Question about Jandy Aqualink Rs4 One Touch Control System Control System
Spa will not fill, water is drained faster than pumped in.
I have a Jandy Aqualink RS4. My spa was drained by the pump system and won't refill. For some reason when I turn on the spillway between the pool, turn on the spa, or just turn on the filter pump - water is sucked out the bottom faster than it is pumped in through the jets. Please help!!!
    Top Expert:
  • Jandy Master
  • 4,292 Answers
Check the JVAs either one is off or they are reversed
Posted on Jan 30, 2016
5 Suggested Answers
PartsCenter
  • 125 Answers
SOURCE: Jandy Aqualink RS4 controller won't turn lights on/off
AquaLink Trouble shooting guide
Posted on Feb 26, 2009
  • 246 Answers
SOURCE: We have an AquaLink RS4 All Button control in the
can't be made the only is to cancel the delay on the back dip #4 heater cool down turn off breaker when do this also change assign jva at system setup
Posted on Sep 13, 2009
  • 990 Answers
SOURCE: Jandy Aqualink rs4 when set on auto the system
Go through your menu again and reset. These have defaults that may be causing the trouble if the power went out or your battery backup is old. Check this and let me know and we can look further. Your menu should help to walk you through problems, it is very user friendly. Hope this helps, let me know.
Posted on Nov 07, 2009
  • 366 Answers
SOURCE: Jandy aqualink rs4: pool has been winterized with
the only thing you can do since the jandy does not have a "winter" mode is switch the valves off. Once you have the valves in spa mode, there should be a toggle switch on the valve actuators. You can set the switches to the middle position and that will lock them in that position. You will probably have to re-winterize the pool lines.
Posted on Nov 14, 2009
Error check system water sensor open
bad water sensor check it hooks up to plumbing after pump wire goes to green plug in aqualink pins 5 and 6
Nov 17, 2013 | Jandy Aqualink Rs4 One Touch Control...
Aqualink RS4 keeps turning on and off even though all programs have been cleared.
This issue sounds tricky. I recommend you callthe Jandy technical support at 800-822-7933 and they should be able to help youfigure this issue out.
I hope this helps.
Sep 12, 2011 | Jandy Aqualink Rs4 One Touch Control...
Spa does not turn off.
There SHOULD be a valve that you can close to disable the spa.
Sep 27, 2009 | Jandy Aqualink Rs4 One Touch Control...
SPA Filter on while Spa is Heating
If it has motorized valves the stop positions have to be adjusted so that the water coming back is equal to what it drains to stop the spill over process unless you want to add more valves but the pool pump does the job of heating and filtering the spa
Jul 04, 2009 | Jandy Aqualink Rs4 One Touch Control...
Spa wont heat
Check the pump make sure that it is getting power. If there is power to the pump and nothing is working then pump is bad. Also this could be your computer board is bad, a inline fuse. or the Jandy is bad
May 20, 2009 | Jandy Aqualink Rs4 One Touch Control...
Spa only gets to about 90 deg
For a quick fix you could swap out the air and water temp sensors. They should be exactly the same.
Apr 11, 2009 | Jandy Aqualink Rs4 One Touch Control...
Jandy Aqualink Rs4 One Touch Control System Control System Logo
136 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
