Question about RCA TruFlat 27F520T 27" TV
Color of tv is mess up
The color is more red
  • Alan Timperley
    Alan Timperley May 11, 2010
    This may be a stupid question, but have you tried adjusting the tint?
  • 822 Answers
Just check your color settings at your menu on your tv. if ok its a cold solder from your CRT socket board.
Posted on May 24, 2009
I have a hitachi 50c20 tv and it has a red tint/hue across the whole screen
Are you using component cables into the TV? It sounds like one of the 3 video cables may have come out saturating the red colors. Check your cabling int he back of the TV, see if you remove 1 by one if that changes the colors. Each cable on its own should have a picture with either red green or blue colors. If any of them are missing the picture then the colors will get messed up when all 3 are plugged in. If you are not using component cables then check the color settings on your TV. Somewhere int he menu of the television you should have something like picture display settings that let you adjust the colors. Check and make sure that the reds are not over configured or the others are not set too low. You may also want to check that your source is proper as well. Check that other sources look okay or if it is with all different connectors/sources that the issue occurs on.
Oct 15, 2013 | Televison & Video
Dp32746 Sanyo Picture is messed up?
try to play a DVD on your TV to determine if the problem is on TV or signal..
If the DVD plays same image you have bad t-con board,.,just replace it to fix the problem..
Aug 25, 2012 | Sanyo DP32746 32 in. LCD Television
We've had the Sony DAV DX150 for a few years and now all of a sudden when we play a DVD the color is all messed up. It displays in mostly greens and purples. If we adjust our TV settings, by putting the...
Hello ,im curious as to whether your using component cables from the dvd to the tv (red,green,blue) if so than i suggest you check those because it sounds like your missing a color,check the red cable specifically.
Jan 18, 2011 | Sony DAV-DX150 System
Tv works good picture is good and clear sound is good but im only getting blue and red colors??? is that the board? or the green bulb?
That is what happened with are tv. My husband took the tv apart and started messing with everything and got the tv to line up better. he just turned the nobs and messed with the coloring.
Dec 09, 2009 | Hitachi 61HDX98B 61" Rear Projection...
My tv was dropped and now the color is messed up how can i fix it
Unfortunately, this can't be fixed without replacing the picture tube. The drop caused a piece called the shadow mask inside the tube to warp or break loose. When that happens, the red, green and blue beams in the tube don't hit the right places on the screen. There isn't any way to repair this kind of damage.
If you had professional movers doing the job, their insurance should cover some or all of the cost of repairing the TV (replacing the tube, that is) or replacing the set. I wish I could give you better news.
Nov 22, 2008 | JVC AV-32D305 32" TV
Tv went red and now power will not stay on
If one color goes out of control, the TV will auto turn off for safety reasons. Sounds like a red bias resistor has burned out. A tech will be needed to trace this problem. Sometimes there is a knob behind the front TV speaker panel for adjusting the color bias levels. You could try to mess with it if you are able to find it. I would just get a tech. Could be a cheap repair.
Nov 13, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Durabrand tv model CR130DR8 13"
Good day.
The issue the you are having is in your tv's color circuit. The daguassing coil is not functioning because there are might be lose contacts on the color circuit.
Have it resoldered.
Regards,
chris
Aug 17, 2008 | Televison & Video
Tv color messed up
There is the chance that the yoke has sliped and a purity adjustment is in order, since you would be dealing with voltages that could kill you if you don't know haw to do this the safest bet would be to take it to the shop
Jun 03, 2008 | Symphonic ST420FF 20" TV
Hitachi TV Problems
convergence ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 23, 2007 | Hitachi 43F300 43" Rear Projection...
TV coloring messed up
my sony did that but would turn off and not leave on. its not recommended to use like that (from tv repair man). theres a chip inside the tv that blew. it cost me 260 bucks to get someone to come and fix it.
Nov 01, 2007 | Televison & Video
RCA TruFlat  27F520T 27" TV Logo
105 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
