and is open:)
Feb 06, 2010 | Gateway GT5220 PC Desktop
Want to open gateway keyboard to clean
I wouldn't open it. use a vaccum to **** the debris from it.
May 24, 2009 | Gateway Computers & Internet
Gateway USB ports stopped working
So maybe you need to install the drivers for the USB device you are trying to connect. Also, with the computer off, try cleaning all USB ports and plugs. You can buy electrical cleaner in a spray can at Radio Shack. Let it dry thoroughly before powering up. But to me it sounds like a driver problem. Unless maybe your USB BUS is going bad.
Jan 06, 2009 | Computers & Internet
Loud noise
Typical problem in most computers, the fan is experiencing a "burn out." This means there is either something caught in the fan causing it to create noise, or the motor is going bad. there are two fixes for this problem.
1) open you computer's case according to its manual and remove the system cooling fan and give it a thorough cleaning.
2) you may need to replace the cooling fan with its recommended replacement model.
Hope this helps!
Jul 08, 2008 | Gateway 506GR PC Desktop
Gateway 2520915 Keyboard Logo
850 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
