Question about Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100)
No Wireless Signal on modem(no green light)
Wireless on Westell 327W modem has no signal(no green light) - I have reset the modem as well. Still not working.... help !!!!
  • rachellecane May 24, 2009
    I have reset the modem twice, still not working - I also went to the Westell site - if I'm reading this correctly, the connection is UP and running ?1?/
  • 822 Answers
Just reset your modem at the back button. and check your antenna if properly installed.
Posted on May 24, 2009
Do i need a wireless router if i have westell 6100f
Yes. The Westell 6100f is not a wireless modem, therefore, you will need to get a wireless router to connect wireless computers.
Or if your ISP is Verizon and you want a wireless modem/router, you may contact them and replace the Westell 6100f with a Westell Versalink 327w, or Westell 7500, or an Actiontec.
Hope this helps!
Mar 01, 2010 | Westell Wirespeed LiteLine 6000 Modem
Westell versalink 327w from bellsouth can't connect
Howdy,
I do not think this modem will work for you. Contact O.T.C. to be sure. For a few details...
I presume that you can access your Westell wireless modem/router 327w with the IP address of - 192.168.1.254. (Or you can simply type "launchmodem" in the address bar - (one word - no quotes)) This will definitely get you in. You will then see the setup menu. If you see the Bellsouth FastAccess Internet Service logo then you know you definitely have a Bellsouth modem.
Now, let's presume, you are using a Westell wireless modem/router 327w made for Bellsouth/ATT. If this is the case, as stated above, you will see the Bellsouth Logo on the setup page. Additionally, it is stated on the page below, that you cannot use a Bellsouth modem/router for any other ISP (Internet Service Provider) This is due to the Bellsouth/ATT firmware that Westell builds into this modem/router.
This is the page link:
http://www.dslreports.com/faq/bellsouth/3.141_Westell_327W__wireless__Info#13772
This is the relevant quote:
"The BellSouth supplied 327W (model C90-327W30-06) is made exclusively for BellSouth FastAccess. They are functionally different from retail Westells (or any model designed for use with other ISPs) and the firmware between them are not compatible and can not be interchanged."
That being said, you still might attempt to use this 327W with orlando telephone company but I do not know if it will work. (Doubtful...) I use the Bellsouth 327W and it is GREAT. (With Bsouth/ATT) Good luck.
P.S. - Please be advised that Westell does manufacture an identical 327W that does NOT have the Bellsouth/ATT firmware.installed. This is the "generic" version I suppose but I have no experience with this one. If you need more just ask. :)
Good luck,
J
Oct 07, 2009 | Westell Wirespeed VersaLink...
Set to work with centurytel instead of bell south
Howdy - You may have a two fold problem here. First of all the Westell wireless modem/router 327w has the access IP address of - 192.168.1.254. (Or you can simply type "launchmodem" in the address bar - (one word - no quotes)) This will definitely get you in. You will then see the setup menu. That problem solved...
Now, from what I understand, you are using a Westell wireless modem/router 327w made for Bellsouth/ATT. If this is the case, you will see the Bellsouth Logo on the setup page. Additionally, it is stated on the page below, that you cannot use a Bellsouth modem/router for any other ISP (Internet Service Provider) This is due to the Bellsouth/ATT firmware that Westell builds into this modem/router.
That being said, you still might attempt to use this 327W with centurytel but I do not know if it will work. I use the Bellsouth 327W and it is GREAT. Good luck.
May 29, 2009 | Westell Wirespeed VersaLink...
No wireless connectivity with Westell 327w
on the back of the modem is a reset button. try resetting and bridging the modem again.
Apr 09, 2009 | Westell Wirespeed VersaLink...
I cannot access my wireless network via my westell 327w Modem
the wireless light indicates activity when it is flashing thus it is probably a good sign
A FLASHING DSL LIGHT IS A BAD SIGN
it means activity getting sync which means no internet or anything
Jan 09, 2009 | Westell Wirespeed VersaLink...
I cannot get my Westell 327w to connect to the internet
Internet light will turn on once you configure the router with your user name and password and once it is authenticated by the server.
Nov 16, 2008 | Westell Wirespeed VersaLink...
No wireless signal
Access the firmware page by going to your web browser and ener the following the address bar:
http://192.168.1.1 (assuming your provider hasn't changed this)
Mouse to "Configuration"
Click on "Wireless"
Select "Basic"
You will see the "Wireless Operation" field. Select "Enable" here.
I actually support this modem on a daily basis. If you have any more issues let me know and I will send you a link to a document with these instructions and screenshots.
May 14, 2008 | Westell Wirespeed VersaLink...
Westell 327w
xbox live connection test MTU failed
Mar 12, 2008 | Microsoft Xbox 360 Console
Hook up westell 327w to linksys router
the wireless won't work. i have the same problem. westell modems aren't compatible with wireless function on some laptops therefore routing signal through a wireless router allows that. it can be done, i've done it but after modem was reset having issues. keep searching it can be done...
thanks for the vague and non-informative answer though whoever that was.
Jan 14, 2008 | Westell Wirespeed VersaLink...
Poor wirless signal
Hi HHC,
You can try resetting the Westell to defaults, but pressing a thin pin, (Paperclip works great!) into the reset hole, in the back, and holding it in for 10 sec. You could also try using the lowest channel you. Most Westell's I have worked with have good wireless range, though. Test your laptop at a nearby hotspot, i.e. Starbucks. McDonalds, etc. If it is not the laptop, (Averatec laptops have horrible range!) and the reset don't fix it, have it replaced.
Good Luck!
Jan 07, 2008 | Westell Wirespeed VersaLink...
Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100) Logo
287 people viewed this question
Top Westell Wirespeed Computers & Internet Experts
Prashant M
Prashant M
arnold balmaceda
arnold balmaceda
Level 1 Expert
Are you a Westell Wirespeed Computer and Internet Expert? Answer questions, earn points and help others
