Snow screen My RCA 52" will go to a snow screen right after turning on or a few minutes after. Turn the tv off then back on, and will be fine for a few minutes. It will do this several times and then be ok until turned off again. It acts like the cable goes out. Someone told me it could be where the cable connects in the back. Any help?
  • hoondogg May 24, 2009
    So how it that fixed?? Thanks.
  • 822 Answers
Yes! your right! its a cable connector problem.
Posted on May 24, 2009
When you turn on the the TV the picture is good with in a minute or so the Picture turns wavy and has a double image. I can turn it off, then turn it right back on the picture is good for any where a...
The problem with the television is the lamp. It is faulty that is why the screen turns wavy in minutes.
The solution to that is to replace the light and your television will be in good condition once again.
Take care
Oct 10, 2010 | RCA P52926 52" Rear Projection Television
Sansui Projection TV - RCA D52W23 52 in., Problem is tv gets turn off automatically after few minutes. It doesnot off but a blue screen with lines appears immd.., it takes long time get the picture on...
CK for Bad capacitors cp114,120,150 if any of them is puffed up on top it is bad so replace all 3 cp150 is 2200uf 16v other two are 220uf 35v also resolder all pinns on FBT flyback transfomer.
Jan 23, 2009 | RCA D52W23 52" HDTV CRT TV
Tv turning off by itself occasionally
Just had mine repaired yesterday.
They relaced a TD4611 voltage regulator and a C2200uf 50v part.
Total including service call $188.00 in Western Canada.
Phil
Jul 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv turns off after several minutes
Hello, I would take it to a TV repair place, they will charge around $50 and let you know what the problem is with it. this is your cheapest way out, it you want to keep it. If you chose to take it please give me a fixya rateing. Thanks, Farren
Dec 23, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Light
My RCA 52 inch was doing the same thing.  TV guy had me use a regular hair blower blowing very hot on the power supply board ( bottom left in back). After a few minutes the tv would come on.  He replaced 2 capacitors, charged me $100.00, plus the $95.00 service call, and is working fine now.  This was a month ago.  So far so good.  He only took the board to the shop, not the entire tv.  Hope this helps.
Oct 04, 2007 | RCA HD52W56 52" Rear Projection HDTV
Rear projection snow
Bad primary tuner==can be replaced,or==by-pass by using video inputs.
Aug 26, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
yes it could ba the cable itself even, but i suspect more the tuner circuit or tuner itself may have bad solder connections. Here is another test for you to try, plug another dvd or vcr, or xbox etc. into the back, using one odf the inputs. See if this works like the built in dvd. if so it will be more likely bad connections in the tuner or surrounding circuit. good luck.
Dec 17, 2006 | RCA HD52W56 52" Rear Projection HDTV
Snow on screen/wiggle the coax
SOUNDS LIKE BAD SOLDER CONNECTIONS IN SIDE THE TUNER. TAKE THE BACK OFF AND TRY TAPPING AROUND WITH YOUR DRIVER HANDLE THIS WILL LEAD YOU TO WERE THE PROBLEM IS. THEN WE TAKE THE TUNERS APART AND RE SOLDER THE CONNECTIONS,BUT YOU HAVE TO BE VERY GOOD OR YOU WILL MAKE MATTERS WORSE.
Apr 11, 2006 | RCA P52830BL 52" Rear Projection...
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
