Question about GE Profile Spectra JGBP90 Gas Kitchen Range
UN LOCKING GE PROFILE OVEN
THE PROFILE SAYS LOCK ON AND WE CAN NOT USE THE OVEN. HOW DO WE UN LOCK IT?? I CAN NOT PULL THE SWITCH CAUSE IT WOULD TEAR THE GRANITE AND IT IS NOT CHEAP.
  • siralexm May 25, 2009
    ACTUALLY THE PROBLEM WAS EASILY SOLVED WHEN YOU PUSH 9 AND 0 TOGETHER FOR 3 SECONDS,,, IT WILL UN LOCK AND YOU CAN BAKE. DISCONECTING WON'T HELP. I TURNED OFF THE POWER FOR 10 MIN. AND IT WAS STILL LOCK. BUT PUSHING THOSE 2 BUTTONS TOGETHER,,, IT HELP!!!!!!!!!!!
  • 46 Answers
Pull the oven out away from cabinets and pull lever!
Posted on May 25, 2009
My GE Profile electric kitchen stove has the oven door open but the locking latch engaged which prevents the door from closing. The panel light is blinking that the door is locked. Solutions???
Hello, Lou -
Try this:
- Switch the circuit breaker for the oven to Off.
- Wait a full minute.
- Switch the circuit breaker back to On.
If those steps do not work to solve the problem, the problem could be caused by the micro-switch for the door lock assembly signaling to the oven control board that the door is locked. You will need to remove the door lock assembly cover. Before doing that, make sure the oven is unplugged from the electric outlet. You will need to pull the oven away from the wall.
Then, disconnect the door lock assembly wires from the micro-switch (make sure you note where the wires connect) so that the door lock assembly can be moved back to the open position.
Then plug the oven back into the electrical outlet or flip the circuit breaker to On. Test the oven to determine if it runs on broil or bake. If it does, the door latch assembly will need to be replaced.
If the oven still doesn't work and the control light continues to flash indicating the door is still "locked", then the electronic oven control will need replacing.
See this video:
https://www.youtube.com/watch?v=JroL8UPDkgI
If you do not feel comfortable following the steps for removing door lock assembly and the subsequent steps, you will need to arrange for a repair technician to come to your home to determine what is wrong and make repairs.
Best wishes.
May 11, 2018 | GE Kitchen Ranges
Ge profile oven lock button won't go off
  • 1.Press the "Clear/Off" button on the control panel to reset the oven. This will clear the lock setting and unlock the door.
    2.Allow the oven to cool to room temperature to avoid turning the lock on again during this heating cycle.
    3.Reset the oven to the temperature you require to finish cooking by pressing the correct temperature control on the control pad.
    or
  • 1.If your GE Profile microwave won't turn on, unplug it, then plug it back in. A power outage may have occurred due to a power surge. Check your home's fuses and circuit breakers.
    2.Set the clock of your GE Profile microwave. Certain models will not operate until you set the clock. Select the "Clock" key and type in the correct time.
  • 3.Hold down your microwave's "Off" button. You may have accidentally hit the control-lock feature on your GE Profile microwave. Hold down the "Off" button for three seconds to turn the lock off.
  • 4.If the sensors of your GE Profile microwave are not working correctly, remove the food from the machine. If the sensors detect food-surface temperatures over 200 degrees Fahrenheit, it will not work properly until the area cools down.
  • 5.Contact GE Support if you are unable to resolve the issue on your own. Call the GE Support hotline or browse the help library on the GE website. You can also schedule a service visit on GE's website.
  • Nov 22, 2011 | GE Profile JK915 Electric Single Oven
    Ran the self cleaning cycle - Now it keeps posting un lock dor. Lock bar easily moved to the unlocked position after cycle completed and oven was cooled. I have unplugged the oven waited 10 minutes and...
    Your switch isnt right ,check the wiring on the switch or make sure the switch is closing or opening when its suppose to,you should hear a click each time it opens or closes. your problem is in the switch area no where else,the computer on the oven needs tosee that switch input and doesnt
    Feb 15, 2011 | GE Profile 30" Self-Cleaning Slide-In...
    My GE Oven JTP 14 displays an F9 error and shuts off.
    F9 error - Lock switch error.
    Resolution - Check wiring to door lock switch (the wire harness may be connected wrong). Check for stuck lock switch.
    Hope i helped you.
    Thanks.
    Sep 02, 2009 | GE Profile JTP18 Electric Single Oven
    Whirlpool Stove Self Cleaning Oven mechanism won't shut off
    pull the power cord it should hopefully un lock the magnetic lock
    Jun 24, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
    GE Profile elec range JSP40 Locked door flashing can't use oven
    Replace the oven temperature sensor to solve the F3 problem.
    You may need to replace the oven lock micro switch to solve the locking problem.
    Change the sensor first. Then try the oven.
    Mar 04, 2009 | GE JSP46 Electric Kitchen Range
    GE Profile Electric Self cleaning oven locked still lit
    There is an overtemperature switch built into the electrical panel of the oven. Resetting this switch may solve the problem.
    To reset it:
    TURN OFF THE POWER!
    Open the door (if it is locked, turn the power back on and gently pull on the door every few seconds as the locking mechanism cycles until it is unlocked)
    remove the 3 screws below the control panel (screws point upwards, with the head just inside the oven)
    pull off the face of the control panel. Let it dangle by the wires so that you have access to the space behind it.
    Within the electrical enclosure exposed by removing the control panel, Look for a small silver and black device with 2 wires attached to the back. The device is about .5" wide by 1" long and is attached with 2 screws to the sheet metal on the bottom of the electrical enclosure. usually located nearly in the middle of the electrical enclosure.
    Push the tiny button on top of the switch. You should feel a click.after Reassemble and power up.
    hope this solves the problem do let let me know i will appreciate a fixyaa rating thanks and Godbless
    Nov 23, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
    DOOR Locked Flashing
    check the interlock switch, can be some object has stuck to it...
    Sep 06, 2008 | GE Profile JTP18 Electric Single Oven
    Our GE Profile JTP18 keeps flashing "door lock" since we ran a self clean
    most of the time a simple fix.... http://www.geappliances.com/search/fast/infobase/10004586.htm
    you have to trick the door lock mech into cycling through the cleaning process (takes about 20 seconds)
    Print Range - “LOCKED DOOR” flashes in the display
    If “LOCKED DOOR” is flashing in the display of your range or oven, and the self-clean cycle has not been selected, follow the steps below to reset your control:
    Motorized Switch
      1. With the door open, locate the door jamb switch on the face of the oven. It will look like a small black post or dowel.
      2. Push it in until the oven cavity light goes off, indicating that the oven believes the door is closed.
      3. While you hold the door jamb switch in this position, complete the following steps.
      4. Press the Clean pad, wait 10 seconds.
      5. When the cycle initiates, press the clear/off or cancel pad immediately to cancel it.
      6. Wait 10 seconds for the display to clear.
      7. The door should unlock and there should not be a need for service.
    Manual Switch
      1. Press the Clean pad.
      2. Close the door.
      3. Slide the latch to lock the door.
      4. Hit the cancel button immediately.
      5. Unlock the door.
    If the above does not correct the situation, a service technician will need to check your cooking product. To obtain in or out of warranty repair on Major Appliances, you may call 1-800-GE-CARES (800-432-2737) or schedule service online.
    Sep 14, 2007 | GE Profile JTP18 Electric Single Oven
    GE Profile Spectra JGBP90 Gas Kitchen Range Logo
    297 people viewed this question
    Top Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Ismael Rodriguez...
    Craig Butler
    Craig Butler
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
