Question about Brother HL 5140 Laser Printer
Ghosting on prints
I have a brother hl-5140 printer. I get a "ghosting" effect on prints, especially with larger font sizes, and an even more pronounced effect on heavier paper. This is a relatively new situation (just this month) I've had the printer since 9/06, have printed probably 25,000 to 30,000 pages using both the OEM, and aftermarket toner cartridges, and did replace the drum in late 2008. No problems, until recently. Cleaned it too ... no change. THANKS!
    Scholar:
  • 72 Answers
Wrong paper type can cause this, also if it is damp or too thick. Also check that you have the correct type of paper (thickness) selected in the driver. Ghosting can also be caused by a faulty drum unit, since you just replaced it maybe there is warranty left on it?.
Posted on May 24, 2009
WHY IS THE PRINT SMALLER WHEN IT PRINTS
check the settings of the size option before you print it.
Oct 06, 2012 | Brother HL 5140 Laser Printer
Need to get a total page count or report off of my Brother HL-5140
hold down the "blue GO" button on the printer intill it prints the report.
Have a nice day!
Aug 23, 2011 | Brother HL 5140 Laser Printer
How do you get a page count from an HL 5140/
On the HL-5140, you can print out a config page which will show the page count on it by pressing down the Go button (the blue button). Hold it for a few seconds, until the config page starts to print out.
To find configuration page instructions and page count tips for other printers, copiers, and fax machines, check out How to Print Configuration Pages.
Aug 22, 2011 | Brother HL 5140 Laser Printer
I usually print invoices and our forms have lines between fields. Lately the printer is not printing those lines. Even with new toner. What to do?
Make sure that neither the printer or the driver are set to draft mode.
Also make sure that no one changed the form content to decrease the size and density of the lines.
Don
Feb 16, 2010 | Brother HL 5140 Laser Printer
Our Brother HL-5140 is not printing. It doesn't
Replace the paper pcik-up rolly assembly. MAKE SURE TO get a good look at how the existing one is installed before removing it. It needs a little tweeking to get the new one in and everything lined up correctly.
Also replace the separation page on the paper tray itself.
Look for part number PF-1 Kit or OEM PART #: LJ7920001
The only diagrams I could find on-line of the inside of the printer I found by searching for "brother pl-prn067". Look at pages 8-9.
Dec 09, 2009 | Brother HL 5140 Laser Printer
Brother Hl-2040 laser printer
I think, you have selected the Fix to Page option in Print Preferences. You have to change this option.
In the Print Preferences, select the "Print at Actual Size" option.
Hope after this, you will get your problem solved.
Apr 24, 2009 | Lexmark JetPrinter Color Z33 InkJet
Font size on printed copis different than shown on incoming email
Just maybe it is the size of the original e-mail and your monitor makes it appear larger. The way  that I do it is to copy and past the email into a word processor,like WORD, then set the type font to the size that I want before printing, then print from that file
Feb 23, 2009 | Brother HL-2040 Laser Printer
Will not Print online Coupos
Just fixed my Brother HL-5140. Hope this helps :) I have struggled for years and finally figured this out from the Brother website.
If you are unable to print coupons from the Internet the print processor
setting in the driver needs to be changed. To change the setting,
1. Open Printers and Faxes.
2. Right mouse click on the Brother printer and left click Properties.
3. Click on the Advanced tab.
4. Click the Print Processor button.
5. Under Print Processor, select WinPrint.
6. Under Default Datatype, make sure RAW is selected. Click OK.
7. Back on the Advanced tab remove the check next to Keep Printed
Documents.
8. Click Apply and OK.
Try printing the coupons again.
Aug 20, 2008 | Brother HL 5140 Laser Printer
Fonts and sizes are typically controlled by the application you are using. Are you sure you are increasing the font size? I've had some users confused by the zoom feature which is more like a magnifying lens. It just makes thing larger for viewing purposes and does not affect the print size. To change the actual font size of a document already created you would first highlight the text in the document. In Word (other applications are similar) you would then select Format from the main menu bar, then select Font. In the next box that appears you would click on the Font tab, and then in the Size field select a larger font size. After that click on OK and you should see your font size change. Let us know if that was your problem or not.
Aug 02, 2007 | Brother HL-2040 Laser Printer
Brother HL 5140 Laser Printer Logo
373 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
