Question about Lite On Laars Lite 2 Heaters: 250,000BTU MV Heater
Cannot screw in plugs on side of Laars Lite 2 Pool Heater
The screw (plug) looks to be in decent shape. When I try to screw it in, it will not "catch". I have spent several hours on this and now am ready to throw in the towel.
I just had the exact problem. Went to a plumbing supply house and got a 1/4"NPT pipe tap for about $10 and a 1/4" brass pipe plug. Put some oil on the tap and very carefully clear the threads by threading it into the hole. Make sure it is straight and engaged with the threads. Once started run it in by hand until it stops and then get a small wrench and turn it about a half turn and then back a quarter turn for a couple of full turns and then remove. Inset the new brass plug
This did the trick for me, good luck.
Posted on May 28, 2009
    President:
  • 3,433 Answers
What are we trying to do? Maybe I can help
Posted on May 26, 2009
How we can differ with Custom Domain and Essentials Design?
The main distinction between the programs is that with web design singapore, the designs square measure ready-to-go. the placement is complete throughout per week as a results of the majority of the work is completed already. Custom sites square measure ready in two to some months, as we've got a bent to pay several hours researching, planning, coming up with and building a company's distinctive internet presence. As a result, there is jointly a giant worth distinction. For corporations on a decent budget, or looking for a simple apply house information processing system, wants is that the quick and easy resolution. Singapore Web Design Development Company Singapore
Feb 22, 2016 | Computers & Internet
Laars Lite 2 Heater will not go on
make sure little pump is moving if not check syphon tube going to pressure switch if ok check pressure switch
Jun 29, 2013 | Teledyne Laars Laars Lite 2 Pool Heater...
Gas pool heater model no.lg125p laars lite 2 max.gas preesure 14.
should be between 9 and 10 on front side manifold side should be 3.5
Feb 10, 2013 | Teledyne Laars Laars Lite 2 Pool Heater...
Have an LG icemaker that is not working and needs removing. Tech showed me how to do that if it happens to not work again. I have the screws removed but can't get it unplugged (icemaker only) is there a...
there are catches on the plug that secure it from accidentally unplugging,some you squeeze and some have tabs in the side of the plug that need pressing to release the plug
Mar 22, 2011 | LG LFC20740S
Need to know where the electric supply goes in on the teledene laars epg-175
About two thirds down the right side of the heater. Inside the ignition control will have one screw that holds the mounting plate in place then it will swing out on hinges and all your wireing will be done behind it.
Jun 24, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
F51 error code on wtw6700tw washer. Lost the tech
Was a far easier fix for me than all this RPS sensor hunting. For my machine's F51 error, there were socks lodged between the inner and outer tubs, causing too much friction on the motor. This led to the computer reading poor performance of the motor. Please consider trying this easy fix before calling out service personnel or replacing circuitry!!! I spent hours under the machine messing with the motor and circuitry until I looked up at the translucent tub and saw stray laundry stuck where it shouldn't be.
* Open the lid. Turn the bottom agitator by hand. Give it a good push. It should continue rolling on for several turns. If not, there is laundry stuck between the tubs causing friction.
1.) Pry open the metal case lid. Take two flat head screwdrivers and wedge them in the crack about 6 inches from the left corner, and use them as levers to pop the metal lid, then the right corner. Lift up the metal case lid and lean it against the wall.
2.) Take off the plastic ring that bridges the gap between the inner and outer tubs. There are many little catches all around the perimeter of the outer tub that hold on this plastic ring. Find those catches and put outward and upward pressure on those to release the catches.
3.) Look down in the gap between the inner and outer tubs for stray laundry. I used a retrieval tool, below, to grab the socks. There were especially several socks in the back right corner near the pump inlet. Run the drain and spin cycle and look again. There were more strays hiding that I nabbed the second time!
4.) Snap the inner cover on by lining up all those catches and seating them. Snap the big metal lid back on by aligning and giving a good downward thump. Run the machine and be the hero, and don't be too mean to your wife about tossing those socks down in the crevices. Half hour and $3 for the retrieval tool is far better than all that RPS nonsense.
May 03, 2010 | Washing Machines
My Husqvarna 128 LD bogs down and quits running
Dirty air filter, dirty fuel system, ie carb, lines, fuel tank. Poor air fuel mixture srew adjustments.
Apr 27, 2010 | Husqvarna 28cc Gas Line Trimmer
I have to unplug and plug back in to get tv on
This will be down to bad capacitors in your power supply, Take the back of your tv look at the power supply and look for bulged capacitors ( domed shaped on top ) they may also be leaking a brown liquid substance, replace these and that should cure the fault.
Mar 05, 2010 | Sony Bravia KLV-32U300A 32 in. HD-Ready...
Heating & Cooling Logo
163 people viewed this question
Top Lite On Heating & Cooling Experts
1STHVACMAN
Paul Carew
Michael Galve
Michael Galve
Are you a Lite On Heating and Cooling Expert? Answer questions, earn points and help others
