Goodman GMS90703BXA Heater
Problem for Goodman GMS90703BXA Heater
Cool turned down to 65 and it is still 81 in the house
By jorn1956 on May 24, 2009
Goodman heat pump one year old. It sounds like the fan is running but maybe not the compressor. It is blowing cool air but not cold.
Clarification Request
Posted by jmgldsmth on May 24, 2009
while it is running place your hand on the compressor and feel for vibration
Posted by jumptrout51 on May 24, 2009
Do you have a amp meter?
Best Solution
posted on May 27, 2009
Very Helpful)
Your an idot
Rank: Guide
Rating: 92%, 9 votes
to see if the compressor is running feel your line set the liquid line
(small line) should feel like there is fluid flowing though it, you can also disconnect the o/d fan briefly if you want to be certain the compressor is running, it best however to get a meter and amp clap to do a proper diagnosis, you are limited to your tools as well as your knowledge, call an NATE certified professional.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Goodman GMS90703BXA Heater
Questions and Unsolved Problems for Goodman GMS90703BXA Heater
Do you recommend Goodman GMS90703BXA Heater?
Answer
Answer
I have a goodman furnace and need to make a connection to the common terminal on the circuit board... (More)
Answer
goodman gmpn 100-4 blinks once and will not start
Answer
GUI 125-4 pilot assembly from standing pilot to sparking unit - how do you install?
Answer
I have the blower assembly apart. I have a liquid teflon sealer with a maximum temperature of 550... (More)
Answer
I took out the blower and replaced the motor. but can not find my wiring diagram for a gms9/gcs9.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Goodman GMS90703BXA Heater:
Top Heater Experts
Rank: Guru Guru
Solutions: 1220
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Heater Experts
Top Heater Repair
(888) 448-9872
Nationwide plumbers where ever you need us any...
plumbingcoop
(800) 905-9506
Traditional water heaters use a storage tank to...
Plumbing Key
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
