Question about ASUS Maximus Formula Motherboard - 45nm Support, Intel X38, Socket 775, ATX, Audio, CrossFire Ready,
Find north and south bridge for asua maximus 2 mother board
I just want to locate the north bridge and the south bridge on a asus maximus 2 formula
  • 272 Answers
I do not the north bridge of this motherboard is different from others. mainly ram ports and Graphics card pord is called north bridge. read it for more. ( click here )
Posted on May 24, 2009
1. function of bios chip 2. function of north and south bridge chipset 3. cpu function
Hi there. Here is a brief description of those components found on the motherboard.
1. BIOS chip: This is known as Basic Input Output System and the chip contains the base instructions on how to boot the PC. All personalized settings can be configured in the BIOS such as CPU overclocking.
2. North Bridge: This component works with high speed hardware components such as RAM and PCI-E cards.
3.South Bridge: This component works with slower speed hardware components such as the hard drive and USB.
4. CPU: Central Processing Unit, this is basically the brain of a computer and this component is the one that does all calculating of data. So when you run an application, the CPU processes the data involving the application.
Please rate and comment, thank you.
Apr 16, 2011 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Amd athlon ii x3 450 best compitible mother board
asus makes the Best mainboards in my opinion, All AM3 boards. You get what you pay for so it's worth spending a bit more to get a good mainboard.
Example: ASUS M4A88TD-V EVO/USB3 is a really good option, however I myself would pair this mainboard with a AMD Phenom 2. Though your X3 450 will work well in this mainboard too.
The best compatible mainboard would be the ASUS Crosshair IV Formula or Extreme edtion, however your CPU will be a bottle neck in the system.
The ASUS M4A88TD-V EVO/USB3 is really good looking and it performs really well too.
You could go for an ASUS 785/790/870/880/890 North Bridge chipset AM3 Socket.
You could even purchase an AM3+ mainboard that will support AMD's new Phenom module CPU's.
Go to www.asus.com and check out the AMD mainboard range that they produce.
Take care!
damnor01
Feb 11, 2011 | AMD Athlon II X3 450 / 3.2 GHz processor
Please help me identify where is the north and south of motherboard
Its normally printed on the board, north bridge and south bridge. But I would suggest that it would be advisable to go to the ASUS website, follow links for downloads and support. There, you should be able to download a user manual for your motherboard and all the drivers, which you will need to install when you get your PC up and running.
Jun 30, 2010 | ASUS Maximus Formula Motherboard - 45nm...
The south chipset bridge of my Asus k8n-vm motherbard heats up
85 to 95 is ok. Anything higher than100 is pushing it. If possible add a fan to the side of the system case (Best choice) or you can buy a south bridge fan. You're MB doesn't have holes in the MB to attach a chipset fan but you can still attach a cooler on to the chipset. Like this fan; http://www.newegg.com/Product/Product.aspx?Item=N82E16835103155
And you'll need this as well for a good bond; http://www.outletpc.com/c2019.html
Enjoy!
Mike
Jun 12, 2010 | ASUS K8N-VM Motherboard
Maximus motherboard with intel x38 chipset won't boot
There's a chance of overclocking, ram failure, bios failure, cpu overheat, power supply problem,etc.. But in the first step, remove everything which are inserted on the board, like power cables, processor, rams, bios battery, Pci cards, sound cards, etc.. and clean them using soft brush, also clean the mother board, there might be dust clogging the chipsets like resistors, transistors and capacitors, and reinsert everything after cleaning... I hope this will help if there's only a small problem except circuit short... Good luck...
May 06, 2010 | ASUS Maximus Formula Motherboard - 45nm...
My motherboard temperature is higher than 80 C. it is also in warranty period. what should i do?
Hi are you over clocking ? Is the temps you are telling me on north bridge or south bridge ? What program are you using bios everest occt core temp ? Do you have good air flow in pc ? did you take temps just after heavy use ? sorry to ask but its not much info as some mother boards can run close to that but thats not as much boards more the chips on the board
Oct 13, 2009 | Intel DG31PR Motherboard
Ihave asus mother board but i have no mother board cd my system manufucter is k8m890 please help me which vga driver is requred for my board.
can you clarify the exact board you have, the text says "k8m890" this is not the board pictured or titled Asus Maximus compdoctor2005@btinternet.com
Jun 06, 2009 | ASUS Maximus Formula Motherboard - 45nm...
Asus maximus formula
Yea- its really simple with the Maximus Formula's (well.. I have a Maximus II Formula....)
Under the BIOS, you should have a tab called "extreme tweaker" or something similar. Go under that and there should be a nice CPU level up option. For example, mine has 3 options: (i have an E8400)
1.) Auto
2.) E8500
3.) Crazy
Another solution is to get the ASUS utility called CPU Level Up. It installs under windows, and lets you switch your CPU settings easily. Although this may be a Republic of Gamers specific utility.. not sure.
Jul 01, 2008 | ASUS Maximus Formula Motherboard - 45nm...
NEED TO KNOW WIRING
i have been to fic's web site, i cannot find any mb labeled au31.
do you have anymore information about the board, how old, which processor, what socket, which north bridge, south bridge, which model system, etc?
however the pins are usually marked "pwr sw" or "pwr" and are usually with all the other front panel connector pins.
Oct 17, 2007 | E-Machines eMachines Desktop PC
Open Questions:
Supreme FX II Won't work Ok, let's start from the top- Bought an ASUS Maximus II Formula mobo off of NewEgg. Open box version, since I'm an idiot. That was my first mistake obviously. So, naturally, it doesn't come with ANY of the parts it's supposed to- LCD Poster, Supreme X-FI II, nothing. yay. Anyways, I finally tracked down a sound card (the X-Fi that was actually supposed to come with the motherboard). Installed it- nothing. Didn't show up in device manager, nothing at all. So, I swapped PCI-E slots, and still nothing. (PCI-E x1). So here I am, mad that I bought a sound card from some guy that didn't work. Well, I happened to come across another one, same exact card. So I tried it, all happy and everything, as I KNEW this one worked. NOTHING. Updated the BIOS- nothing. Changed a few settings, such as turning off PnP OS, tried a couple other small things- nothing.,... I'm beginning to think that the mobo has bad PCI-E x1 slots- all other slots work though. Is there any other way they could possibly be disabled by something? Please give some ideas to try, including the simple ones- I'd like to try to solve, as the mobo did cost a good bit. System Specs: Vista Ultimate, XP Pro, 7 RC (tri-boot) (card does not show up in ANY OS) - All have updates. 4Gb DDR2 1066 (OCZ) Intel 3.0 Ghz E8400 CPU Nvidia 9500 GT 1Tb total drive space. Currently having to use a POS Soundblaster Audigy (original) To be honest, I could care less about the X-FI. I just want my FP audio to work. But the mobo has no headers- the FPAUD header is on the sound card. But, the X-FI would be a nice upgrade.... Please help- I can't afford a new mobo right now. Like I said, even give me simple solutions- sometimes we just skip the easy stuff without realizing it lol And you don't have to use laymans terms with me- I repair PC's for a living lol. Update- Tried placing sound card in x16 slot- lit up (which it did before), but still not showing up in device manager. Tried placing it in same slot my video card was in (since I know that slot works) - nothing. So, now we know its not a faulty slot. Tried disabling PCIE Spread Spectrum, CPU Spread Spectrum. Nothing. Tried both cards in all 4 PCI E slots - nothing still... Also removed Audigy while doing this. So- we know the card works, as I saw it work earlier on a different PC. We know the slots on the mobo are fine. I've tried everything in the BIOS I could think of. When I try to install the drivers- says no supported device found. Update- Took both cards up to work. Plugged into one of our shop machines- still nothing. HOWEVER. The second card that I had come across, was out of a customers machine- and of course, it works in his with no problem. So I know the card is good. Yet, it won't install on ANY other machine.
May 08, 2009 | ASUS Maximus Formula Motherboard - 45nm...
ASUS Maximus Formula Motherboard - 45nm Support, Intel X38, Socket 775, ATX, Audio, CrossFire Ready, Logo
614 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
