Question about Maytag 24 in. MDBH950AWS Built-in Dishwasher
Our dishwasher does not drain all the way. What could be the problem?
Our Maytag dishwasher is not draining completely. What could possibly be the problem. It is affecting the result of the cleaned dishes. Not as clean now.
  • 3,600 Answers
Water pump is defective replace the pump about $40.00 and is not to hard to do. Take a picture of the washer underneath and send me a pick and I will give you the exact details of how to remove and replace it.
Posted on May 24, 2009
Won't drain after rinse cycle.
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 14, 2011 | Maytag Dishwasher
Water doesn't drain
Hi
Daniel
Aug 03, 2011 | Maytag MDB8851 Built-in Dishwasher
Maytag dishwasher MDBH985AWS1 won't drain
Hi
Daniel
Jun 19, 2011 | Maytag Dishwasher
Water will not pump out of my Maytag dishwasher!!
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Daniel
Mar 25, 2011 | Maytag Dishwashers
I have a Maytag MDB7100AWB that won't drain water after completed cycle
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter.
Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Dec 23, 2009 | Maytag Dishwashers
Our Maytag MDB7100AWS Dishwasher fails, inconsistently, to drain.
Hi
Thanks
Rylee
Dec 23, 2009 | Maytag MDB7100AWB Dishwasher
Dishwasher is not draining
Hi
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 04, 2009 | Maytag 24 in. MDBH955AW Built-in...
My Maytag dishwasher Model # MDB-3 will not drain. Please help. Thanks! Anna Giacobbe
Hi
Thanks
Rylee
Nov 03, 2009 | Maytag 24 in. MDB5600A Jetclean II...
Maytag dishwasher not draining completely
You have to remove the bottom kickplate to gain access to the drain pump and drain hose. You can remove the drain hose and blow through to see if the obstruction is in the hose. Take a look at the check valve for blockage. If a garbage disposal was just installed, make sure the knockout plug was removed.
Feb 25, 2009 | Maytag 24 in. MDBH940AW Built-in...
Food particles are on dishes after washing
Try adding bicarb of soda/baking soda and vinegar in the detergent dispenser. Bicarb fizzes off hardened particles and vinegar strips off grease and aids rinsing.
Jan 26, 2009 | Maytag 24 in. PDB1420 Built-in Dishwasher
Maytag 24 in. MDBH950AWS Built-in Dishwasher Logo
706 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
