Question about 1995-1997 Chevy Suburban Ignition Starter Alarm switch
Will turn over but will not start
Our 1997 Chevy suburban will turn over but will not start. My husband checked the fuel pump relay but could not determine if that was the problem- how would we know?
    Problem Solver:
  • 3 Answers
1999 sub,
turns over but will not start. Somewhat solved: there is a fuel line on the air cleaner side that is somewhat stomped up. When the hose is blown in and then reinserted, the truck starts. It will run for awhile but eventually it will clog again. Good luck.
Posted on May 28, 2009
    Sergeant:
    Champion:
  • 212 Answers
When turning the key on you should hear the fuel pump turn on for a sec or so.take 2 people one turn the key and the other listen by the fuel tank. It might also need a new distributer cap, plugs and wires.
Posted on May 24, 2009
My Chevy Suburban has spark and turns over it just will not start the engine what should I do
Check fuel pump relay circuit ! GM Fuel Pump Relay Testing Or take it to a ASE certified repair shop or the dealer !
Aug 26, 2015 | Cars & Trucks
I have a 1998 GMC Chevy Suburban it starts but then it stops I've checked the fuel relay, starter fuel pump. I put starting fluid in it and it starts with his shirt off why is it doing that?
Part 2 -Troubleshooting the Fuel Pump (GM 4.3L, 5.0L, 5.7L)
troubleshootmyvehicle.com > GM > 4.3L, 5.0L, 5.7L
May 5, 2011 - The engine will start momentarily and after a few seconds will die or... 2.... Tahoe. 1996, 1997, 1998, 1999, 2000. GMC Vehicles: Sierra C1500
Aug 18, 2015 | GMC Cars & Trucks
1997 Chevy Suburban Changed fuel pump fuel filter relay new battery engine turns over but will not start. Getting spark. Took off fuel lines going in top of engine not pumping fuel. Any suggestions
There is a fuse that deals with the fuel pump circuit through the ECM. If you haven't checked it's in the fuse panel under the hood in the engine compartment on the drivers side by the brake master cylinder. I hope that you have a cover for it with the names of the fuses. The fuse you want to check will be the fuse marked "ECM B". I gave you a picture of the fuse layout but it's not a good one but I did put an arrow to the one I think it is. I pretty sure that's the one but not 100 percent because it's pretty blurry. In any case there is a fuse marked "ECM B". I would check there if you haven't already. Other than that You may have to check your wiring. There is a fuseable link at the starter you may want to check if that fuse isn't blown. I hope this helps and good luck.
Aug 04, 2011 | 1997 Chevrolet Suburban
Truck won't start
If it has a vortech V8 It has to have the right fuel PSI or it won't start. Also pick up in distributor could be causeing problem. Cross over style distributor cap also can cause problem. Out of oil? Fuel pressure regulator where found inside the intake manifold with injector cluster, if fuel psi regulator goes bad could be leaking fuel in intake causing oil to get deluted and burn.
Jul 28, 2009 | 1999 Chevrolet Suburban
92 Chevy Suburban Electrical Fuel System
Check fuel flter at fuel pick-up intank (looks like a small wire sock). Remove fuel filter and fitting at fuel rail. Blow out fuel lines w/about 35lbs air press. Ck electrical @ relay - should be 4 connectors - one is key on hot/one is always hot/one is ground and last is hot to fuel pump. Good Luck
May 03, 2009 | 2002 Chevrolet Suburban
I assume the fuel pump fuse is good?
The only time voltage will be sent to the fuel pump will be the first 2 to 3 seconds if the starter is not engaged. You will want to crank the engine over and check for voltage on the load side of the relay, circuit #30 at the relay.
Let me know after you check.
Regards,
Feb 22, 2009 | 1992 Chevrolet Suburban
97 chevy suburban wont start
try putting a dab of solder on each one of the contacts on the fuel pump relay. i had a similiar situation where the relay contacts in the fuse box got strectched out over time so i put a dab of solder on each terminal to beef the contacts up and it worked perfectly. i think this will work because if the mechanic put a wire jumper in the contacts then electrical it is fine.
Feb 14, 2009 | 1995-1997 Chevy 1500 Truck Ignition...
Fuel system not working
  • hello, have you checked the fuel pump relay?
  • It´s located in the fuse box in the engine compartment.
Jan 06, 2009 | 1995-1997 Chevy Suburban Ignition Starter...
1995-1997 Chevy Suburban Ignition Starter Alarm switch Logo
1,358 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
