Question about Sony PlayStation 2 (PS2) Console
Can't get past the ghouls to free Neville
Trying to get through room with ron but there are 3 ghouls in there plus a crystal and a mirror. What do I do?
Have Ron cast the illumination spell onto the cristal ball, this will charge the cristal ball and it will shoot a beam of light. Then go to the mirror and adjust it so it will redirect the beam to an eyeball on the wall sowhere, that will open a cage door on the wall. Use Ron again and use the illumination spell on the ghouls and drive them to the cage. I hope this helps.
Posted on May 25, 2009
How to play minecraft
Minecraft is and easy but challenging game to play. First thing you will need to do is buy the game or try the demo at www.minecraft.net. Once install open up the game and choose the type of game you would like to play. If survival mode you want to build a house or tunnel to hide in at night so the ghouls don't kill you. Minecraft is a game of crafting and building pretty much any structure you can imagine. You can also join someone else's server by finding the ip their server is hosted on!
May 09, 2013 | Computers & Internet
Grass trimmer GL430SC just stopped working, I have lost the manual?
Hi ron higgs,
Search on internet via google type you,re name of the product plus manual and find download of you,re machine.For pdf download free adobe reader .
Free of charge.
Appie
May 30, 2011 | Black & Decker 3 x 21 In. Dragster Belt...
The crystal is scratched, can I fix that myself?
Thanks for contacting FIxYa.
  • Use a jeweler's loupe to identify all scratches on the watch crystal. You do not have to remove the watch crystal from the watch.
  • Use a polishing cloth to remove dirt, grit, lint or any debris on the watch crystal. Squeeze a small amount of standard toothpaste with abrasive properties onto the watch crystal. Gently brush the toothpaste into the crystal for five minutes. Wipe clean the watch crystal. and repeat another five minutes.
  • Use the jeweler's loupe to inspect your progress. Repeat application if necessary. Apply Brasso polish once the watch crystal is wiped clean. This will polish the crystal to a clear, bright shine.
  • Apply Autosol or Polywatch to the watch crystal in the same manner as toothpaste if you prefer to use a product specifically designed for watch crystals. These products will provide the same results as toothpaste. You may also apply Cerium Oxide, a glass scratch remover used specifically in the window manufacturing industry.
  • Apply a small amount of 3-micron diamond paste using your finger or a Kleenex if removing scratches from a sapphire crystal. Rub the paste in for about five minutes. Remove paste with cloth. Buff the sapphire crystal with one-quarter micron buffing diamond paste for finishing.
  • Use a toothpick to remove excess polish and gunk that may accumulate between the crystal and the bezel that secures the crystal in place. Gently work the toothpick around the diameter of the bezel. Wipe the bezel clean with a cloth.
  • Buff the watch crystal with a polishing cloth.
  • OR..take to a local jeweler/watchmaker.
    Best regards. Jewel
    Sep 10, 2010 | Relic Watches
    How to replace mirror on 2008 ford explorer
    Remove front door inside handle bezel. It should snap off waway from the door. Remove the screws behind bezel. Remove the screws on the bottom of the main door trim panel. DO NOT PULL OUTWARD ON THE DOOR PANEL OR IT WILL BRAKE!! Remove the door panel by lifting the pael upward. at this point you ay have enough room to access the 3 nuts behind the mirror and te mirror electrical connector. If there is not enough room then you will have to disconect the electrical connectors and the door handle linkage on the door panel. if there is eonough room for you then disconect the mirror electrical connector first then remove the 3 nuts behind the miror. the mirror should just pull strait away from the door. Reverse this proceadure to install new mirror. This is the same for left or right side.
    Jun 18, 2010 | 2008 Ford Explorer
    Acer crystal eye web cam
    you can download www.camfog.com free and go on there into chat rooms an enjoy yourself there or you can use it with you instantmessenger with frineds and family.
    May 25, 2009 | Computers & Internet
    Order of phoeninx da meeting problem
    i had a problem with that too have you given the mandrake root too the boy in potions?
    about the spell try talking too everyone in the room if so talk to hermione she can teach you a spell
    May 24, 2009 | Electronic Arts Harry Potter and the Order...
    Broken side rear view mirror
    the only way to fix if the mirror is damaged is to replace mirror assembly. remove the trim piece on the backside of the mirror and remove the 3 10mm nuts holding the mirror on.
    Mar 25, 2009 | 2005 Saturn VUE
    Channels not working
    It was in the guide plus set up that I needed to redo. When I was originally using it I had it setup to be connected to cable box, but when we moved it into the other room when we got the new tv we recieved, there wasnt a cable box in there. I didnt know that I just need to reset the menus to delete it being connected to cable box and it worked. I hope this will help someone else if this problem occurs with their TV. Ron
    Sep 16, 2008 | GE 27GT722 27" TV
    Sony PlayStation 2 (PS2) Console Logo
    41 people viewed this question
    Top Sony Video Game Consoles & Games Experts
    shaun taylor
    marley mcelhinney
    juanmireles1
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
