Question about Maytag Washing Machines
WATER RUNS NON STOP EVEN WHEN MACHINE IS OFF
THE WATER RUNS NON STOP THROUGH MY WASHER. IS THERE SOME TYPE OF PRESSURE SWITCH. THX JOE
    Scholar:
  • 85 Answers
Yes. on Maytag usually runs fro left rear of tub to the control panel. You will have to pop the lid up to get to it. It may have pulled off the lower nipple or rubbed a hole in it somewhere.
Posted on May 24, 2009
Water wont stop filling up
If water keeps filling or dribbling into the machine with the power off it's the water inlet solenoid. If it overfills only during the cycle then it is the pressure switch or pressure switch tube.
Jul 10, 2013 | Meiko Dishwashers
Water will not stop running during cycle. the code says it water pressure but you have to shut off the water to make it stop
It could be one of two things. If the water runs into the machine even when the washer is turned off, you need a new water valve. If the water only comes in when called for then doesnt stop you need a new pressure switch and possibly a new pressure switch hose
Jul 12, 2011 | Maytag MAH8700A Front Load Washer
I have a gasoline pressure washer. i connect machine the right way. try to start but machine only runs when trigger is pressed. stop pressing trigger machine shuts off. the water is flowing through the...
Not knowing exactly what type of pressure washer you have, most are equipped with an "unloader valve" so the pressure bypasses. If this is malfunctioning, the pressure will build up and bog the engine down.
Feb 11, 2011 | Garden
It will not start. It was bought new and only used three times drafting water from a bucket. Now it will not even turn on.
It is not clear what type of machine this is you are having trouble with but I would guess it is not a chainsaw but a pump like a pressure washer pump.
Pressure washers today are very picky about what goes in them. If it was just water you may have corrosion in the pump. especially if it is an aluminum housing. It is never recommended to run harsh chemicals through the pumps. Briggs and Stratton makes a pump saver recommended for storing your pump. You can purchase this pump saver or parts for your machine through dealers such as www.arcolawn.com.
If you can reply with the type of machine and any numbers you can find I would be happy to assist further.
Thank you -Joe
Feb 11, 2011 | Karcher PSI Electric Pressure Washer
My P11897 washer pump runs until I connect the
Dear Davidandkath,
I am assuming that by feed hose you mean the water supply inlet. Well if you connect the water supply inlet and the gun is closed, then the machine will stop. This is normal. Now if you open the gun and the machine still stays dead...then the control valve that operates a micro switch is stuck in a position that leaves the micro switch off.
So you must open machine and see a spill valve(pressure control valve)...this will have a cap on it with a wire. This wire is feeding electricity to the micro switch. You can lubricate the spill valve, but myself I change with a new one. You must also check that the micro switch is OK. To open the outer cover there are screws which are normaly TORX ..T15 size. Another reason for the machine to stop dead is that the outlet hose is blocked or the wand( Gun ) is blocked.
Regards,
Fulltech.
Jul 17, 2010 | Karcher PSI Electric Pressure Washer
Kennmore washing machine Model 11026722693 water level overflows and won't stop filling....
Unplug you washer, if water still runs into you machine, you have a bad water valve. If it does not your selector switch is bad. This is the switch where you set the size load you want to wash. If you will go to www.partselect.com This is their part number PS342529 for your part. enter it in the box and this will bring up the part you need. From there you can order it. Good luck.
Oct 22, 2009 | Kenmore Washing Machines
My washer won't stop filling with water i changed out the water valve and still have the same problem. even when the washer goes in to a drain cycle it still fills with water.... thanks for your help
have you tried looking at the pressure switch? sometimes you can blow through the house that's attached to it and it will clearn things up. give it a try. good luck :)
Jul 15, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Water keeps flowing non-stop with my old Kenmore washer
Check the pressure switch and the pressure switch hose.
Remove the end caps on the console and remove the 2 screws that hold it down. Pull slightly from the bottom of the console and flip it up. On the left side you should see the pressure switch (water level switch) with a few wires and a small hose connected to it. The hose should be connected between the pressure switch and the tub. In most cases the pressure switch hose sometimes falls off over time due to vibration.
Replace the hose if it is damaged. If there are no visible holes or cracks in the hose, try trimming 1/4" off each end of the hose (pressure switch side and tub side) and reconnect them making sure to push hose ends securely onto connections. This is done because the hose sometimes stretches at the connection points and you will lose air pressure inside the switch, therefore the water will never shut off.
Alternatively you can use small clamps on each end.
If this doesn't work, check the function of the pressure switch by attaching a small hose to it and blowing lightly into the pressure switch while the machine is filling. You should hear a click and the inlet water valve should turn off. If it doesn't turn off you may need to replace the pressure switch or if the machine fills even when it's in the off position replace the inlet water valve.
Mar 03, 2009 | Kenmore 22422 Top Load Washer
WHIRLPOOL TOP LOADER OVERFILLING WATER
While it is filling up try this. Unplug the washer from the wall, if the water still runs then you need to replace the mixing valve. If the water stops then take the screws out at the base of the console and flip the controls back. Look for the clear hose that goes to the water pressure switch and make sure that it is connected. If it is connected take it off the switch and blow through it to see that it is clear of any obstructions.
If this only overfills after the first ore second wash then you may have the slow drain and the drain hose is in the downspout too tight.
Possible items needed;
#1 mixing valve
#2 pressure switch
#3 plumber
Jan 20, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer will not complete the cycle.
Check if you have power to the inlet solenoid/valve where the hose connects to the machine. There is a thin tube running from the outer drum at the back of the machine to a pressure switch. This pressure switch controls the water level in the washer. Remove this tube from the pressure switch and blow back into the machine. There could be a blockage in the tube. To check if the pressure switch is faulty, pull the tube off the pressure switch and let the machine fill. If the machine fills to a high level, switch it off before it overflows. Replace the pressure switch.
Oct 15, 2007 | Maytag MAH6500 Neptune Front Loading...
Washing Machines Logo
66 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
