Question about Sunbeam Manuel Blood Pressure Monitor W/ Stethoscope
The gauge does not work on the manual bp cuff
I have a sunbeam sphygomomanometer that is attached to a manual bp cuff. and the gauge is not calibrated right any more. it starts at 200. and then when pumped up to it goes to 300 then over to the correct start position of 20 then on up. and hence it does not give an accurate reading when i take bp. is there a way to recalibrate it? or do i need to get a new one? if i need a new one, where do i go for one? thanks so much.
  • Anonymous Mar 26, 2014
    As stated above, the monitor is FarmaMedia BP-103 and I need to know if it needs recalibration and if so, how do I get this done?
If u look at the bottom of the gauge there should be a small hole if u insert a small screwdriver or similar u should be able to turn it until it begins at zero if that doesnt work then u probably need a new one
Posted on May 16, 2012
    Problem Solver:
  • 10 Answers
It sounds broken, calibration won't help it.
just go buy a new one at walmart. They are in the area of the pharmacy. I think they run about $20.
Posted on May 25, 2009
How to calibrate omega 1445 bp monitor
My first question is how do you know it's not accurate? I would tee in a digital manometer (measure in mmHg), wrap the cuff around a glass bottle and let the cuff inflate. When it fully inflates the cuff...look at the readings between the monitor and your manometer. If they are within a few digits of one another, I would leave it alone.
Inaccuracies with patient nibp readings are usually related to improper cuff placement on the patient. There's usually a mark on the cuff to indicate where the cuff should be placed in relation to the brachial artery. I believe this unit utilizes oscillatory technology to determine readings and an improperly placed cuff can create inaccurate readings.
May 23, 2014 | Criticare omega 1445 BP Monitor
The needle on the Sphygmomanometer gauge will not return to its zero reading. Otherwise it seems to function correctly.
This will happen sometimes, if the BP Cuff has been dropped and the gauge gets stuck. Have you tried tapping on the gauge with your finger, to get it to return to 0 ? Also. be sure the thumb screw air valve is fully open and the cuff is completely deflated. The gauge is easily replaceable, if necessary. Just contact the manufacturer of your BP Cuff or if you prefer Sphygmomanometer.
Thanks for choosing FixYa.
Sep 22, 2011 | Lifesource Aneroid Professional...
SOFTWARE PROBLEM DURING PUMP FUNCNTION SO MANY ERROR I WANT UREGENT SERVICE PLESE CONTACT NO. & ADD. SERVICE CENTER IN AHMEDABAD
What brand of BP Monitor?
Is this a personal BP monitor?
Or is it a hospital BP monitor?
Well.. you have to check the cuff to see if it's OK. Most of the errors are because of the cuff which has a balloon inside the cuff.
It depends on your model.
On some models you can take off the cuff line. Check if there is air coming out from the BP machine. If there ir air, it must be probably the cuff.
If both the cuff and machine is OK, then the problem must be the machine calibration.
Is it electronic or manual BP?
Hope it helped.
God Bless You!
Feb 05, 2011 | Health & Beauty
What does it mean when you get a reading then 3 consecutive readings say EE
What is the pattern of the EE? If the two E's are on the same line, then you didn't inflate the cuff to a sufficient pressure. (Wait 2-3 minutes before trying again and then inflate the cuff to 40 mmHg higher than the previous attempt.)
If the Es are arranged vertically, then you overinflated the cuff. Any [ressure above 300 mmHg is beyond the range that this bp monitor can handle. If you reached this point by getting several underinflation alerts, ask your medical professional to test your bp and recommend the starting inflation level that you need.
Make sure that you have the cuff on properly. You may need to consider a different bp pressure cuff size to get an accurate reading.
I hope this.
Sep 09, 2010 | Omron Model HEM 432C Manual Inflation...
Sunbeam7650 Don't know how to properly set the Pressure Selector
The switch tells the machine how high to pressurize the cuff when it starts. It needs to somewhat higher than your normal systolic pressure (mm Hg). (So if your systolic (top number) bp is regularly between 100 and 130, set the switch to 160.) Similarly if your systolic pressure is regularly above 130 but below 170, set it to 200)
I hope this helps.
Jul 19, 2010 | Sunbeam Digital Blood Pressure Monitor
The Sunbeam blood pressure kit doesn't inflate the cuff.
You have the same problem I do. The hose socket to the machine is broken.
Jul 10, 2010 | Sunbeam Digital Blood Pressure Monitor
Looking for replacement arm cuff for my sunbeam blood pressure monitor model 7652
To get a replacement arm cuff call sunbeam at 1-800-394-2326
The cuff will cost you 12.95 there. If you need you can get the manual and order sheat on the link below. Page 10 of manual.
http://www.foodsaver.com/manuals/HAH/Manuals/7652.pdf
Good Luck
May 24, 2010 | Sunbeam Health & Beauty
Readings vary widely withing 5 mins. when repeated
You should not recheck BP until at least 15 minutes after the first check because it will always get higher on reading even with a manual BP machine. As a retired nurse I have both an automatic HoMedics which I I lost the manual for and a old type arm BP cuff. My automatic is pretty close to the other cuff in readings so I know it is close. Try waiting for a while before you recheck and not talk or move around when you take it.
Mar 10, 2009 | Health & Beauty
Sunbeam Manuel Blood Pressure Monitor W/ Stethoscope Logo
299 people viewed this question
Top Sunbeam Health & Beauty Experts
Kevin Hill
Level 1 Expert
musquodoboit
musquodoboit
Level 1 Expert
Are you a Sunbeam Health and Beauty Expert? Answer questions, earn points and help others
