Question about HP Officejet Pro L7780 All-In-One InkJet Printer
Problem with printout on hp7780
When i print a page on the 7780 the black color doesn't print completely, it skips between lines. can this be a printhead problem.
  • 822 Answers
Clean your black cardriges and calibrate.
Posted on May 24, 2009
Black ink is skipping lines
Take out cartridge put in a sandwich baggie and shake it; then re-install
Sep 25, 2014 | Canon PIXMA MP610 InkJet Printer
Hi. I replaced the black cartridge (yellow almost empty) but if I print a page (only black, the printer skip some lines. Can you please assist me? Surene Whiteman
Printer contain 4 cartridges and 2 printeads. Because the black color skip some lines as you mentioned you need to replace a new printead(not the cartridge) No:88 Black/Yellow color one. For more information visit the following link: http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=&cc=us&docname=c00841890&product=2512009
Jan 24, 2013 | HP Officejet Pro L7680 All-In-One Printer
HP L7700 officejet printer leaves streaks on black ink lines only. Have cleaned heads repeatedly, changed black and color cartridges - nothing works.
Print in grayscale (black area streaking only) If the streaks are in a black area of a black and white printout, change to grayscale printing.
NOTE: This step does not apply to color printouts.
  1. In the application you are printing from, click File , and then click Print .
  2. Make sure the printer is selected and click Properties .
  3. Click the Color tab, and select Print Grayscale and High Quality .
Nov 28, 2009 | HP Office Equipment & Supplies
No black when printing color
Dear Sir,
You are getting black lines in green color,and apperence of parallel light and dark lines because your colour catridge is almost empty.So solution is replace the catridge and take a printout. There is no proplem with a printer. i think it solves your problem.
good luck
chandrashekhar
Jul 29, 2009 | HP OfficeJet 4255 All-In-One InkJet...
Black ink problem with printout on hp7780
Always try replacing the ink cartridges first.
It sounds like the print heads in the 7780 are bad. Don't confuse the ink cartridges with print heads. The cartridges fit inside the print heads. You will need to change the heads. Here is a link to HP's how-to.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00841890&tmp_track_link=ot_faqs/top_issues/en_us/c00841890/loc:1&lc=en&dlc=en&cc=us&lang=en&product=2512010
Could have the same problem with the Dell.
Jun 01, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
When I change the black ink cartridge, the alignment page and instruction page are printing out fine. When I place the alignment page on the glass as instructed and press 'ENTER', the printer gives a...
I just had the same issue (align page not detected).
We had just re-installed the empty color cartridge back into the printer (long story but basically we knew we could only print B/W).
The align page printout had a lot of empty spaces around the black lines. This is apparently where the color lines are supposed to print.
Without those color lines, the printer would not detect the align page as color is part of the alignment being done.
Since we only wanted black printouts, I pressed 'cancel' to stop the alignment process, and now we just hit the Black copy button and ignore the alignment prompt on the printer window.
The HP site (enter psc750 in product window) has some helpful ideas as to what the problem might also be. It could be the shipping tape is still on the new cartridge (and preventing the black or color from printing on the align sheets) etc.
Mar 20, 2009 | HP PSC 750 All-In-One InkJet Printer
HP 2600N PRINTS A BLACK LINE VERTICALLY ACROSS THE PAGE (FROM TOP TO BOTTOM) RIGHT IN THE MIDDLE EVERYTIME YOU PRINT SOMETHING . WHAT COULD THIS BE? I HAVE CLEANED EVERY DRUM, THE FILM ETC AND IT KEEPS...
You either have a defective black toner, a bad fuser or transfer belt. From my experence it is usually a bad toner cartridge. After you print a couple of pages, pull the black toner and see if there is anything on the drum. If there is try shaking the toner, sometimes toner does like dirt and clogs up. If you still have problem you will have to try another toner. I know that is not cheep, but I don't know any other way.
Mar 02, 2009 | HP Color LaserJet 2600n Printer
Streaks though the pages
Step one: Retry the print job The problem may occur only rarely. If you have not seen it in other printouts, try again. Step two: Increase the print quality mode If reprinting did not help, try increasing the print quality mode.
  2. Make sure the printer is selected, and then click Properties .
  3. Select the Paper/Quality tab.
  4. In the Print Quality area, choose the next higher quality setting. If the current setting is Draft, choose Normal. If the current setting is Normal, choose Best.
Step three: Print in grayscale (black area streaking only) If the streaks are in a black area of a black and white printout, change to grayscale printing. NOTE: This step does not apply to color printouts.
Step four: Clean the printheads If the print quality is still bad, clean the printheads.
  1. Make sure the printer is loaded with unused white paper.
  2. Open HP Solution Center .
  3. Click Settings , Print Settings , and then select Printer Toolbox .
  4. Click the Service Tab .
  5. Click Clean Printhead , and then click Clean .
Step five: Align the printheads If the print quality is still bad, align the printheads.
  2. Open the printer Toolbox , and select the Printer Services tab.
  3. Click Align Printheads . The Align Printheads window opens. Click Align .
  4. The printer prints an alignment page. The lines in the patterns should appear to be straight. Click OK when the page finishes printing.
Step six: Calibrate the linefeed If the print quality is still bad, calibrate the linefeed:
  2. Open the printer Toolbox and select the Printer Services tab.
  3. Click Calibrate Advanced Linefeed . The Advanced Linefeed Calibration window opens. Click OK .
Step seven: Replace one or both printheads If the print quality is still bad after performing all the above steps, one or both of the printheads will have to be replaced. Print a PQ Diagnostic page to see which printhead should be replaced.
  2. Press the Setup button.
  3. Press 1 and * simultaneously.
  4. Look at the color blocks labeled Test Pattern 2. Some or all of them could show white horizontal streaks. If none of the blocks are streaked, the printheads are okay.
    • If the Black block has lines – replace the KY printhead.
    • If the Cyan block has lines – replace the MC printhead.
    • If the Magenta block has lines – replace the MC printhead.
    • If the Red block has lines – replace the KY printhead.
    • If the Green block has lines – replace the KY printhead.
Nov 25, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
Epson Printer - Skipping When Printing Black
If you try the print head alignment or head cleaning wizard under the maintenance tab, they may help!
Dec 18, 2007 | Epson Stylus CX3810 All-In-One InkJet...
Empty ms word printout
Hi, You can try: 1. go to Start, Printer and Faxes, right click on your 3745, click on Properties, Printing Preference; 2. Check to see if you have any Advanced tab or button; 3. Check if you can set the printer to text only; 4. Check if you can set the printer to use black ink only. 5. In MS Word, verify through the use of Print Preview that your document is as you would want to be printed; 6. In some instances you may have to set manually text color in MS Word. While your document is open, click Ctrl + A to select all, then choose font color to "Black". Alternately, in your MS Word, you can click on "Format", "Font", "Font Color" set to "Black" rather than "Automatic" and set this as the "Default" setting. Hope this be of some help/idea. Post back how things turned up or should you need further information. Good luck and kind regards.
Sep 29, 2007 | HP DeskJet 3740 InkJet Printer
HP Officejet Pro L7780 All-In-One InkJet Printer Logo
246 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
