Question about Honda Garden
8 hp honda on cement mixer starts on first pull but shuts down as if it is running out of gas. I put fresh gas in it and cleaned the filter and bowl of the carb.
My engine starts on the first pull but only runs for a couple of minutes and then acts as if it is running out of gas. The tank is full. I changed the gas and took the bowl of the carb cleaned it and put the bowl back on. It starts but shut off after a short time.
    Sergeant:
    Champion:
  • 212 Answers
If it has a fuel filter. check that. change the spark plugs.
Posted on May 24, 2009
Wont start
Flush gas tank, fill with fresh gas and Stabil. Replace air filter. Remove bowl from carb clean bowl and holes in bowl screw.
Mar 07, 2014 | Honda Gxv160 55hp 55 Hp 25mm Dia Lawn...
I have a toro super cycler gts 5 model 20475 6.0 engine i put new gas in it a new spark plug but if i loosen the gas bowl no gas come out and it wont start what could be wrong
Ensure fresh gas is in tank. Follow gas line from tank to carb. Have locking pliers ready to pinch off gas line or close gas line valve. Remove gas line from carb. observe gas flow to carb. Remove carb bowl from bottom of carb. Attach gas line to carb. Does gas flow to carb. Observe float, float down gas flows, float up no gas flow. If float is bad replace float assembly or carb. Remove float mounting pin and needle metering valve. Use a bread wrapper pealed back an inch so thin wire can clean out port of meter needle. Use wire to clean out center port. Observe bowl screw look for hole thru screw, clean out with wire if preset. Re-assemble carb. Clean replace air filter. Fill oil. 30w. Prime motor, pull rope 10 times to start. No start, replace carb.
Aug 02, 2013 | Snapper 20 HP Lawn Tractor 2690578
I have the Husky 2600 I got it to start it will run for about 10 min.then it will shut down.I can restart it then it does it again
This is sometimes caused by dirt or debris in the fuel tank, carburator float bowl or in-line fuel filter if it has one. When you start the motor the dirt is settled down and the motor runs fine. While the motor is running, the vibrations and fuel flowing through the system agitates the dirt and it eventually plugs the filter or jets. When the motor shuts down the dirt settles down and the process repeats. Replace the in-line filter if it has one and clean out the float bowl on the carb. While you have the fuel line off, let some gas flow through the fuel lines to flush them out. If dirt is a problem also check your gas can(s).
Feb 26, 2013 | Honda 2500 PSI Gas Pressure Washer
Honda 8hp motor only starts with quick-start fluid
if you have gas to carb rebuild carb or relace
Jul 07, 2012 | Honda 8 HP Engine
I have a yamaha ttr230 and since i have pulled it out of storage this spring it cant make it run right. It starts fine and idles but a soon as any throttle is given it dies out . I have put fresh gas in it...
G'day, sounds a bit like the float valve in the carby might be stuck nearly shut or just some moisture in the carby, a light tap with the handle of a screwdriver on the side of the carby bowl should fix it if it's the needle stuck shut (happens from sitting sometimes), or maybe try loosening the drain screw in the bottom of the carby bowl to drain any water etc out, hope this helps :)
Apr 11, 2010 | 2004 Yamaha TT-R 225
After 1 season it ran great ,slowly died now it wont start
So many possibilities, so little data... <grin>
When you say "clean gas", do you mean that you added "fresh" gas, or that you emptied the tank, and refilled it with "fresh" gas?
Try this:
a. remove the "float bowl" screw, and put a regular "bowl" or pan underneath to catch ALL of the gas as it comes out.
b. if the gas is totally "clear", then it (probably ain't the gas), but... if it's "yellow", it's old and/or contaminated; alternatively, if there's any water (which may appear as a grey-ish liquid) then it's contaminated; also, don't forget to check the gas from your "storage" can, the same way...
c. re-install the the screw, and put some *FRESH* gas in the tank.
d. pull the spark-plug, and clean (or replace) it.
e. prime it, and crank it, and it should start right up.
Jul 03, 2009 | Poulan Pro 22" Self Propelled High Wheel...
Craftsman eager-1 3.75 mower will not stay running
the engine is not getting enough gas. when you hold down the primer you are bypassing this problem. to fix this simply adjust the carb's fuel screw, located on the side of carb, a little at a time until runs smoothly.
Jun 24, 2009 | Craftsman Garden
Our 2000 Yamaha TT-R125L engine won't fire. It is a kick start
Here are a few things to do >>
How old is the gas in the gas tank? Get fresh fuel.
Remove the water trap bowl at the bottom of the petcock, (gas valve). Any water or trash in the bowl? Drain a cup of gas from the tank. Is there any water or trash in the cup? Clean the bowl and filter screen if present, then re-mount them, ( not all bikes have a water trap bowl or screen ).
Install a new stock NGK spark plug and try to start the engine. If the bike doesn't start and run properly then shut off the gas and remove the carburetor from the engine.
Remove the float bowl and clean the entire carb with a spray carb cleaner from the auto parts store. Wear protective goggles to avoid getting spray in your eyes. Spray into all the little airways and fittings in the carb. Remove the two screws on the outside throat of the carb and spray into the screw holes as well.
< < READ CLOSELY > >
Be sure to put these two screws back in the same hole they came out of. IMPORTANT > do not tighten these two screws down. Only screw these in until they LIGHTLY seat. Now turn each screw one and one half turns outward. Put the rest of the carb back together, clean the air filter and install the carb. Let the float bowl fill then start the engine. Set the idle speed with the idle screw.
I am uncertain if the bike has ran for you or not. "Did pull the spark plug and kick started it." If the bike still will not run then the cam chain may be out of time. Why was the tensioner off the bike?
Please rate this solution. Thanks budx5!
Apr 04, 2009 | 2002 Yamaha TT-R 125 L
Honda 5.5 HP starts & dies
had the same problem with my Honda engined mower. you can't see it easily, but there is a very fine screen in the outlet of the fuel tank that gets blocked and fuel will not pass thru it fast enough to refill carb. remove tank and pour fuel in another container . Use a flexible plastic tube in the outlet or make a small wire hook to penetrate the screen,or preferably, remove it. confirm that fuel flows freely thru it, remove any debris, and reassemble. Change spark plug, add fresh fuel,and test. best of luck!!!! Ray
Dec 18, 2008 | Honda Chipper Blower and Vac: 5.5 Hp Gas
Garden Logo
496 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
