Question about Samsung HP-R4252 42 in. Plasma HDTV
Fuzzy picture and horisontal lines all across the screen
Samsung hp-r4252 plasma tv the problem is in all the inputs
wwjdcgh
  • 114 Answers
SOURCE: Samsung Plasma Lines and Colors on Screen
first is it still under warranty through the manufacturer samsung is verry well with wanrranties
It sounds like it is most likely the plasma gas itself and in that case it would cost way more than what you could purchase another one for.
by the time you have a tech come out and fix the plasma gas tube itself yould be looking well over 1000
Posted on Mar 30, 2009
romsky79
  • 822 Answers
yes it can fix. its only loose connections from LCD connectors. trust me. romsky79@yahoo.com
Posted on May 29, 2009
stonephoenix
  • 563 Answers
SOURCE: Samsung Plasma TV have sound but no picture
G'Day!
Unfortunately, what you're describing is a repair issue. You won't be able to address the problem with troubleshooting. There is a part inside the TV that needs to be replaced. If you're under warranty, this will cost you nothing. If you're not under warranty the cost will likely be a minimum of $200 parts and labor. However, be warned that the cost could be considerably higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further
Posted on Jul 22, 2009
boltthedog
  • 24 Answers
SOURCE: my samsung plasma has horizontal line across middle of picture
loose wire check connections
Posted on Sep 19, 2009
  • 5124 Answers
SOURCE: I have a 46 inch Samsung plasma HP R4252 picture went black
Probably the power supply that drives the video has gone bad. Samsung recommends the TV go to a service center. If you have some skill and are willing to try, open up the back of the TV, remove the shielding and look at the boards to identify any obvious damage. Leaking or bulging capacitors, soot, scorch marks are the obvious. (Other parts can have bad solder or tiny cracks that are hard to spot.)
http://www.shopjimmy.com/catalogsearch/result/index/q/HP-R4252 has reclaimed parts for this TV. These are parts from TVs that were damaged in shipping and were only run during quality control tests. They list several power supplies for the model so check what part number is actually installed (there is usually a label on the board).
I hope this helps.
Posted on Aug 02, 2010
Verticals and horizontals lines on screen
May be a Yscan or buffer issue, but may also be a bad panel. Plasmas are very difficult "snap diagnose".
Either way, not an inexpensive proposition.
Nov 29, 2013 | Samsung HP-R4252 42 in. Plasma HDTV
Big large blackspot and fuzzy picture on Plasma TV
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
May 12, 2017 | Televison & Video
How do I correct pink and green bands accross HP-R4252 Plasma TV
First of all try, changing the input device to some other and see whether you see the same problem. Then connect your present input to a different TV and see. If you feel the input is ok, and it is a problem in the display, this is a case to be handled by a qualified service technician.
Jul 16, 2012 | Samsung HP-R4252 42 in. Plasma HDTV
I Have a Samsung HP-R4252 42 in. HDTV Plasma Television and the picture is not showing. It does have sound but no picture. Is there any ease way to fix this problem??
sounds like the video cable is not in the right input.
or maybe you have to redo the setup and be sure the tv is set to the right video input . HDMI or component etc. I hope this helps.
Oct 19, 2010 | Samsung HP-R4252 42 in. Plasma HDTV
Vertical lines across my entire screen
My 42" Samsung Plasma HDTV HP-R4252 has a 2" vertical strip of green pixels down the right side of the screen.
My 3 year warranty with Circuit City expires in Nov 2008.. so I hope I'm covered.. can't call until the morning.
Samsung said it might be a logic board problem.. but they want almost $2000 to fix. I might as well buy another TV if Circuit City can't fix it.
Apr 19, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Samsung hpr4252x perfect picture in
You have a burn in problem from watching widescreen movies.If you have access to a signal generator or tv setup disc run a perfectly white screen on the plasma for about 30 min.This should help even out the pixels on the display.
Mar 05, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Horizontal lines on Samsung Plasma
Sounds a lot like the Power supply board. But you have to check it out further to be sure. Email me back and we'll chat. GURU JAY
Feb 05, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Vertical colored lines on top and bottom of screen
Definately a video processing problem and it may need a logic board it is called. Does the set work fine if you feed component into set to bypass all that? Let me know. GURU JAY
Sep 11, 2007 | Samsung HP-R4252 42 in. Plasma HDTV
Verticle lines on screen
This is a very easy fix. Your cable box is not grounded correctly. To fix this you need a AC Plug adapter. This will change your TV ac plug from a 3 wire to a 2 wire. This may sound funny, but trust me on this. I have fix a lot of TV in NY doing just this.24001fc.jpg
Sep 10, 2007 | Samsung HP-R4252 42 in. Plasma HDTV
Samsung HP-R4252 42 in. Plasma HDTV Logo
204 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
