Shakes violently durring spin cycle as if load were out of balance, but it's not.....Does this machine have a wig/wag? I'm guessing it's stuck in 2 gears at the same time..??
  • 46 Answers
Get a level and make sure that the machine is level by adjusting the legs with a cresent wrench or a pair os channel locks
Posted on May 25, 2009
Why is my washing machine Miele w404 making thudding noises on spin Plse?
Unbalance load???
When in spinning cycle, does your drum start shaking violently and hitting the washer outer walls. Out of balance load.....
Is your machine on level floor. Does it have a play on legs while sitting doing nothing???
Happens for every load, then may be your washer shocks and/or top coil springs have come out or broken..
Or machine drum counter weights broken and drum going out of balance.
Apr 25, 2015 | Miele Washing Machines
How do I fix a front load washer that shakes violently on the last spin cycle?
CLOTHES UNBALANCED? OR COUNTER BALANCE SUPPORTS BROKEN, AND NEED REPLACMENT? WASHERS have many different weight balancers but sounds like u need to take body off and have look at the counter weights set up while running machine, just jumper the door switch to keep a closed line. and then agin sometimes its as simple as making sure ur washer is leveled on ur floor, check ur leg adjusters as they do get funny at times..
Sep 13, 2014 | Washing Machines
Whirpool imperial series will agitate but will not do spin cycle
If that is the old belt driven modle I would check the lid switch. If it is bad then no power will get to the wig-wag and the transmission will not be shifted. If the switch is fine check for corrosion on the shift pins or an open wigwag coil. The wig wag has 4 wires. 2 white wires that are common AND 2 other wires for wash and spin. A neat trick is to swap the 2 control wires and see if it washes in spin and spins in wash. That way you can determine if the wig wag coil is bad.
If the washer is a newer model without a belt I would say your lid switch is bad.
Oct 29, 2011 | Whirlpool Washing Machines
Violent shaking on spin cycle
make sure you loads are balanced, put heaviest clothes in first... if you can rock it by hand then the legs are not adjusted properly. If you stand 2 feet away from front of machine, jump up and down and see it move the floor is soft and you need 2 sheets of plywood to make 1 1/2 inches put under the machine
Aug 17, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Spin cylcle not working. Makes a funny sound and does not spin
There is a part called the Wig Wag. It is 2 solenoids on a metal bar about 6 inches long. It has a hole in the center of the bar and 3 electrical wires go up through the center. One is a common wire and the other two go to each selenoid. One selenoide when activated causes the WIG WAG to shift the Transmission into WASH MODE or SPIN MODE. They are powered by 115 VOLTS AC and is enough to KILL YOU.
What you will find is the 3 wires are held together by a few wraps of electrical tape. Because the WIG WAG moves while the machine is running, the wires are all the time FLEXING. Eventually a wire will break and in this case it was the SPIN Wire to the SPIN solenoid.
Replacing all 3 wires is the best fix. Splicing near the wig wag could cause the wires to break again, They could then pinch or touch the moving metal parts and if the washer is NOT properly GROUNDED someone could get ELECTROCUTED and KILLED.
USE CAUTION doing this repair. The replacemet wire needs to be FINE Grain Flexable wire. If you use something like Lamp Cord that is not designed to be flexed hundreds of times will soon break.
Check with Sears Parts and ask for a Wig Wag Wire Harness.
You can lay the machine on it's back and see this problem. Caution plugging it in on it;s back, something could break.
The Wig Wag can take your fingers off..... CAREFUL !!!!
Do this repair at your own risk. It is dangerous.
At least you will know what to tell the Repairman.
Apr 26, 2009 | Washing Machines
Kenmore heavy duty washer wont spin but does everything else corr
you really still have a belt model? that unit is close to 30 years old now.
anyway if the unit looks like all is moving, then you may have a bad lid switch or most likely an open coil on the wig wag assembly.
it is the part the has 2 coils on a metal bracket on top of the transmission. it moves back and forth when the unit is running.
does it drain but just not spin? if so then you could just have a broken wire to the wig wag or the coil could be bad. wires do break to the wig wag , but you usually hear the coils engaging then shutting off if the wires are bad. so check the coils and try to replace the wig wag second if you dont find a bad wire.
Jan 31, 2009 | Kenmore 22422 Top Load Washer
Shook Violently first time on spin cycle
Make sure the washer is leveled properly and all four feet are resting on the floor. If it is level, try running one cysle without any clothes in it to see it is spins without that violent shaking.. you may have also had an out of balance load.. Hope that helps!
Aug 13, 2008 | Samsung WF337AA Front Load Washer
Kenmore 70 series top load washer - no spin
the older belt drive washer has a cylanoid under it on the top trans missin called a wig wag eather broken wire to it are bad wig wag can still be found ck lid switch also
Mar 19, 2008 | Washing Machines
Washing Machines Logo
106 people viewed this question
Top Washing Machines Experts
