Motherboard?.. blank screen.. no post.. powering over and over
I believe i may have a motherboard problem..... the pc wont post, the HD isn't spinning.... no screen output.... just keeps powering up and down over and over
  • nytkrwlr May 24, 2009
    model # is HP pavilion dv9408nr tried reseating the internal battery and some other power things.... removed the HD and the DVDR/RW drive.... still didn't post. reseated the RAM.... still just a christmas decoration with flashy lights
  • Jim Goldsmith
    Jim Goldsmith May 11, 2010
    what type, model# of computer tower, laptop?
    Problem Solver:
  • 13 Answers
Sounds more like a power supply, you might try disconnecting as many devices as you can from the mother board (CD, Floppy, HD ect) and see if it will post then.
Posted on May 24, 2009
  • 1,869 Answers
The infamous power switch cable problem
you will most likely have to dissasemble your computer and seseat the tape cable that goes from the power button to the motherboard see: HP.com/support/manuals as to how the computer comes apart these are a pain they always fail
If you need a new one go to e-bay and, buy one there it's much cheaper than HP
HP dv6000 Lights up but that's it.
Re : When i press the power button, the lights all light up, the cd rom drive spins for a second and that's it. No fan, No Post, Blank Screen. After a few seconds, it shuts off and then turns back on.
That is generic hardware fault, any faulty device can cause the problem.
The motherboard must be started with a minimal set of devices to troubleshoot.
Start motherboard with only CPU, power adapter connected (faulty battery can cause the problem), heathsink, display and one memory stick. Keep unplugged HD, optical units, keyboard, minipci cards etc.
If problem persists, eventually test the motherboard using a post card(PCI & ISA PC Diagnostic POST CARD MOTHERBOARD TEST CARD) to ensure that new motherboard is not faulty, and then if cpu has not been replaced with the motherboard, replace CPU.
Jul 18, 2009 | HP Pavilion dv6000t Notebook
Blank screen on hp pavilion s5300z
Either VGA or motherboard issue... What were you doing when this first happened?
Jan 27, 2014 | HP Pavilion Slimline s5300z PC with AMD...
Computer has power, hear the fan and HD trying to run however nothing happens, blank screen. Plugged in external monitor and still black screen
HP laptops have several problems with GPU overheating. Could also be a bad stick of RAM or a bad hard drive. You will need to remove each one and try to power on after each is removed. If still wont light up the screen you probably have a motherboard problem with the video chip (AKA: GPU processor)
Jan 17, 2011 | HP Pavilion dv7-1240us Notebook
Hi, I have a HP Pavillion dv2601 Special Edition. The system switches on but the screen is blank. Some say the motherboard is gone, some say this is due to battery problem. Even if I run it directly with...
Look closely on the power,num lock,cap lock on your next power up.
ALL THREE will light up at the same time during the boot process.
THEY MUST lite up at the same time.
This is call POST.
NO POST will = a bad motherboard.
==== If they all lite up and no screen display then it is a back light,LCD or ribbon cable problem.
I recommend you start a CHAT session at Fixya.
I don't think you can get an answer by email/posting method.
Aug 11, 2010 | HP Pavilion dv6000z Notebook
Acer Aspire M1100 desktop will not boot or respond
sounds like a motherboard or HD problem, If you can try the HD in a different pc to see if it can be recognize, also don't forget to setup you pc to boot the HD first.
Jul 03, 2009 | Acer Computers & Internet
Computer will seem to start, but
if the screen comes up and goes blank again,
1.Remove and replace your RAM with a known good RAM to test with, if it persist or continue, then
2.repair your operating system by re-updating it,this will help it to recover from the missing files
Apr 24, 2008 | E-Machines eMachines Desktop PC
PC powers up but wont boot
I would start with a new power box, then a motherboard. then the hard drive.
Dec 23, 2007 | Computers & Internet
PC totally locked
The flashing power switch and power supply LED on the rear in conjunction with a power failure or surge indicates that there is a defective component; typically the power supply, motherboard, memory, processor or modem. -Disconnect all the power supply leads, drives, and motherboard as well as any USB, firewire and other external devices. -Plug in the 115v power supply cable and look at he LED on the back of the power supply. If it is still flashing the power supply is bad and needs to be replaced. -If it isn?t flashing then unplug the power supply plug in one device, plug in the power cord and watch for the flashing LED again. If it?s flashing you?ve found your culprit, if not move on to the next component and repeat the process until you?ve found it. Don?t forget your plug in cards could also be the problem. Good luck and let us know if you have any other questions. As always please don?t forget to rate this posting.
Jan 27, 2007 | Compaq Presario SR1120NX 2.66GHZ Tower w/...
Computers & Internet Logo
560 people viewed this question
David Payne
David Payne
