Question about LG LDF9810ST Built-in Dishwasher
Will not come on.
My LG LDF9810ST will not come on. Dishwasher does have power. It stoped working in the middle of a cycle.
  • 423 Answers
Since the LG LDFxxxx family, including the 9810 all have a power button (and not just a door handle interlock switch that turns the unit on when you close the door, you have an internal problem that will not have a quick fix.
This dishwasher had a 12 month parts and labor and a 24 month parts-only warranty. If you have proof of purchase, I recommend you contact the LG support number in the owner's manual.
Good Luck!
Posted on May 26, 2009
LG dishwasher LDF9810ST. After starting it stopped in mid cycle and the display will not show anything or even light up. The interior light works and has power. But controls will do nothing
First check to see if there is a reset. This is usually some combination of the keys on the display. Your user manual will give you the combination to use.
Jan 02, 2017 | LG Dishwashers
I have a prima LPR 450 dishwasher, the light is on but I cannot select a program
If the unit is not operating, then it will require service. To make service arrangements, you may either contact our Customer Interactive Center at 800-243-0000, or you can check our Repair Provider Lookup on our website, at http://www.lg.com/us/support/repair
May 10, 2014 | LG LDF9810ST Built-in Dishwasher
Water not draining and a e0 is flashing
http://www.fixya.com/answer/answerpageslideview.aspx?thid=24072807&ctg=131&brd=474
Mar 26, 2014 | LG LDF9810ST Built-in Dishwasher
There is a 'Cr' message on the display panel, and none of the buttons respond while this message is displayed. What does this mean, and how can it be cleared so that the dishwasher can be operated...
Mine is doing the same thing right now. It started beeping again this morning after I wiped off the touch pad. I shut the power off to it at the box and when I turned it back on to try to make it work it just showed the Cr on the display.
Dec 05, 2010 | LG LDF9810ST Built-in Dishwasher
There is a very faint sound and you can't hear it anymore. It's almost like there is no sound. On my LG LDF9810ST.
It could be turned off... and the faint sound is air you can hear .....this site is for 'machine' problems it sounds like your LG does'nt have one. Best Wishes.....Helen
Apr 17, 2010 | LG LDF9810ST Built-in Dishwasher
I have an LG Dishwasher model LDF9810ST. Error code E1 keeps showing (Water Leakage Problem) NO water problems anywhere to be found. I have a hard time shutting down the machine. It has had a new MAIN...
Are you draining the unit in the basement or under the kitchen sink?
If you are draining the unit to the floor you will need a new drain hose with a syphon breaker. This drain hose is factory installed on all new LG dishwashers.
The part # is AEM69493801
This is a known issue and may be covered under your factory warranty.
Depending on where you live a factory service tech may be in your area.
Could you explain the second problem further...Hard time shutting down?
Shoot me a E-mail @ omaharox@msn.com.
I am a LG factory service technician not a sub contractor.
Mike
Jan 08, 2010 | LG LDF9810ST Built-in Dishwasher
Not drying dishes, help!!
The LG LDFx810 dishwasher energy saving series uses a condensing system mounted in the door and does not turn on the heating element during the drying cycle. Rather it heats the final rinse water and then runs the condensing fan system to remove the moist air. Energy saving dishwashers will never dry as completely as the energy hogs of 10 years ago - especially the plastic items.
Also, confirm that the rinse aid is full. This will help with drying considerably.
Aug 03, 2009 | LG LDF9810ST Built-in Dishwasher
Dishwasher problem
The LG dishwasher family has a cool feature that alternates the full wash/spray power between the upper spray arms and the lower arm.
It is called Vario - with a motor that drives a check valve to route the water.
So, If you just open the dishwasher while it is running and look to see if all the spay arms are spinning, you will be disappointed.
Now, if you are having problems with dishes not getting cleaned, we need to take the next step. Post back what you find.
Good Luck!
Apr 09, 2009 | LG LDF9810ST Built-in Dishwasher
LG LDF9810ST Built-in Dishwasher Logo
439 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
